Old 09-29-2013, 09:44 PM   #57
TheseColorsDontRun
Keep calm and drive on
TheseColorsDontRun's Avatar
Drives: 2013 WRB BRZ Limited 6M
Originally Posted by sierra View Post
That sounds the same and perhaps because i'm aware of it and looking for it now it seems worse?
The problem with this area of the forum is everyone turns into a car hypochondriac. A problem is described and you think you may have felt it once before and you're all like "omg I have that!"
5th is the direct drive 1:1 ratio so perhaps that has something to do with it?
Doubtful.
TheseColorsDontRun is offline   Reply With Quote
Old 09-29-2013, 09:48 PM   #58
sierra
Drives: Skoda Yeti DSG diesel 4x4
True!
The problem with mine is real and I searched the forum for similar problems to see how common it might be.
Now it's there I avoid it but also check to see if it's still there and if it's got worse.
sierra is offline   Reply With Quote
Old 09-29-2013, 09:53 PM   #59
TheseColorsDontRun
True!
Not discounting your issue at all. I'm talking about those who come here and read these threads and then one morning have a grind going into second while the tranny is cold and think "zomg I need a new transmission!"
Just gotta learn how to work around these issues. Don't beat on it while it's cold and make sure to rev match downshifts.
Old 09-29-2013, 10:04 PM   #60
sierra
Yes I knew what you meant, just clarifying it for others.
I agree but we shouldn't need to rev match anywhere these days, especially in the high gears. I do it in the lower gears for fun and to keep those hard working triple synchros like new.
Old 09-29-2013, 10:19 PM   #61
TheseColorsDontRun
Synchros are there so you don't HAVE to rev match, but it is a good idea to keep them healthy.
Old 09-30-2013, 01:29 AM   #62
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
It happens for me when i downshift 6>5 above 3500 rpm every time now. When i took it in they said there's no issue despite the metal shavings on the drain plug and my sparkly oil.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 09-30-2013, 01:57 AM   #63
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
sounds like a gear cut issue on the synchros. Hence the large amount of metal shavings in some of your oil. The dust is normal, and is the coating on the synchros and gears fresh from the factory. That is why the fluid should be changed at 1000 miles after the break in period. Oil, trans, diff. All changed at 1k. =)
boxer 2.5 is offline   Reply With Quote
Old 09-30-2013, 03:22 PM   #64
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
5th Gear Grind at Freeway Speeds?
I have that same problem with the 6-5
Edit: I'm waiting for it to break, so I can rebuild stronger or replace with diff unit. At this point, I'm so heavily modified that warranty work requests would be comical at best.
tech4pdx is offline   Reply With Quote
Old 09-30-2013, 03:39 PM   #65
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I don't have 5th problem yet and hope not.
It's quite funny that every car forums i visit, there is Gear Grind problem thread.
Old 09-30-2013, 04:19 PM   #66
Hawaiian
That guy
Hawaiian's Avatar
[ame="http://www.youtube.com/watch?v=dHtRnOXXZ0w"]http://www.youtube.com/watch?v=dHtRnOXXZ0w[/ame]
Ultramarine mt FR-S
P&L stage 1 turbo
The Following 2 Users Say Thank You to Hawaiian For This Useful Post:
tech4pdx (09-30-2013), zc06_kisstherain (09-30-2013)
Old 09-30-2013, 05:02 PM   #67
zc06_kisstherain
Drives: SWP BRZ
Old 10-05-2013, 11:29 AM   #68
ZionsWrath
Thanks
ZionsWrath's Avatar
Was that car overheating after 2 laps?
Old 10-05-2013, 11:37 AM   #69
radroach
Drives: car
sorry I deleted the post with the video, here it is again
[ame="http://www.youtube.com/watch?v=QLjVPGJKNm4"]AUTO FACTORY 86 ExhaustテストinFSW - YouTube[/ame]
5th gear gets clicky after 5:40 after he grinds it hard around 2:15
Old 10-05-2013, 11:49 AM   #70
ZionsWrath
Thanks
ZionsWrath's Avatar
That sounded like he tried to enter the gate without the full depressing the clutch.
3rd-4th gear grind...but only near redline hushypushy Engine, Exhaust, Transmission 89 06-03-2016 09:39 PM
Steering grind Kregar Issues | Warranty | Recalls / TSB 19 08-11-2014 02:47 PM
High pitch sound at freeway speeds l0aded Issues | Warranty | Recalls / TSB 7 06-14-2013 05:25 AM
RPM at Highway Speeds sparis45 Scion FR-S / Toyota 86 GT86 General Forum 21 05-26-2013 02:41 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
