Old 04-04-2015, 07:30 PM   #57
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I used to switch between stock rotors, hawk pc pads for the street to stoptech rotors, hawk hp+ pads for track but that got old quick. Now I stick with the track setup full time. I usually don't dd the FRS but I recently sold my wrx and will daily it through the summer for financial reasons. The hawk hp+ pads squeal like crazy but I just don't care. They are worth keeping on bc of the braking power. I highly recommend this setup.
If u ever need a place to work on ur car give me a holler. I am about to purchase a house and have all the tools u should need. I also enjoy working on cars so it isn't an inconvenience.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
marchocais (04-04-2015)
Old 04-04-2015, 07:55 PM   #58
marchocais
Drives: Scion FR-S
That much of a bother huh? That's kind of what I was thinking of doing since I don't want to street my track tires. I figure, the wheel is off might as well switch the pads too.
Do you have to bed-in the rotors and pads before every event?
marchocais is offline   Reply With Quote
Old 04-04-2015, 08:06 PM   #59
Takumi788
JHerbert Racing
Takumi788's Avatar
It's not that it is hard to do its just that I missed the braking power of the race setup on the street. I tend to do some spirited driving quite often. You should only have to bed in the pads once.
Old 04-06-2015, 07:25 AM   #60
Takumi788
JHerbert Racing
Takumi788's Avatar
Just ordered bronze 17x9 +35 RPF1s and 245/40/17 Hankook RS-3s! That comes to 9 pounds off of each wheel compared to my XXR setup!
Also bought the Cusco sports accel pedal. Ever since installed ss brake lines and master cylinder brace I have had a hard time with heel toe since the brake pedal is so much higher than the throttle.
That's $1800 before 8 o'clock AM on a Monday.
Taking a half day today to install my Openflash Header! Expect videos soon!
Old 04-06-2015, 07:52 PM   #61
Takumi788
JHerbert Racing
Takumi788's Avatar
Openflash header and Manzo overpipe installed!!!
[ame="https://www.youtube.com/watch?v=IuYmRxvWUBY"]https://www.youtube.com/watch?v=IuYmRxvWUBY[/ame]
Old 04-07-2015, 01:08 AM   #62
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
How many inches is wind splitter from floor?
Packofcrows is offline   Reply With Quote
Old 04-07-2015, 01:26 AM   #63
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Just found your thread today, I think we both have very similar end goals in mind for our builds. Subscribed for updates
Decay107 is offline   Reply With Quote
Old 04-07-2015, 07:43 AM   #64
Takumi788
JHerbert Racing
Takumi788's Avatar
I will get this measurement for you asap. I think I remember the top of it being 4.75" when I measured it to see if it was level.
I have seen your thread. I agree we do have a similar goal. I am jealous of all the track days you do. I am lucky to do 4 in a year the way the weather is here. Your build thread states the SPL LCAs didn't have enough camber adjustment. I was planning on buying those (unless VELOX gets theirs done soon) and want to run -2 degrees in the back. Do you think I will be ok? Its kind of weird for such little adjustment on that type of LCA.
Packofcrows (04-07-2015)
Old 04-07-2015, 10:46 AM   #65
Decay107
Decay107's Avatar
Originally Posted by Takumi788 View Post
...I am jealous of all the track days you do. I am lucky to do 4 in a year the way the weather is here. Your build thread states the SPL LCAs didn't have enough camber adjustment. I was planning on buying those (unless VELOX gets theirs done soon) and want to run -2 degrees in the back. Do you think I will be ok? Its kind of weird for such little adjustment on that type of LCA.
And I am jealous of the tracks available near you! Yes, I couldn't get nearly enough camber out of them with what I would call reasonable thread engagement. It is really going to depend on how low you are. I'm running my coilovers with a lot of stroke at around stock ride height (great for cornering, less so for looks), so I'm going to need a whole lot more adjustment than someone with even a mild drop.
Old 04-09-2015, 08:23 AM   #66
Takumi788
JHerbert Racing
Takumi788's Avatar
They are here! Wheels arrive today!
The Following 2 Users Say Thank You to Takumi788 For This Useful Post:
akahenry (04-15-2015), shifter907 (04-09-2015)
Old 04-09-2015, 12:58 PM   #67
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Nice setup!
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
Takumi788 (04-15-2015)
Old 04-10-2015, 11:32 AM   #68
Takumi788
JHerbert Racing
Takumi788's Avatar
So stoked that my wheels arrived I forgot to take a picture of them. You know you're a car guy when the UPS driver knows you well enough to pull into your driveway to drop parts off. lol
While waiting for my wheels I installed my Cusco throttle pedal. I have had a hard time with heel toe after installing ss brake lines. My heel could just barely reach the throttle while my "toe" was on the brake. This added a good amount of space on top of the stock pedal. I noticed that the way the gas pedal assembly is mounted to the car allows for a little adjustment by using washers behind the assembly if you wish to move the throttle pedal closer. I like the pedal and it seems like it is going to do what I wanted, but I will probably add a washer or two to make it even easier.
Old 04-10-2015, 04:00 PM   #69
Jonsey
Jonsey's Avatar
Nice addition, I just did this to mine the other day and it makes heel toeing much easier. For some reason I also found it very amusing to hold the throttle pedal in my hand. It was just odd to me how easy it comes off. I feel like I may need to prank a friend at the track next time...
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
The Following 2 Users Say Thank You to Jonsey For This Useful Post:
endless_pain (07-29-2015), Takumi788 (04-15-2015)
Old 04-11-2015, 09:53 AM   #70
Takumi788
JHerbert Racing
Takumi788's Avatar
Quick teaser for now. More pictures to come soon. 17x9 +35 245/40
New hottness vs. old and busted
Installed teaser
akahenry (04-15-2015), LucidMomentum (04-11-2015)
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
street + track oil question autobrz Tracking / Autocross / HPDE / Drifting 51 11-20-2013 11:32 AM
Street to track giraffee Australia Classifieds 1 10-31-2012 02:03 AM
Different pads for street and track Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-01-2012 02:55 PM
