#57 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Well it's enabled in the rom by default.... But as far as changing the value, shiv just posted about needing new xml files
#58 |
Drives: 2013 FRS
v2.01 Beta download folder is up: http://openflashtablet.com/Automotive/FRS/downloads/
Again, no changes to the map files so no need to load up maps again if you already loaded v2.0 Beta. All I did was update the XML files with Launch Control and No-Lift Shift definitions. The maps will go non-Beta next week. At this point, the only change I expect to make is disabling the U0155 diagnostic code. In the previous map releases, that diagnostic code has usually been disabled by default. It's caused when there is a loss/interruption of communication between the ECU and a diagnostic device (in this case, the OFT). It's pretty easy to trigger if you unplug the OFT at the wrong time. It's annoying but totally benign. So feel free to disable it yourself (with ROM Raider) if you feel so inclined ![]() I'm glad you guys are really enjoying the new v2.0 maps! Cheers, Shiv |
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post: |
#59 |
Drives: White BRZ
Noticed that OFM no longer says something along the lines of "checksum corrected" when loading the .bin maps into the memory slots. Is that something that should still happen?
#60 |
Drives: too soon junior
yay! it works
#62 |
Drives: 2013 Scion FR-S Auto- OFT Stage 2EL
I'm happy. 2.0 stage 1 91. Noticeable difference from 1.59 to 2. Well done!
2013 Scion FR-S Auto, OFT Stage 2 Equal length 94oct, Hollowed out Factory Manifold, Stock Overpipe, Hollowed Front Pipe, Stock Midpipe with Resonator Removed, Custom Axleback with Single Exit and a Flowmaster 50series Muffler. Stock Airbox with all resonators removed, Snorkel shortened, TRD Panel Filter.
The Following User Says Thank You to toyotaAlex For This Useful Post: | Shiv@Openflash (07-26-2014) |
#63 |
Fanboy
Drives: 2013 ultramarine frs
Shiv
windows8 patch 404s is USB3.0 supported yet?
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#64 |
Drives: FRS(sold), AP2, R35, FJC, ED9
is it me or am i not noticing the valve timing coming on or kicking in as strong as before. i know it takes a while for the valve timing to reinitiate so i drove around for 15 mins which usually does it but i can't hear it anymore and the power boost isn't as dramatic. power deliver does feel much smoother though out, is that why i'm not feeling it? stage-1 91 oct 700C rom
also the real time charts are missing all the texts. going to try to reload the templates. Last edited by garfull; 07-25-2014 at 11:59 PM. |
#65 |
Drives: 2013 FRS
No need to upload the template file. There has a been a bug with the current firmware versions (v1.27) that requires you to unplug and replug the OFT after flashing the ecu in order for the datalog channel text to be displayed. It will be fixed with the next firmware update.
The Following User Says Thank You to Shiv@Openflash For This Useful Post: | garfull (07-26-2014) |
#66 |
Drives: 2014 Scion FRS
How do you upload 2.0 maps into oft?
2014 Scion FRS- Kw2 suspension, Openflash headers, Openflash tablet, Invidia N1 exhaust, Invidia Overpipe, Nameless catted front pipe, TRD intake, Enkei RPF1s with Hankook RS3 tires, carbon fibre front lip, TRD knockoff spolier, SPC lower control arms.
#67 | |
Fanboy
my guess is he found power below where it used to "kick" so you don't feel it as much. Same reason my car doesn't feel like it pulls as hard as it used to up top now that I have the nameless header. I have more power everywhere but particularly lower in the RPM so the top end doesn't feel as good despite having more power.
The Following 4 Users Say Thank You to FrsDuke For This Useful Post: |
#68 |
Drives: 2014 Whiteout TRD FR-S 6MT
Is this only beta because its limited to USDM cars? I'm not sure if I should wait for the full version to flash!
EDIT: Just saw the earlier post, thanks shiv! |
#69 |
Drives: Whiteout 6MT
since they only have 90octane here should i just use stg1 or can i use stg1 91?
#70 | ||
perfect thanks. great job, well worth the wait.
The Following User Says Thank You to garfull For This Useful Post: | Shiv@Openflash (07-26-2014) |
OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 12:29 AM |
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 10:21 PM |
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
