#57 |
Drives: Raven FR-S
I figured this would get more attention. Wonder how it will match with the open flash tablet?
#58 |
Drives: 2013 Scion FR-S Raven
Great question, wondering that myself.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#59 | ||
Drives: 2013 Subaru BRZ
http://www.mishimoto.com/silicone-in...ru-brz-13.html Additionally, check with your favorite vendor for the best available pricing. Let me know if you have any questions. Quote:
#60 |
Drives: 2013 Raven FR-S
any group buys?
#61 |
Drives: 2014 FR-S 6MT Whiteout
Ok, I have a technical question regarding this product and your silicone intake pipe. In the designing the silicone intake pipe thread you presented data showing that the best performance could be obtained (on stock tuning) with a panel filter and use of the plastic resonator that attached to the bottom of the intake pipe. Did you conduct any testing with the resonator in conjunction with this intake pipe? Is it still the case that optimum performance comes with use of the resonator?
And as an aside, once tuning comes into play (for example, the OpenFlash Tuner that @shiv@vishnu works on), do you still recommend the use of the resonator in conjunction with your silicone intake pipe? Thanks!
#62 | |
At this time we do not have any plans to start a GB for this particular intake.
Unfortunately we cannot provide a concrete answer in response to the question on tuning. If you are using our induction hose with a tune specified for use without the resonator, I would have to assume removing the resonator will generate the highest power output. Thanks for the inquiry, feel free to follow up with any additional questions. |
#63 |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
CARB number, or "for offroad use only in CA"?
#64 |
#65 |
Drives: Asphalt 2013 FR-S
Does anyone know if this is compatible with the Innovate super charger kit?
#66 |
Doesn't the Innovate intake pipe plug into the stock airbox? If that's the case there's no reason this shouldn't work as it plugs in in place of the stock airbox.
#67 |
Yeah that's what I was thinking too since both products are made to work with stock parts, but I wanted to ask anyways just in case.
#68 | |||
#69 |
Fiebru
Drives: Scion FR-S and Integra Type R
I have the AVO kit and I'm considering this intake but I have the Robispec radiator/oil cooler combo ... I am not sure if I have to modify the radiator support to fit it.
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
#70 |
Drives: brz
Gains with the hose/intake? Wondering how Perrin only got 4 whp while you guys got 10 with just the stock hose.
Silicone hose looks just like the other mass produced hoses... will this work with the Perrin silicone hose? I prefer their design with a smoother bend. |
| Mishimoto Needs Your Help With Our BRZ/FR-S Intake! | Mishimoto | Engine, Exhaust, Transmission | 10 | 03-31-2014 10:30 AM |
| FS: MISHIMOTO INTAKE TUBE | BlackyRose | Engine, Exhaust, Bolt-Ons | 4 | 03-09-2014 05:17 PM |
| Testing Our New Vortech Cold Air Intake @ Pure Automotive Performance! Dyno's Inside! | Pure Automotive | Forced Induction | 24 | 10-21-2013 12:29 AM |
| AMR Performance: Cold Air Intake System - BRZ/FR-S/GT86 | AMR | Engine, Exhaust, Transmission | 10 | 04-11-2013 12:37 PM |
| *Pure Automotive Performance: Project Whiteout FRS Build Thread* | Pure Automotive | Member's Car Journals | 6 | 01-18-2013 12:34 PM |
