Old 03-25-2016, 03:23 AM   #57
notout86
Drives: GTS 86 auto
Originally Posted by johan View Post
That discussion was very helpful. Thanks for linking that. I'll be following up on both ends of that rail section. I've already had my car apart and looked down in there with much wonder as to how sound could travel down that cavity. Knowing it's actually opened to external air, I'm even more interested in sealing it and then stuffing a bunch of Thinsulate down there.
From an acoustical standpoint, sound entering from the front wheel arch would only be amplified as it bounces around in that slowly opening space. It would then travel upward towards our ears to sound like it was coming from the back wheels. Some of the sound would also be from the back - but it's just ironic that the design of the car is likely amplifying sound from both sources to make road noise far worse than it needs to be.
I have finally got around to doing something about that point of entry for tyre noise at the rear arch. I had a good look at that rubber "mud flap". It is fastened forward to the underside bodywork. It was not sealing well against the metal & I figured wind noise was getting in so I sealed along the edge with silicone rubber and also did a hole higher up around a seam where 2 metal panels join. I did both sides of the car.
The result: tyre noise reduction very little BUT the growl of the exhaust/engine note is much reduced, which surprised me. I rather liked that sound so may unplug the sound tube.
I will seal further inboard from the seam later. I will also seal in the arch where the rubber meets the plastic and up around the rim of the arch where the rubber meets it. You can poke a finger between the arch and rubber and into the hole. I have left the small hole at the lowest point as I think it wise to let any water drain. I would not put any Thinsulate in the hole as it could get wet and encourage rust/mould.
After that I will check the front arches. I can feed at least 30cm of wire towards the back of the car via the hole at the lowest point. Is it sealed off beyond that distance?
What must be happening driving in the rain??
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Old 03-26-2016, 04:15 AM   #58
notout86
Drives: GTS 86 auto
I have now sealed all around the rubber cover, leaving only a 3mm drainage hole at the lowest point.
The result is an incremental reduction in tyre roar and road rumble. Subtle but noticeable improvement. This is around town at 60kph so we hope to
notice even more improvement at higher speeds. Offsetting this is a slight higher pitched tyre or road noise that must have been there before is now revealed.
I reckon it could be dampened somehow. Maybe sealing all around the arches where the plastic meets the metal would help. It is all easy to do (especially with
the wheel off) and appreciated by my wife too.
As for the front arches I found some images that show the end of the sill beam is blanked off about 35cm in from the hole that I poked the wire in so I tried a
longer bit and it did hit a dead end.
Old 03-26-2016, 08:10 PM   #59
johan
Drives: '14 981CS, '99 NB1
I'm well past all of this on my end. I found the same as you - that the beam that runs the length of the car is baffled. With enough wrangling, I did manage to get a wire run from the front of the car, through the baffle and out to the rear quarter area. But it was such a pain, I realized there was no way I'd be getting any sound deadener down that. So what I did after sealing up the big hole at the rear, is stuff thinsulate down the different sections of the beam as far as I could.
I also laid thinsulate over the wheel arches inside the quarter panel voids, put CLD/CCF/MLV and thinsulate over the inner portions of the wheel arches (where the rear fabric covers for the trunk attach, and laid a sheet of MLV over the trunk tools, cut to the shape of the trunk tray. At highway speeds, I now get very very little sound from the rear of the car.
What is very prevalent now though, is the amount of roar I get from the front. I stuffed the front pillars on either side of the dash with thinsulate, and lined them with MLV as best I could, but that doesn't seem to have been enough. I think the only fix will be to pull the dash completely and do MLV all the way up the firewall... which totally kills me. So much work, and so much risk of messing things up.
I've also CLD/CCF/MLV'd my floor and doors (with thinsulate in the doors too), CLD'd and thinsulated the roof... pretty much went nuts. I even bought some hydrophobic melamine foam from sounddeadenershowdown and tried stuffing that in the void in the front fenders behind the fender liners. That didn't make a noticeable difference.
MLV on the firewall... sigh.
Good luck with your efforts!
johan is offline   Reply With Quote
Old 03-27-2016, 03:42 AM   #60
notout86
Drives: GTS 86 auto
Johan, See post # 39 here http://*************/forum/f16/poten...43/index4.html and read in conjunction with the text below. For the ***** substitute ************* to complete the link. It looks naff but certainly works for engine noise and must help for the amount of roar you get from the front.
In hindsight it would have simplified install if the bracing bars had been removed prior to putting the sisalation layers in place.
The layers have slits leading to holes that match various hoses or pipes. The slits of one layer are vertically down, another vertically up, one horizontal and another more or less diagonal. Thus the slits are overlayed by adjacent layers.
The shielding rests below on the transmission housing and 10cm back into the tunnel and blanks off the tunnel. It comes up behind (but not touching) the engine and curves over to rest on the black bracing bars. While driving, It may rise there to contact the bonnet but there are no flapping noises. There is plenty of room for heat to rise and no contact with exhaust below.
The shield curves around horizontally as far as possible and slightly covering the suspension damper turrets.
I tried burning sisalation. The paper backing burns but quickly extinguishes.
I have just tried revving up to the redline in second gear on smooth bitumen. At that low road speed wind and tyre noise is more or less out of the equation i.e. leaving mainly engine & transmission noise.
I am blown away by how effective this sound-shield is. Engine noise at 7000rpm is now very similar to what I hear in everyday driving around 1200rpm in top.
I love it. No longer is it a somewhat tinny car but altogether more refined and there's no loss of fun factor.
Old 03-27-2016, 03:30 PM   #61
Porcupint
Drives: 13 GBS BRZ
Use this http://bit.ly/1Sf5Qp5
Porcupint is offline   Reply With Quote
The Following User Says Thank You to Porcupint For This Useful Post:
notout86 (03-27-2016)
Old 03-27-2016, 08:09 PM   #62
notout86
Drives: GTS 86 auto
Originally Posted by Porcupint View Post
Thanks Porcupint. How did you come up with that link? I have had this problem with part of links seemingly rejected by this forum and someone else has had to come to the rescue. I will make a note of what I should be doing for later reference.
Old 03-27-2016, 08:17 PM   #63
Porcupint
Drives: 13 GBS BRZ
Just a link shortener https://bitly.com
Old 03-27-2016, 10:36 PM   #64
johan
@notout86, I saw those pictures before when reading on the other site.
I'm not a big fan of the solution if only for the aesthetic side of things. Additionally, I do intend to turbo my car soon, so heat is definitely a concern for me on anything I do. Also, I've never seen a product like that here in the states, so couldn't use it if I wanted to. I have considered pulling the cowl off and trying to put some MLV inside there. There are so many options, just depends on how committed you are.
Old 03-28-2016, 05:53 PM   #65
Norville Rogers
Drives: Subaru BRZ
Haven't read the whole post but having looked at the pictures I'm stunned by the fact that you have a sniff of body colour on the interior. On my last Z4, and the previous one that was missing from the exterior.
Norville Rogers is offline   Reply With Quote
Old 04-01-2016, 02:55 AM   #66
notout86
Drives: GTS 86 auto
"the product" is merely foil insulation as used on houses and lining the inside of a roof e.g. in a shed. It is re-inforced by a laminate of fabric or plastic between the foil layers and often colored blue on one side so it is not so glary for installers. Sisalation is a trade name for one variety. On the aesthetics side I cringe myself but my wife and I agree it has reduced engine noise quite noticeably. We have just completed a 700km trip over all sorts of roads at mainly 100kmph and along with the silicone rubber seal for the holes at the rear we are quite happy.
The main remaining noise now is a low frequency thrumming ie not a rumble.
Old 04-08-2016, 12:10 PM   #67
straggler7
Drives: BRZ dark metallic grey
Appreciate the pictures. Thank you.
straggler7 is offline   Reply With Quote
Old 06-02-2016, 09:34 AM   #68
FR-S Future Owner
Grand Touring Fan
FR-S Future Owner's Avatar
Drives: 98 2.2L Camry, 87 2.0L Camry Wgn
Thumbs up Excellent Thread!
Originally Posted by nalc View Post
It's probably not Lexus LS quiet. The real limiting factor at this point is the frameless windows. Road and engine noise are down significantly, but there's still some wind noise, and there's not much I can do about it.
I measured it around 85 dB with the app on my old phone at 65mph on the highway, and 78 dB after the sound deadening. I don't know how accurate that app is, so the numbers are probably off (I've already been challenged that there's no way the BRZ reaches 85 dB at that speed), but the 7 dB reduction is probably about accurate. Remember, it's a logarithmic scale, so 10 dB = 10 x as loud.
As a better example, I took someone for a ride who did not know that I had done any sound deadening, and he remarked that he was surprised how quiet it was. I'd certainly be up for doing an actual comparison with an accurate SPL meter, perhaps at a meet or some other event where we could compare my car to a stock car at the same speed on the same road.
As for the headliner, there is nothing securing the Thinsulate. It's just sandwiched between the headliner (which is actually quite stiff) and the roof. One nice thing about treating the headliner is that you lose the "rain drops on a tin roof" sound when it rains. Raindrops make practically no noise on the roof now.
I'll post a more detailed write up on it once I have a chance (maybe tonight), but for now the pics are available in the imgur album in the first post.
I paid about $600 for all the materials. In retrospect, my amount of CLD was a bit low (I used 45 and could likely have found room for another 5 without too much trouble), my amount of CCF was too high (I only used half of what I ordered, since there was already foam below the carpet), and my MLV and Thinsulate were right on the money.
I should also add that if you're doing any JDM interior pieces (like the kneepads or armrest), or if you're installing upgraded speakers, do them at the same time. Taking all these panels off makes those upgrades very fast and easy.
GREAT JOB!
  1. Based on your experience, how much of each of the sound deadening materials is needed for the FR-S/BRZ?
  2. About how many hours did it take to complete this job?
  3. Which supplier(s) is/are recommended for these materials?
  4. If you had it to do over again, would you? If no, which sports car might you buy instead that's significantly quieter?
Thanks!
FR-S Future Owner is offline   Reply With Quote
Old 06-12-2016, 09:22 PM   #69
nalc
Drives: 13 BRZ Limited 6MT GBS
Originally Posted by FR-S Future Owner View Post
GREAT JOB!
Thanks!
I ended up using approximately 80 sq ft of MLV (minus scraps, so probably 70 lbs into the car), 45 CLD tiles (could have used more), 25 sq ft of 3M Thinsulate Acoustic, and 4 sheets of closed cell foam.
I don't know, probably a good 30-40 hours working it alone over the course of a month or two. It wasn't a 1-day job. I had a handful of times I just did the entire afternoon working on it. Although I did drive the car during the process, so it'd be faster if you dedicated a weekend to it, because a fair amount of my time was assembly and reassembly (I'd take off a panel, work on it, then put it back together). In terms of budgeting your time, the biggest piece is the floor. I did it over a couple days so I had the seats in and out multiple times, if you could dedicate a solid day to it, I think you could bang it out, and then just do the doors separately at your convenience. Having a helper would speed things up immensely - a lot of my time was going back and forth betweeen tools, going back to measure things. if you had one person just cutting material and a person just installing it it'd go much faster. I also got the JDM interior pieces AFTER doing the sound deadening, so I had to have a lot of that taken apart a second time.
I got it all from Sound Deadener Showdown.
It's tough to say. I don't think I would be happy with the stock car 3 years later. I like everything about the new Impreza except for the vague 5-speed gearbox and anemic 148bhp engine. If they had an Impreza hatch with a BRZ gearbox and a 200hp motor I'd have been all over it. The reason I didn't go for a WRX in 2013 was the high price, crappy gas mileage, and the fact it was based on a previous generation Impreza.
That being said, every couple of months I'll drive past someone, usually a teenage boy, who shouts "Cool car, man!" at me, which I don't think you get in an Impreza.
In terms of non-Subarus, I'm too tall for a Miata and I got sick of FWD after a torque-steery, wheel-hoppy '97 Maxima, although to be honest I think I'd be pretty happy with a modern FWD sporty car with a manual gearbox. But the BRZ is cooler.
nalc is offline   Reply With Quote
The Following 2 Users Say Thank You to nalc For This Useful Post:
FR-S Future Owner (06-16-2016), Spankopotomous (12-16-2020)
Old 06-14-2016, 08:36 PM   #70
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
GREAT JOB!
Thanks!
Just wanted to say that SDS sells a complete kit now for these cars, looks like their numbers are about what the OP used.
XanRules is offline   Reply With Quote
The Following 2 Users Say Thank You to XanRules For This Useful Post:
FR-S Future Owner (06-16-2016), WryGuy (06-15-2016)
FRS/BRZ Full Interior LED Kit! Choose your brightness! See Installed Comparison Pics! Diode Dynamics Interior Parts (Incl. Lighting) 243 08-29-2018 01:01 PM
What are you using for sound deadening ? mashal Electronics | Audio | NAV | Infotainment 108 11-06-2015 01:51 PM
SOUND DEADENING White64Goat BRZ First-Gen (2012+) — General Topics 7 04-22-2013 02:36 AM
Quarter Panel Deadening - factory deadening? l0aded Electronics | Audio | NAV | Infotainment 4 03-19-2013 08:19 PM
Sound deadening yomchi1989 Electronics | Audio | NAV | Infotainment 16 01-02-2013 03:08 PM
