Old 06-18-2014, 07:34 PM   #57
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
The business pieces of the Avo kit sit down on the right (passenger) side of the engine. I would start there and check for anything that looks out of order (Contact points and such).
Did you install yourself or have a shop do it for you? I wonder if something came a bit loose...
alexand3r is offline   Reply With Quote
The Following User Says Thank You to alexand3r For This Useful Post:
Astroboy (06-18-2014)
Old 06-18-2014, 07:42 PM   #58
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Judging by what's been posted I doubt OP installed himself no disrespect.
Anyhow I'd find a different more knowledgeable mechanic, one who's more familiar with car and turbos etc....
Also there's a lot to learn just by jacking car up safely on "good" Jack stands and looking and listening. Something may become obvious. Versus posting I'd be all over the engine doing just that like a spider monkey. Much faster results likely...
Old 06-18-2014, 07:46 PM   #59
Astroboy
Astroboy's Avatar
Drives: None
I installed it myself....
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
Old 06-18-2014, 07:54 PM   #60
Astroboy
Astroboy's Avatar
Drives: None
When it's a di faliure, would the rpms move funny?
Old 06-19-2014, 10:04 AM   #61
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Man just record a video and post it on here the next time it happens.
Old 06-19-2014, 12:22 PM   #62
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I have had this happen to me as well before a coil pack failure.
However it always went away on its own.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
Astroboy (06-19-2014)
Old 06-19-2014, 02:35 PM   #63
Astroboy
Astroboy's Avatar
Drives: None
so your car was wobbling on the passenger side to? almost sounds as if the door was vibrating... is that what you felt?
how much is a set of coils from the dealer if you dont mind me asking
Old 06-19-2014, 02:40 PM   #64
Astroboy
Astroboy's Avatar
Drives: None
Guys, thanks a lot for helping me out with this problem I'm having. ft86forum will be nothing without y'all
Old 06-19-2014, 04:08 PM   #65
feldy
feldy's Avatar
Not the door but more like where the shock was it was really weird. No idea on price. Dealer covered it.
Old 06-19-2014, 04:29 PM   #66
steve99
Can you log the per cylinder misfire counts this will tell you if its a misfire and which cylinder it is. It could be ignition or fuel related misfire but a least you will see which cylinder or cylinders are acting up.
their is a threshold for misfire counts where it will throw a CEL but you might not be reaching that yet.
likely culprits are DI seal failure or coil failure
also some general logging of AFR ignition advance and cam VVT RPM monifold pressure ect would be usefull as it could be anything even a CAM actuator playing up.
Or its just something mechanically loose on the car
Old 06-19-2014, 05:10 PM   #67
mike the snake
I know when a plug/coil doesn't fire, it can make the engine shake badly at idle.
Old 06-19-2014, 05:33 PM   #68
onzippy
Drives: 2014 FRS
Good thing this isn't webmd...patient would be dead for lack clear symptoms.
Sent from my SGH-T999 using Tapatalk
onzippy is offline   Reply With Quote
Old 06-19-2014, 08:16 PM   #69
onzippy
Drives: 2014 FRS
That was rude.. Sorry.
Why haven't you been able to post a video of the wobble, pop, shaking noise or movement you're talking about? You thought the wheel was loose, or the door, but your entertaining a DI failure and have yet to scan the ECU for saved events. Why?
Your LG-D800 does record video.
Old 06-20-2014, 12:31 AM   #70
Astroboy
Astroboy's Avatar
Drives: None
I haven't had time to upload a video, unfortunately, I've been way to busy. I spend most of my time at my job and school. when I'm not working I devote my time to school. I'm planning on giving awd tuning a call. I'm starting to worry now
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Ugh! Car won't start :( FRSGIRL❤ CANADA 53 05-10-2013 04:52 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Tad's CBS BRZ From The Start Tad_07 Member's Car Journals 8 10-12-2012 02:19 AM
