Old 05-29-2013, 01:10 AM   #57
Kayzer Soze
Drives: 2013 BRZ 6MT Satin White Pearl
ill take a ton of pics wednesday when i finish it all up :-)
Kayzer Soze is offline   Reply With Quote
Old 05-30-2013, 10:11 AM   #58
Kayzer Soze
So after 8 hours, almost done. im definitely slower than a professional, but am really happy i was able to use what ive learned from my cousin in past installs and do this on my own. Got someone to make me spacers for door speakers out of wood. ran wire from door to inside via grommet on passenger side (slit in tube and vaseline did the trick). Where i lost an hour was on driver door, seemed to be harder to pass wire so ended up just slitting both grommets and passing wire through there.
Attached the door speakers and amp to crossovers, and finished up all the wiring. I didnt have time to take too many pics, but here are a few i got...ill take more when all is done. was a nice feeling this morning when i plugged amp for first time when i woke up, and sound came out of the door speakers (i didnt plug subs or tweets yet, thats all i have left to do then the adjustments). my biggest worry was that i tapped the wrong wire for the remote wire, but ends up i didnt have a blue with white line, so i tapped the blue wire behind the radio and that was correct)
Old 05-30-2013, 10:44 AM   #59
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
Looking good... but may I suggest that you spray those MDF rings with about 5 coats of bedliner because they will swell from water entering the doors.
Sent from my SPH-L710 using Tapatalk 2
Sbeezy is offline   Reply With Quote
Old 05-30-2013, 11:06 AM   #60
Kayzer Soze
i was thinking of doing that, but the guy who did them said it wasnt necessary since the speakers would prolly get ruined before the ply wood swelled (if that much water managed to get in)
ill have to fully sound deaden door in a couple weeks when i get more, so ill take advantage and coat rings then! thanks for the tip
Old 05-30-2013, 01:19 PM   #61
cruzinbill
Drives: Argento 6spd FR-S
Agreed atleast put a couple coats of spraypaint on them. Humidity alone will affect raw wood. Everytime you roll a wet window down it introduces moisture. Not enough to hurt the speaker as its treated for it, but raw wood is not.
Looks great tho, definitely finish deadning your doors as you have planned. Take the extra time to unscrew all the pieces off the door plastic and deaden between them. Makes a large improvement.
Also, you may have to trim back the plastic speaker ring in the door panel if you are experiencing buzzing once done deadning.
cruzinbill is offline   Reply With Quote
Old 05-30-2013, 03:56 PM   #62
Kayzer Soze
cant wait to go finish the job after work in an hour.... question, with the v9 and two 8s, should i wire in series or parallel? from what i see, the amp can handle both options
Old 05-30-2013, 04:09 PM   #63
Sbeezy
Go parallel... even though the amp doesn't care
Old 05-30-2013, 04:17 PM   #64
Sbeezy
But remember the lower the impedance the harder it is on the amp and electrical system. I've been told by Steven mantz its better to run the amp at higher impedances ie 4ohm for best efficiency and sq purposes. but since a sub is there and you are only covering 1.5 octaves at most you should be ok .
Old 05-31-2013, 01:26 AM   #65
HotSauce
Drives: 2013 Scion Fr-s Firestorm
Originally Posted by Kayzer Soze View Post
here are some pics.... all prep work for tomorrow when i pick up the box and spacers. ran wires, sound deadened trunk hatch and prepared location for amp (had to cut off the screw that the stock amp use to bolt to car)
Looks almost identical to my setup, I just finished mine and it sounds AWESOME. The V9 will not disappoint! and even under the carpet in the stock amp location mine is warm to the touch not hot by any means. Let us know hows yours works out.
HotSauce is offline   Reply With Quote
Old 05-31-2013, 10:43 AM   #66
wheelhaus
wheelhaus's Avatar
I have two 4ohm subs in parallel (i.e. 2ohm) and the V9 is fine. I've also come to understand too low impedance can hinder SQ due to how it lowers the amp's damping factor (how much control it has over the output). However, as sbeezy mentioned, subs cover such a small freq range that any distortion or inaccuracy is likely detectable with software, but not to the human ear unless the amp isn't designed to handle 2ohm loads very well.
wheelhaus is offline   Reply With Quote
Old 05-31-2013, 09:05 PM   #67
Kayzer Soze
well i just learned that i need a harness for my radio (avic 9310bt that came stock with my car) since there is only one rca out and 2 are needed.....aside from that and tuning, everything is ready, now lets see how fast i can get one of these harnesses
Old 06-03-2013, 10:36 AM   #68
djdnz
1337
Drives: 2013 BRZ WRB S/C
Can you please post where you get the harness from? It will be useful to others if they are reading the thread later.
I am very interested in your build, as it's about what I'd like to do as well (except a single 8"). Looks like the amp is a great fit back there.
djdnz is offline   Reply With Quote
Old 06-03-2013, 11:37 AM   #69
Kayzer Soze
got the harness on amazon.ca for $30. was $45+ on ebay
[ame="http://www.amazon.ca/Replacement-Assembly-Harness-Pioneer-X9310BT/dp/B0088HRFJG/ref=sr_1_1?ie=UTF8&qid=1370273766&sr=8-1&keywords=subaru+harness"]Subaru Replacement RCA Cord Assembly AV Radio Harness for Pioneer Avic X9310BT.: Amazon.ca: Electronics[/ame]
of course this is for those who have the pioneer headunit stock in the car.... (only canadian models from what i understood)
The Following User Says Thank You to Kayzer Soze For This Useful Post:
djdnz (06-04-2013)
Old 06-04-2013, 09:50 PM   #70
Kayzer Soze
got the harness a day early, and finished install....it worked perfectly as soon as i plugged the rca into the "front out" rca of the harness :-) happy i managed to do iinstall all by myself (with help of you guys on forum). here are a few pics, got tired so didnt take too many but will take more soon. and a pic of back of the avic 9310bt for anyone wondering whats back there
GaN-MaN's Custom Audio Setup + Sub/Amp Box GaN-MaN Electronics | Audio | NAV | Infotainment 23 03-26-2014 05:43 AM
Boombacloud's BRZ Audio Build...Need Help/Advice boombacloud Electronics | Audio | NAV | Infotainment 1 12-28-2012 12:35 AM
In need of advice (full setup) computertech01 Electronics | Audio | NAV | Infotainment 8 08-02-2012 06:23 PM
Any specs on the standard Audio setup? viking84 Electronics | Audio | NAV | Infotainment 72 05-30-2012 03:34 AM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 06:23 PM
