#57 |
Drives: 2013 WRB BRZ Sport Tech
just made the changes and will flash before i drive home from work, hopefully will get enough driving in to datalog...
#58 |
APEXHNTR
Drives: 10 Series FR-S #1867
okay so here's a pull with the 91 octane tune and still the same tank of 93 as all my previous logs
http://www.datazap.me/u/silver-ignit...g=0&data=1-2-5 I think it looks pretty good, what do you guys think?
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#59 | |
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
but maybe between 6000 and 7000 you could remove a degree of advance, since your flkc is a between -1 and around -2 ? |
| The Following User Says Thank You to Walla Walla For This Useful Post: | Silver Ignition (08-06-2014) |
#60 | |
Drives: FT86
seems strange to have to remove so much on 93 USA, maybe you got a bad batch, happend to a mate of mine a couple of weeks ago, tune was fine then filled up at normal supplier outlet (98RON OZ fuel)) and soon after knocks like crazy IAM about 0.6 where its usually solid at 1. Suspect station had filled tank with lower octane fuel (he checked his receipt and was correct octane), after he filled up again a couple of days later at different outlet all ok same fuel. http://www.datazap.me/u/silver-ignit...7-12&solo=6-12 |
| The Following User Says Thank You to steve99 For This Useful Post: | Silver Ignition (08-06-2014) |
#61 | ||
APEXHNTR
#62 | |
Drives: FT86
unless you want to wait and try different fuel or octane booster ? its strange 93 octane should be better than that |
#63 |
I've had the same spot, running 94 octane in canada, now i don't have my BPB installed yet so i don't if that's anything but our gas has a bad reputation.
I might just switch to the 91 rom just cause our gas sucks and i cant get 94 everywhere i might end up. Running A01C 93octage Stage 2 UEL This log has 4 3rd gear pulls each had the same area of knock, http://www.datazap.me/u/hagbard/aug3...om=15553-16183 http://www.datazap.me/u/hagbard/aug3...om=14039-14594 http://www.datazap.me/u/hagbard/aug3...om=12709-12874 http://www.datazap.me/u/hagbard/aug3...om=11037-11289 Pulled some timing and got this now. http://www.datazap.me/u/hagbard/aug-...zoom=5427-5808 http://www.datazap.me/u/hagbard/aug-...zoom=6997-7287 just the od -.65 in the lower rpm |
#64 | |
APEXHNTR
there's a lot of knock correction happening now...
#65 | |
Hicas Thread Basher
there is a lot, but it seems like small correction, as @steve99 said, under -.07 you should not really worry about it. The correction is bigger than the knock itself as i understand, (to be sure to "stop" the knocking situation, that it wont knock multiple times) i'm doing a long term datalog to see the evolution of those knock, and also to spot tendency of know (where and how strong) and it's seems that, with time, your short term and long term fuel trim seems to developp, and produce less knock. i'll post my results in a few days. maybe it will help to build some kind of guideline, of what is normal, and what is not! |
#66 | |
Hicas Thread Basher
how much timing did you remove? for the gas, if it's 94 petro can, it really have a bad reputation. it contain ethanol, and it seems to produce more knock. but, there are some debate on this... |
#67 | |
Drives: FT86
I rearly would try a different brand of fuel then if no luck, pull a bit more at the effected load/rpm points where the knock is try just over half of what the ecu is removing. The fuel trim and knock learning is pretty quick usually minutes unless you have big fuel trims which you dont. |
#68 | |
APEXHNTR
#69 | |
APEXHNTR
I'll put a few more miles on it and try another log. Wish the almighty @Shiv@Openflash would chime in and tell me if I'm on the right track...
#70 | |
Hicas Thread Basher
today, same drive, 4 knock issue.... so it seems that it could get better with time... but still, not a lot of data to back this up! with @steve99 comment, i'm starting to think I should try this long run log with different gas brand each week, just to see! |
| Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks | Shiv@Openflash | Engine, Exhaust, Transmission | 129 | 11-24-2017 07:58 PM |
| Crawford Billet Power Blocks | smbstyle | Engine, Exhaust, Transmission | 799 | 01-18-2016 05:01 PM |
| Crawford Billet power blocks | Triumphrider | Engine, Exhaust, Transmission | 0 | 08-01-2014 01:39 AM |
| FS: One set of barely used Crawford Billet Power Blocks | Robert@Openflash | Engine, Exhaust, Bolt-Ons | 1 | 06-07-2014 04:13 PM |
| **Crawford Power Block Install Special -- R/T Tuning -- Call Today** | R/T Tuning | Engine, Exhaust, Bolt-Ons | 3 | 05-21-2014 11:18 AM |
