#57 | ||
Keep calm and drive on
Drives: 2013 WRB BRZ Limited 6M
#58 | |
Drives: Skoda Yeti DSG diesel 4x4
The problem with mine is real and I searched the forum for similar problems to see how common it might be. Now it's there I avoid it but also check to see if it's still there and if it's got worse. |
#59 | |
Just gotta learn how to work around these issues. Don't beat on it while it's cold and make sure to rev match downshifts.
#60 | |
I agree but we shouldn't need to rev match anywhere these days, especially in the high gears. I do it in the lower gears for fun and to keep those hard working triple synchros like new. |
#61 |
Synchros are there so you don't HAVE to rev match, but it is a good idea to keep them healthy.
#62 |
That guy
Drives: Ultramarine mt FR-S
It happens for me when i downshift 6>5 above 3500 rpm every time now. When i took it in they said there's no issue despite the metal shavings on the drain plug and my sparkly oil.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#63 |
Drives: 2007 Impreza, 2013 BRZ
sounds like a gear cut issue on the synchros. Hence the large amount of metal shavings in some of your oil. The dust is normal, and is the coating on the synchros and gears fresh from the factory. That is why the fluid should be changed at 1000 miles after the break in period. Oil, trans, diff. All changed at 1k. =)
#64 | |
Make love
Drives: H8R.. Not really
5th Gear Grind at Freeway Speeds?
Edit: I'm waiting for it to break, so I can rebuild stronger or replace with diff unit. At this point, I'm so heavily modified that warranty work requests would be comical at best. Last edited by tech4pdx; 09-30-2013 at 06:39 PM. |
#65 |
Drives: SWP BRZ
I don't have 5th problem yet and hope not.
It's quite funny that every car forums i visit, there is Gear Grind problem thread. |
#66 |
That guy
[ame="http://www.youtube.com/watch?v=dHtRnOXXZ0w"]http://www.youtube.com/watch?v=dHtRnOXXZ0w[/ame]
Ultramarine mt FR-S
| The Following 2 Users Say Thank You to Hawaiian For This Useful Post: | tech4pdx (09-30-2013), zc06_kisstherain (09-30-2013) |
#68 |
Thanks
Was that car overheating after 2 laps?
#69 |
Drives: car
sorry I deleted the post with the video, here it is again
[ame="http://www.youtube.com/watch?v=QLjVPGJKNm4"]AUTO FACTORY 86 ExhaustテストinFSW - YouTube[/ame] 5th gear gets clicky after 5:40 after he grinds it hard around 2:15 |
#70 |
Thanks
| 3rd-4th gear grind...but only near redline | hushypushy | Engine, Exhaust, Transmission | 89 | 06-03-2016 10:39 PM |
| Steering grind | Kregar | Issues | Warranty | Recalls / TSB | 19 | 08-11-2014 03:47 PM |
| High pitch sound at freeway speeds | l0aded | Issues | Warranty | Recalls / TSB | 7 | 06-14-2013 06:25 AM |
| RPM at Highway Speeds | sparis45 | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 05-26-2013 03:41 PM |
| 3rd gear grind | Mo707 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 07-29-2012 08:37 PM |
