#57 |
My clutch began engaging like 1mm from the floor, and I suspect many people's are still grabbing slightly even with the pedal to the floor.
This causes hard to select 1st at a stop when warm, and sometimes the grinding when shifting. I adjusted mine so the clutch begins engaging with the pedal further up, or also so it begins actuating earlier when you start to push the pedal. Basically made the actuation rod longer. Our clutches have an extra spring, so it's hard to feel the proper "deadband". My clutch moved a lot before it began engaging, like 1.5'' to 2''. Usually you want 1/2'' pedal movement before anything moves clutch-wise. With the proper adjustment, the clutch engages earlier, and opens more when the pedal is pushed fully to the floor. |
#58 |
Life to short to be slow!
Drives: Toyota GT86
My clutch ACT 6 Pug, 4 months of use I did abuse it a little on the track. Now my 4th gear keeps grinding when I engage it above 5000 revs.
#59 |
Drives: 2014 Toyota FRS
Mine grinds speed shifting into 5th. And downshifting into 4th. I rev match as much as possible...doesn't help. If I slowly put it into gear at lower rpm...no issue. Only high rev fast shifts...tranny issue???
#60 |
Drives: 2014 SSM BRZ
Recently had similar issue of grinding going into 4th above 4k rpm. After a bunch of fighting with the general manager since the service manager was out I got a tech to ride with me. Previously couldnt get any work done since it was only in high revs when "speed shifting" not when driving "normal." This time the tech acknowledged the grind above 4k at highway merging speeds and passing speeds and put in the tech line. 30 mins later got a call back from subaru that they were sending transmission out.
#61 |
Drives: Toyota GT86
This Car is crap, not a sport car at all... thanks Subaru for a crapy transmision!
#62 |
New trans in mine feels amazing. Way it should've worked from the factory
#63 | |
Dude go buy something else and go away!!!!! |
#64 |
For the record the trans does suck. Only reason mines good is because they just replaced it. Turbo doesn't kill synchros by the way
![]() Sent from my iPhone using Tapatalk |
#65 | |
The tranny is engineered for a stock vehicle not one putting out 360WHP as the complainer states he has. Although I will give him credit for at least upgrading the clutch. If this tranny were so bad on STOCK vehicles there would already be a service notice from Toyota/Subaru. I know, I KNOW there will be a million people saying they just don't acknowledge there is a problem but I will leave that up to the conspiracy theorists to debate. Toyota WANTS this car to succeed so will deal with any known issues. My whole point is don't do heavy mods, drive the crap out of it, then go yelling foul when something breaks. |
#66 |
Mine was grinding on stock power output. And it's a known issue, Subaru told the tech on the phone this. As soon as the tech line was put in I got a new trans.
#67 |
Drives: s2000
#68 |
Bad luck then. Doesn't make them ALL bad. Got 4000 miles and mine is still as smooth as silk. Mind you I may eat my words if that changes!!!!!
#69 | |
Drives: Toyota GT86
You are very, very close minded, the trans suck and is a known issue. Aspirated FR-S are broken on the dealership and certain parts are in back order. Dont be a FAN BOY... this is my 3rd sport car and so far at around the same horsepower. Do you buy a sport car to sit on it? Wow thats a lot of fun!
#70 | |
Just because a bunch of guys whine and moan about their transmissions on a forum does NOT make it a known issue. It just means that the small percentage of the people that use the forum are more vocal about any problem they have. There are not nearly enough people that are on here to represent all the cars sold. Do a quick google search on FRS transmission problems and the only hits you will get are this forum or places that pulled their misinformation from it. Shit happens and things break when you push them. Fix it and move on |
| How would you shift from 4 to 5? | qqzj | BRZ First-Gen (2012+) — General Topics | 37 | 05-01-2014 08:10 PM |
| You know what really grinds my gears...... | z3ro | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 10-10-2013 01:55 PM |
| HUD shift up and shift down display question | JS86JS | Electronics | Audio | NAV | Infotainment | 6 | 05-17-2013 02:54 AM |
| What really grinds my gears! | CircuitJerk | Off-Topic Lounge [WARNING: NO POLITICS] | 124 | 04-01-2013 08:45 PM |
| How do you shift? | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 12-30-2012 01:11 PM |
