#57 |
Drives: 2017 BRZ Yellow Spec Ed 1of500
Rattle Recently started in Neutral while in Idle
Rattle Recently started in Neutral while in Idle on my 2017 BRZ, but I just installed a Complete ACT HD Clutch kit with the new OEM TOB with the new grease that does not dry out and burn up and a Perrin Transmission support block and a Perrin Fork. My idle goes down to 800 and it's there. I'm removing the Perrin Block (which lets you hear every gear shift in the cabin) and having my tuner (James Martin) correct my idle. The ACT HD clutch has a light weight fly wheel and I knew there was probably going to be some chatter, especially for the first 1000 miles. I am sure that nothing is lose in the clutch Will see if this makes it go away. |
#58 |
Any updates on this? Mine started doing the same...
I noticed that many people with this issue have Motul oil... |
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| Cold start up popping noise | Weeber | Issues | Warranty | Recalls / TSB | 51 | 09-23-2016 12:54 PM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 06:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
| MT, neutral 15-10mph slowing, ratcheting noise | bcj | Engine, Exhaust, Transmission | 7 | 04-18-2013 12:33 AM |
