Old 11-25-2013, 01:14 PM   #57
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Originally Posted by RallySport Direct View Post
That looks great! And I never use the analog speedo, so a gauge in that position would be perfect for me.... hmm I really like this.
Good job and thanks for posting this up!
Rick
Yeah my thougts exactly. I can block of that speedo, its basically useless. In fact, the 60mph mark lies so low in the speedo that it seems you are going slower! I'll post pics once the gauge gets here.
Pablitomarrero is offline   Reply With Quote
Old 11-25-2013, 03:01 PM   #58
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Yes please do, I am excited to see how it looks when it is all done
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
The Following User Says Thank You to RallySport Direct For This Useful Post:
Pablitomarrero (11-25-2013)
Old 12-04-2013, 03:04 PM   #59
Pablitomarrero
Thanks,
Rick
There she is Rick @RallySport Direct . Not wired in yet though. I love how it looks and is barley noticeble from outside... Which i love.
The Following User Says Thank You to Pablitomarrero For This Useful Post:
RallySport Direct (12-04-2013)
Old 12-04-2013, 05:47 PM   #60
RallySport Direct
Attachment 59100
Attachment 59101
That looks amazing!! Thanks for posting it up
Rick
Old 01-21-2014, 12:47 AM   #61
Sniper2606
Sniper2606's Avatar
Rick
N00b question over here.
Where did you guys cut/tap in for the vacuum on the vortech sc??
A pic would be greatly appreciate it
thanks!!
Sniper2606 is offline   Reply With Quote
Old 01-21-2014, 02:13 AM   #62
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
What type of gauge are you wanting to use?
Electric or mechanical
Ryan86 is offline   Reply With Quote
Old 01-21-2014, 02:47 AM   #63
Sniper2606
Sniper2606's Avatar
Electrical
Old 01-21-2014, 03:28 AM   #64
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Yeah, I would always recommend a boost gauge with any form of forced induction. Always a good idea to know how much boost you are running at any given time
Thanks,
Rick
I guess theirs no point of me having one since I'm thinking of keeping my car NA.
They look sick though!
Carlitoz3 is offline   Reply With Quote
Old 01-21-2014, 02:42 PM   #65
RallySport Direct
thanks!!
We used the brake booster hose with a step down fitting pre check-valve. This picture may not be for the boost reference line specifically, I think it's for the BPV, but you get the idea
Thanks,
Rick
Sniper2606 (01-21-2014)
Old 10-29-2014, 08:14 AM   #66
Adstanley84
Drives: 2013 BRZ Premium
Manual Needed
Originally Posted by ft_sjo View Post
It looks as if only the front silver trim ring is universal, but the housing and inside section come as a unique pair:
Anyone know how I can find the manual this image was from?
I popped my dash vents out (the ones on the top of the dash right below the tweeters) thinking I might Plasti Dip them and then decided not to. WELL.... they don't go in as easy as they come out or at least mine didn't and I might have gotten a little frustrated and I might have gotten a little to rough with them.... and then I might have realized I was trying to put the Left and Right sides in the opposite places which didn't help my frustration at myself. So long story short I need to replace one and this looks like it has the part number and I don't trust the dealer to look up what kind of oil my car takes so this is a lost cause for them.
Adstanley84 is offline   Reply With Quote
Old 10-29-2014, 07:50 PM   #67
vividracing
vividracing's Avatar
Great write-up guys!
vividracing is offline   Reply With Quote
Old 03-23-2016, 01:48 PM   #68
Irace86
Drives: BRZ + Ducati M796
I test fit the ATi ring and gauge in the pod just to make sure everything sat correctly and looked good. Everything was perfect, so I removed the ATi ring so I could prepare the Defi 60mm gauge to sit in the pod.
Thanks,
Rick
Does the supplied Defi black bezel still fit, and perhaps you chose to go without it, or does this ac adapter interfere with it fitting?
Irace86 is offline   Reply With Quote
Old 03-25-2016, 11:33 PM   #69
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
I just installed my ATI pod a couple weeks ago. You're basically just friction fitting the gauge in place, so if the bezel needs more clearance, you just pull the gauge out a bit, fit the bezel in place, then push the gauge back in.
I don't care for how the wiring was run... I found it a better idea to punch a hole in the vent housing instead, just in case you ever want to go back to stock vent it's easier to replace and probably cheaper.
Luftwaffel is offline   Reply With Quote
Old 03-26-2016, 12:29 AM   #70
Irace86
Thanks for the info and the advice. I'll consider both.
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 10:36 PM
FS [BNE] - Pivot DXW-R air vent gauge, Cusco catch can and Team Voodoo gear knob Nardi330 Australia Classifieds 3 04-22-2016 09:24 AM
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
How-to: Install JPM Coachworks Stitched Alcantara Gauge Cluster Hood JPM Coachworks DIY (Do-It-Yourself) Guides 109 05-01-2015 01:19 PM
DCW Single Gauge Pod - 52/60mm gauges - In stock USA No Limit Motorsport Interior Parts (Incl. Lighting) 17 06-27-2013 04:20 PM
