Old 03-19-2014, 07:22 PM   #57
VuDism
NASIOC: AzNSTiImpreza
VuDism's Avatar
Drives: 2013 Whiteout Scion FRS
Oakos.com only place carries gunmetal @OAKOS Automotive
VuDism is offline   Reply With Quote
Old 03-19-2014, 08:01 PM   #58
BenBrown
Metal up your butt
BenBrown's Avatar
Drives: Subaru BRZ
can anybody tell me if its possible to find RPF1s in silver, not sbc, in 18x9.5 with 5x100 bolt pattern? Cant find them anywhere but from this one seller on ebay. Not sure if its legit though. heres the link
http://www.ebay.com/itm/like/291079002545?lpid=82
BenBrown is offline   Reply With Quote
Old 03-19-2014, 08:08 PM   #59
VuDism
VuDism's Avatar
Originally Posted by BenBrown View Post
where did you get those gun metal rpf1s in 18x9.5?? cant find them anywhere
http://www.oakos.com/Merchant2/merch...de=BRZ-ENKRPF1
Old 03-19-2014, 11:33 PM   #60
Captain Caveman
Drives:
Oakos also has 2 staggered setups in gunmetal, 18x8.5/9.5 and 17x8/9. Decisions, decisions...
Captain Caveman is offline   Reply With Quote
Old 03-19-2014, 11:41 PM   #61
EN2_Squirrel
EN2_Squirrel's Avatar
17x9 +45 with 255/40 zII used for autox
EN2_Squirrel is offline   Reply With Quote
Old 03-20-2014, 12:20 AM   #62
Wepeel
Drives: '13 BRZ Ltd
Do you have tire rub anywhere with that setup?
Wepeel is offline   Reply With Quote
Old 03-20-2014, 12:29 AM   #63
EN2_Squirrel
I have coilovers. you need them to fit 255's. never rubbed.
Old 03-20-2014, 12:40 AM   #64
pleong
Drives: 2013 Whiteout FR-S
where did you get those gun metal rpf1s in 18x9.5?? cant find them anywhere.
contact Bryce at Oakos he'll take care of you and hook you up
Bryce@Oakos.com
@Oakos
pleong is offline   Reply With Quote
Old 03-23-2014, 02:42 PM   #65
Squishy86
Squishy86's Avatar
Drives: Your Car
A member PM'd me and asking to see a couple more pictures of how my wheels fit and whether it tucked or not. Decided I'll post them on here to help people out. The wheels are 17x9 +35 on 245/40 Hankook v12s. I'm on Fortune Auto coils dropped about 1.75 inches. My front camber is 2.5 degrees and the rear is 2.3 degrees. Camber on the front is from the OEM camber bolt and close to max camber plates. The rear is natural. I really should learn how resize pics before posting...
That's my ride height. I would say its about a 1.75 inch drop. I'm on Fortune Auto coils.
That's my top view of the front. My camber settings in the front is 2.5 degrees. I used the oem camber bolts plus close to max on the camber plates. The top of the tire is tucked in but you can see the bottom pushing out quite a bit.
Here you can see some more of the camber and how much it pokes out.
The rear is about the same deal in height.
The clearance from tire to fender in the rear is basically the same as the front. I only have 2.3 degrees of camber and it fits very nicely without the top of the rim poking out of the fender.
The tire sticks past the mudguards on both the front and rear and it gets sort of annoying because it throws water all over my white car so I'm forever dirty.
And one more pic of dat ass. I don't think I'm on level ground for this one though.
Squishy86 is offline   Reply With Quote
Old 03-24-2014, 10:02 AM   #66
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
I'll be making a purchase soon for my 10 Series...
17x9 +35 in gunmetal with 245/40R17 on Tein S-Techs
Can anyone confirm fitment before I place the order?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 03-24-2014, 10:43 AM   #67
Steve
Steve's Avatar
Drives: 6MT
From others experiences that I have read, it will fit. The inside of the front tires will get close to the spring perch when adding negative camber to bring in the poke, as the front will poke without negative camber, but it will clear. People running +45 offset had clearance issues where they had to run front spacers to dial in more negative camber.
Steve is offline   Reply With Quote
Old 03-24-2014, 01:15 PM   #68
Silver Ignition
APEXHNTR
I don't want much negative camber, as this is my daily driver. Somewhere between 0 and -1*. I don't want to be down to the cords on the inside of my tire and have 100% tread on the outside. Maybe I'll stick with +45 and keep my wheels vertical.
I wish I could find a 17x9 +38.....
So 17x9 +45 with 245/40 and a 5mm spacer in the back in SBC is the plan I guess...
#1867 of 2500
Old 03-24-2014, 02:21 PM   #69
Steve
Steve's Avatar
Drives: 6MT
So 17x9 +45 with 245/40 in SBC is the plan I guess...
Check out this thread http://www.ft86club.com/forums/showthread.php?t=28678
Old 03-24-2014, 02:56 PM   #70
VuDism
VuDism's Avatar
stock range of camber on alignment can go as low as -.08.
im running about -1.6 to -1.7 ish camber in the front with Whiteline camber bolts with 17x9 +35 rpf1. car is lowered about 1.2".
to my eyes the wheels do not poke in the front and i'm not concerned about tire wear. Toe is what destroys the tire. Camber wear wont be bad especially if it isnt lower than -2.0 . . .
my advice is get the +35 and dial in negative camber. it will not destroy your tire... rotate your tires at oil changes or every 5k miles and you will be good to go
+45 rubs stock struts and tie rods...
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
Enkei RPF1 17x7.5 +48 5x100 SBC and wheel/tyre question Victor Draken Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-19-2013 01:28 PM
Track wheel Enkei RPF1 in 16" ?? stockysnail Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-07-2013 09:13 AM
