Old 03-05-2012, 04:01 PM   #57
OrbitalEllipses
Drives: Attitude
Originally Posted by carbonBLUE View Post
i have 140 lb-ft in my car and it pulls just as hard as my friends mustang and hes got 240 lb-ft , hes got 100 more lb-ft and more hp but is slower than me 0-60 and 0-120 60-120 doesnt matter
the weight difference between my car and his is 800lbs that does mean a lot, 151 should be more than enough to make the car fun,
And a Celica GTS should weight approximately 200-300lbs less than this car with just under 10% less peak torque. 151 lb-ft is laughable, admit it.
Old 03-05-2012, 04:29 PM   #58
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
When my car was stock I still beat him, then I had 129lb-ft , gearing is about the same plus the 86 has a much broader powerband than my car...
It is low for a car but good for a 4 banger...
If you don't like the car, why are you here?
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 03-05-2012, 04:41 PM   #59
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Let's put some perspective on this:
The Honda S2000 made 153 and the SUPERCHARGED Lotus Elise made 157.
Old 03-05-2012, 04:45 PM   #60
serialk11r
Drives: '06 AM V8V Coupe
This talk of torque to weight ratio makes me sick, shut up already! :P
Old 03-05-2012, 04:46 PM   #61
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
if it's laughable why are you still here and why are you still a sucker for this car? what's truly laughable is subaru was just gonna stick the fb20 in there as is until tada insisted on something more powerful, which led to the fa20 being built from scratch.
cyde01 is offline   Reply With Quote
Old 03-05-2012, 04:56 PM   #62
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by MrBonus View Post
Why? Where do you "need" that additional horsepower?
Its funny you say that yet you own a 2012 Boss. I think 444hp is way too much for the streets and you could've gone with a 305 hp v6 with the sport package. To me your post seems like a contradiction.
SUB-FT86 is offline   Reply With Quote
Old 03-05-2012, 05:03 PM   #63
SUB-FT86
86 Member
I actually own a car with 140tq and I will be the first to say it's weak. The torque is rich in the torque band of my RSX base but it still feels weak when it's hauling 2790 lbs+.
Old 03-05-2012, 05:13 PM   #64
spin9k
spin9k's Avatar
Drives: RX-8
This car will be fine on track, regardless of the low torque number. The place where it will fall down is 4th gear and up acceleration and resultant top speed. It will be similar to my RX-8... superb on track, esp. tight tracks, or long tracks without much in the way of straights. But anywhere where higher HP cars can stretch their legs, they'll easily show their strength ... outright acceleration at speed ... and you'll be left in the dust. Power rules because drag increase as the cube of speed. 200HP just doesn't go that far countering drag forces. Take these two easy examples....
Say, for the FRS/BRZ if 3HP is needed at 30mph, then 24HP is required at 60mph, but 192HP is needed at 120mph. It's pretty much finished accelerating.
vs. let's take a 350HP Mustang
if 4HP is needed at 30mph, then 32HP is required at 60mph, but only 256HP is needed at 120mph. There's more HP left and it will contiune to accelerate just fine.
Long story short, this car will rock on the twisties, you'll be crying on the long straights.
spin9k is offline   Reply With Quote
Old 03-05-2012, 05:32 PM   #65
cyde01
cyde01's Avatar
the problem with cars that have weak low and mid range is a matter of torque curve more than peak torque numbers. the peak number doesn't really tell the story. from the dynos we've seen, the new 86 has a very flat torque curve, a very good indication. at least drive it for yourself before you knock it.
Old 03-05-2012, 05:43 PM   #66
SUB-FT86
86 Member
Its not that flat. It actually dips in one of the most important parts of the power band, the mid range. Between 3k-5k rpms there is a nasty dip in torque.
Old 03-05-2012, 05:44 PM   #67
serialk11r
For you, I'd think that the bigger problem would be the very fast drop off in torque below 3000rpm...it will probably feel slower than your RSX there if I remember how the RSX is geared correctly... the dip in the middle isn't that big.
That's the price of high revs, fixed cam profile. I'm happy about it, because the mpgs should be better :P
Old 03-05-2012, 05:49 PM   #68
SUB-FT86
86 Member
I know what you mean Serial but I like mid range torque better than low range torque or high range torque. Most of the times when I drive I shift before 4500 rpms
Old 03-05-2012, 05:55 PM   #69
cyde01
cyde01's Avatar
lol yeah i've seen the curve. the dip is not big. i doubt you'd even notice the dip when you're actually driving the car. 150 lb/ft at 3000rpm is pretty dang good if you ask me.
Old 03-05-2012, 06:01 PM   #70
carbonBLUE
Reverse Burnouts
lol you know you need about 9-15 hp to go 60mph depending on your drag ratio
EDIT: plus overcoming rolling resitance, forgot about that :P so its anywhere between 19-24 hp but not 32 hp and you dont need 192 hp at 120mph its about 120hp...
these are the calculations for a 6 series with a .29 CG, remember the 86 has a lower .27 CG weighs less and is a smaller car, has skinnier tires and less rolling resistance....
Speed/ Power at the wheels/ Power at the engine
35 mph 8 hp 9 hp
60 mph 20 hp 23 hp
80 mph 38 hp 44 hp
100 mph 64 hp 75 hp
120 mph 102 hp 119 hp
140 mph 152 hp 178 hp
160 mph 220 hp 257 hp
180 mph 304 hp 356 hp
200 mph 409 hp 479 hp
220 mph 537 hp 628 hp
250 mph 776 hp 908 hp
(wont forget you)
2011 Infiniti G37x
Question jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 9 10-23-2020 11:31 AM
Question about the nomenclature.. RadOnc Scion FR-S / Toyota 86 GT86 General Forum 46 12-14-2013 11:55 PM
Stupid Question Canibuz Engine, Exhaust, Transmission 24 03-05-2012 09:50 AM
Engine Question alex05 Engine, Exhaust, Transmission 4 02-21-2012 06:08 AM
