| DIY (Do-It-Yourself) Guides For all DIYs. |
#57 | |
Drives: FR-S 10 series
#58 | |
Drives: 2014 Widebody Cosworth FR-S
![]() Thanks, Rick |
#59 | |
There she is Rick @RallySport Direct . Not wired in yet though. I love how it looks and is barley noticeble from outside... Which i love. Sent from my iPhone using Tapatalk |
#60 | |
![]() Rick |
#61 |
#62 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
What type of gauge are you wanting to use?
Electric or mechanical |
#63 |
#64 | |
Drives: 2013 MT Asphalt FRS
They look sick though! |
#65 | |
![]() ![]() Thanks, Rick |
#66 | |
Drives: 2013 BRZ Premium
Manual Needed
I popped my dash vents out (the ones on the top of the dash right below the tweeters) thinking I might Plasti Dip them and then decided not to. WELL.... they don't go in as easy as they come out or at least mine didn't and I might have gotten a little frustrated and I might have gotten a little to rough with them.... and then I might have realized I was trying to put the Left and Right sides in the opposite places which didn't help my frustration at myself. So long story short I need to replace one and this looks like it has the part number and I don't trust the dealer to look up what kind of oil my car takes so this is a lost cause for them. |
#67 |
Great write-up guys!
#68 |
Drives: BRZ + Ducati M796
Does the supplied Defi black bezel still fit, and perhaps you chose to go without it, or does this ac adapter interfere with it fitting?
#69 | |
Boost Creep
Drives: 2016 HyperBlue BRZ
I don't care for how the wiring was run... I found it a better idea to punch a hole in the vent housing instead, just in case you ever want to go back to stock vent it's easier to replace and probably cheaper. |
#70 | |
| Gauge install, dash cluster light cable, Tach RPM cable help... | Sportsguy83 | Electronics | Audio | NAV | Infotainment | 99 | 08-07-2016 10:36 PM |
| FS [BNE] - Pivot DXW-R air vent gauge, Cusco catch can and Team Voodoo gear knob | Nardi330 | Australia Classifieds | 3 | 04-22-2016 09:24 AM |
| DIY - Defi 60mm Boost Gauge Install in AC Vent | msile | DIY (Do-It-Yourself) Guides | 55 | 02-27-2016 01:10 PM |
| How-to: Install JPM Coachworks Stitched Alcantara Gauge Cluster Hood | JPM Coachworks | DIY (Do-It-Yourself) Guides | 109 | 05-01-2015 01:19 PM |
| DCW Single Gauge Pod - 52/60mm gauges - In stock USA | No Limit Motorsport | Interior Parts (Incl. Lighting) | 17 | 06-27-2013 04:20 PM |
