#57 |
I think James is on the right track with "fixing" it... the knock doesn't seem to be detrimental down low, except to the IAM so removing the advance so it doesn't hurt the IAM is a good enough solution for me. It doesn't happen very often for me, so I'm not too concerned about it.
#58 | |
Drives: STi
Sent from my SM-N9005 using Tapatalk |
#59 | |
#60 | |
![]() Do you mean total advance? I also found this which says coarse correction is enabled when advance is above 0.
Last edited by s2d4; 03-11-2014 at 09:18 AM. Reason: Edited with further findings and additional question. |
#61 | |
![]() Revving from idle behaves differently because you're going from an idle state (injectors on) instead of a deceleration state (injectors off). It doesn't happen all the time, but it has definitely happened more often than I would like.
#62 |
yes it does. i mean the currently applied value from the advance map. bad noodle's doc suggests 3.9 degrees as the value, which my own testing seems to confirm. it's likely that map definition is wrong or isn't scaled properly or something, as a value of 1 or 2 degrees will definitely disable coarse correction. this is really easy to test, just go induce some tip-in knock with it normal and watch it drop, then reflash with lower advance values (but same total timing) and watch it stay put. works every time lol.
#63 | |
#64 |
Modified advance table
I
Below is modified advance table I am using to reduce knock. Has not completely eliminated it in 1500-3000 PRM range but is less frequent and less severe and now does not result in IAM dropping below 1, when driving in that range in traffic for long periods. However I am using 100 octane fuel. Will try it out on 98 once tank is run down. |
| The Following User Says Thank You to steve99 For This Useful Post: | Ralph Spoilsport (03-11-2014) |
#65 | |
#66 | |
AFAIK yes 98 RON 93 AKI 100 94 95 91 91 87 However I believe the "test" procedure is different for the different ratings so its not an exact equivalence . It does appear that our 98 RON is not quite as good as your 93 AKI for real world knock resistance. |
#67 |
octane shouldn't make any difference to the tip-in knock. i get it even on e85, just the same as on pump gas (which led to my pekc theory that i've yet to prove lol).
#68 | |
If thats the case I will be happy as it should be reduced on 98RON as well. What is the cause of tip in knock , Fueling error ?? Last edited by steve99; 03-11-2014 at 02:53 PM. |
#69 |
Drives: Attitude
#70 |
that's the million $ question... i can say what makes it worse (too much advance in low load areas, bad tip-in tuning), but i can't say what is causing it because i haven't been able to completely eliminate it 100%.
| The Following User Says Thank You to jamesm For This Useful Post: | steve99 (03-11-2014) |
| BC Racing Coilovers - Knock? | 636 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 12-09-2015 11:41 PM |
| FR-S Rod knock | pozer | Issues | Warranty | Recalls / TSB | 95 | 11-03-2015 10:39 AM |
| ca-fi knock off questions | fionnsfrs | Electronics | Audio | NAV | Infotainment | 2 | 10-27-2013 02:47 PM |
| Knock on e85 not a problem? | gdrider77 | Forced Induction | 76 | 10-21-2013 12:36 AM |
| Would you rather buy knock off parts for your car? | EJ20 | Engine, Exhaust, Transmission | 63 | 11-02-2011 07:17 PM |
