Old 12-15-2013, 03:01 AM   #57
gmsii
gmsii's Avatar
Digital Assassin...the oil reservoir in the original KW location is fine...Rotrex is concerned that too high of position will cause the front seal to leak due to high static hydraulic pressure; their generalized instruction to mount the reservoir lower than the charger guarantees that the seal will not see high enough static hydraulic pressures to cause leakage. The reservoir even or slightly higher than the charger with the line running lower (as is the case with the KW kit) is fine.
gmsii is offline   Reply With Quote
Old 12-16-2013, 12:07 PM   #58
dren
Originally Posted by digital_assassin View Post
Added you to the owners list @dren. Can't wait to see your results!
Thanks! I'm still waiting on the EcuTek to ship. Once that does, I'll tear into her.
dren is offline   Reply With Quote
Old 12-19-2013, 01:29 AM   #59
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
@gmsii
How long before the toothed idlers come out? Only - I read or hear about is noise levels and I'm very curious is those bits being toothed will basically solve that or not. I'm abit of a nancy pants with additional noises so this is a concern for me.
Old 12-19-2013, 07:51 AM   #60
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Received my kit the day before last... smooth idler pulleys. So, the toothed idlers have not come down the pipeline just yet.
cobrabyte is offline   Reply With Quote
Old 12-20-2013, 01:47 AM   #61
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Next tip guys.
The cold side piping that runs behind the passenger headlight needs to be checked after installing the headlights. I was hearing a bit of rattling and chased it down tonight and discovered when I reinstalled the headlights I had sandwiched the IC tube in between the headlight and the attachment point of the front crash bar and if left unattended would have wore a hole in the IC pipe.
After reinstallation of the headlights check this side and make sure you still have clearance. Now that I loosened things up and moved them the issue is solved. Not a problem with the kit just something to be aware of when aligning things.
digital_assassin is offline   Reply With Quote
Old 12-26-2013, 01:23 PM   #62
digital_assassin
Anybody else get their kit installed yet or am I still the only one getting to enjoy this thing so far?
Old 12-26-2013, 04:32 PM   #63
cobrabyte
cobrabyte's Avatar
Waiting on belt cover, replacement anodized parts, injectors, fuel pump and some other bits. Can't come soon enough!
Old 12-26-2013, 05:08 PM   #64
digital_assassin
Which injectors and fuel pump did you go with? I think we were about hitting the limits of the stock setup so this may open up some more potential in the tuning for you. Colder spark plugs should help too.
Old 12-26-2013, 05:42 PM   #65
Next tip guys.
Try using rubber pads with adhesive backing for tight fits like this. It'll eliminate any rattling/vibrating, and absorb the wear.
The "other" kit includes a bunch of these pads for the exact same reason.
Old 12-26-2013, 05:45 PM   #66
cobrabyte
cobrabyte's Avatar
I went with Full Blown's 270lph pump. It's a 65mm pump so it's a direct fit pump. I'm also going with 540cc Fuel Injector Clinic injectors. I'm running ethanol, so definitely need the headroom.
May as well change out the spark plugs at the same time... good call.
Old 12-26-2013, 06:50 PM   #67
digital_assassin
This is the only spot were metal to metal was a possibility and once I realigned the pipe there is tons of room around it. The only rattle issue I have is the filter cone is vibrating on my APR bumper but that is probably due to a slightly modified shape to the front end.
Old 12-26-2013, 07:38 PM   #68
Ah, gotcha.
I used the rubber liner on every spot where the fitment was tight. Doesn't hurt, since I HATE rattles and funky noises.
Old 12-27-2013, 01:45 AM   #69
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
When I saw that the oil for the SC was $100 I sprayed coffee all over my phone. Now I'm typing from my laptop.
Good LAWD that stuff is outrageously priced! Must be made of Unicorn piss or something.
Coheed is offline   Reply With Quote
Old 12-27-2013, 09:26 AM   #70
grostoine
Drives: Subaru BRZ
You have to change it every 80 k miles or two years. Its not THAT bad
grostoine is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
