03-25-2016, 02:23 AM | #57 | |
Drives: GTS 86 auto
The result: tyre noise reduction very little BUT the growl of the exhaust/engine note is much reduced, which surprised me. I rather liked that sound so may unplug the sound tube. I will seal further inboard from the seam later. I will also seal in the arch where the rubber meets the plastic and up around the rim of the arch where the rubber meets it. You can poke a finger between the arch and rubber and into the hole. I have left the small hole at the lowest point as I think it wise to let any water drain. I would not put any Thinsulate in the hole as it could get wet and encourage rust/mould. After that I will check the front arches. I can feed at least 30cm of wire towards the back of the car via the hole at the lowest point. Is it sealed off beyond that distance? What must be happening driving in the rain??
GTS86 Auto (Australia)
03-26-2016, 03:15 AM | #58 |
Drives: GTS 86 auto
I have now sealed all around the rubber cover, leaving only a 3mm drainage hole at the lowest point.
The result is an incremental reduction in tyre roar and road rumble. Subtle but noticeable improvement. This is around town at 60kph so we hope to notice even more improvement at higher speeds. Offsetting this is a slight higher pitched tyre or road noise that must have been there before is now revealed. I reckon it could be dampened somehow. Maybe sealing all around the arches where the plastic meets the metal would help. It is all easy to do (especially with the wheel off) and appreciated by my wife too. As for the front arches I found some images that show the end of the sill beam is blanked off about 35cm in from the hole that I poked the wire in so I tried a longer bit and it did hit a dead end.
03-26-2016, 07:10 PM | #59 | |
Drives: '14 981CS, '99 NB1
I also laid thinsulate over the wheel arches inside the quarter panel voids, put CLD/CCF/MLV and thinsulate over the inner portions of the wheel arches (where the rear fabric covers for the trunk attach, and laid a sheet of MLV over the trunk tools, cut to the shape of the trunk tray. At highway speeds, I now get very very little sound from the rear of the car. What is very prevalent now though, is the amount of roar I get from the front. I stuffed the front pillars on either side of the dash with thinsulate, and lined them with MLV as best I could, but that doesn't seem to have been enough. I think the only fix will be to pull the dash completely and do MLV all the way up the firewall... which totally kills me. So much work, and so much risk of messing things up. I've also CLD/CCF/MLV'd my floor and doors (with thinsulate in the doors too), CLD'd and thinsulated the roof... pretty much went nuts. I even bought some hydrophobic melamine foam from sounddeadenershowdown and tried stuffing that in the void in the front fenders behind the fender liners. That didn't make a noticeable difference. MLV on the firewall... sigh. Good luck with your efforts! |
03-27-2016, 02:42 AM | #60 |
Drives: GTS 86 auto
Johan, See post # 39 here http://*************/forum/f16/poten...43/index4.html and read in conjunction with the text below. For the ***** substitute ************* to complete the link. It looks naff but certainly works for engine noise and must help for the amount of roar you get from the front.
In hindsight it would have simplified install if the bracing bars had been removed prior to putting the sisalation layers in place. The layers have slits leading to holes that match various hoses or pipes. The slits of one layer are vertically down, another vertically up, one horizontal and another more or less diagonal. Thus the slits are overlayed by adjacent layers. The shielding rests below on the transmission housing and 10cm back into the tunnel and blanks off the tunnel. It comes up behind (but not touching) the engine and curves over to rest on the black bracing bars. While driving, It may rise there to contact the bonnet but there are no flapping noises. There is plenty of room for heat to rise and no contact with exhaust below. The shield curves around horizontally as far as possible and slightly covering the suspension damper turrets. I tried burning sisalation. The paper backing burns but quickly extinguishes. I have just tried revving up to the redline in second gear on smooth bitumen. At that low road speed wind and tyre noise is more or less out of the equation i.e. leaving mainly engine & transmission noise. I am blown away by how effective this sound-shield is. Engine noise at 7000rpm is now very similar to what I hear in everyday driving around 1200rpm in top. I love it. No longer is it a somewhat tinny car but altogether more refined and there's no loss of fun factor.
03-27-2016, 02:30 PM | #61 | |
Drives: 13 GBS BRZ
Use this http://bit.ly/1Sf5Qp5 |
The Following User Says Thank You to Porcupint For This Useful Post: | notout86 (03-27-2016) |
03-27-2016, 07:09 PM | #62 | |
Drives: GTS 86 auto
03-27-2016, 07:17 PM | #63 | |
Drives: 13 GBS BRZ
03-27-2016, 09:36 PM | #64 |
@notout86, I saw those pictures before when reading on the other site.
I'm not a big fan of the solution if only for the aesthetic side of things. Additionally, I do intend to turbo my car soon, so heat is definitely a concern for me on anything I do. Also, I've never seen a product like that here in the states, so couldn't use it if I wanted to. I have considered pulling the cowl off and trying to put some MLV inside there. There are so many options, just depends on how committed you are. |
03-28-2016, 04:53 PM | #65 |
Drives: Subaru BRZ
Haven't read the whole post but having looked at the pictures I'm stunned by the fact that you have a sniff of body colour on the interior. On my last Z4, and the previous one that was missing from the exterior.
04-01-2016, 01:55 AM | #66 | |
Drives: GTS 86 auto
The main remaining noise now is a low frequency thrumming ie not a rumble.
04-08-2016, 11:10 AM | #67 |
Drives: BRZ dark metallic grey
Appreciate the pictures. Thank you.
06-02-2016, 08:34 AM | #68 | |
Grand Touring Fan
Drives: 98 2.2L Camry, 87 2.0L Camry Wgn
Excellent Thread!
06-12-2016, 08:22 PM | #69 | |
Drives: 13 BRZ Limited 6MT GBS
I don't know, probably a good 30-40 hours working it alone over the course of a month or two. It wasn't a 1-day job. I had a handful of times I just did the entire afternoon working on it. Although I did drive the car during the process, so it'd be faster if you dedicated a weekend to it, because a fair amount of my time was assembly and reassembly (I'd take off a panel, work on it, then put it back together). In terms of budgeting your time, the biggest piece is the floor. I did it over a couple days so I had the seats in and out multiple times, if you could dedicate a solid day to it, I think you could bang it out, and then just do the doors separately at your convenience. Having a helper would speed things up immensely - a lot of my time was going back and forth betweeen tools, going back to measure things. if you had one person just cutting material and a person just installing it it'd go much faster. I also got the JDM interior pieces AFTER doing the sound deadening, so I had to have a lot of that taken apart a second time. I got it all from Sound Deadener Showdown. It's tough to say. I don't think I would be happy with the stock car 3 years later. I like everything about the new Impreza except for the vague 5-speed gearbox and anemic 148bhp engine. If they had an Impreza hatch with a BRZ gearbox and a 200hp motor I'd have been all over it. The reason I didn't go for a WRX in 2013 was the high price, crappy gas mileage, and the fact it was based on a previous generation Impreza. That being said, every couple of months I'll drive past someone, usually a teenage boy, who shouts "Cool car, man!" at me, which I don't think you get in an Impreza. In terms of non-Subarus, I'm too tall for a Miata and I got sick of FWD after a torque-steery, wheel-hoppy '97 Maxima, although to be honest I think I'd be pretty happy with a modern FWD sporty car with a manual gearbox. But the BRZ is cooler.
The Following 2 Users Say Thank You to nalc For This Useful Post: | FR-S Future Owner (06-16-2016), Spankopotomous (12-16-2020) |
06-14-2016, 07:36 PM | #70 | |
A Very Powerful Wizard
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
The Following 2 Users Say Thank You to XanRules For This Useful Post: | FR-S Future Owner (06-16-2016), WryGuy (06-15-2016) |
Similar Threads | ||||
FRS/BRZ Full Interior LED Kit! Choose your brightness! See Installed Comparison Pics! | Diode Dynamics | Interior Parts (Incl. Lighting) | 243 | 08-29-2018 12:01 PM |
What are you using for sound deadening ? | mashal | Electronics | Audio | NAV | Infotainment | 108 | 11-06-2015 12:51 PM |
SOUND DEADENING | White64Goat | BRZ First-Gen (2012+) -- General Topics | 7 | 04-22-2013 01:36 AM |
Quarter Panel Deadening - factory deadening? | l0aded | Electronics | Audio | NAV | Infotainment | 4 | 03-19-2013 07:19 PM |
Sound deadening | yomchi1989 | Electronics | Audio | NAV | Infotainment | 16 | 01-02-2013 02:08 PM |
