#57 |
Drives: Pavement MT GR86
Speed sensitive chime...wow that's some 80's/90's JDM shit right there....
In fact the only time I've ever heard one is in an anime lol....
GR86 MT premium
#58 |
Do you mean the seat belt chime?
Sent from my SCH-I535 using Tapatalk 2 |
#59 |
Drives: 2013 Whiteout FR-S
Saab was a big fan of this and made it standard on most of their cars haha
#60 |
Drives: Hot Lava 86 MT
No speed chime. Even my GMC Sierra does it, but the truck hits 120km.h, gives you one "ding" and that is it. My 86 hits 120km/h and it starts "ding, ding, ding" sounds like the seatbelt chime but is for speed.
Will drive you batty if you consider the legal posted speed limit between Dubai and Abu Dhabi is 140km/h....
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
#61 | |
Drives: FR-S 6MT
I'm running the US spec , so it might possibly be available on the Europe settings.. ? |
#62 |
Is it possible to change the region?
#63 |
Drives: FR-S 6MT
#64 |
Drives: Ultramarine FR-S 6MT
Can this thing re-program the throttle sensitivity? I would like it less sensitive on initial tip-in (more progressive, as in don't go from 10 to 25% open just b/c I touched the pedal) and have it speed up at the end (get closer to 100% at floored)?
#65 |
Grip>Slip
Nope, unfortunately not. If you have an ECUtek reflash your tuner MAY be able to accomodate that request.
#66 |
Thanks, I have ordered the cable already but just wanted to check. I know it is possible to remove the chime but my tuner told me he can't remove it. Hoping that this cable can...
#67 |
Ok, cable arrived and messed around last night. Can't find anything about the speed sensitivity or the speed chime/buzzer.
I need help here since I know you guys in the states do not have this problem. Not sure about Aus or South Africa or Europe for that matter. It is driving me up a wall!!!!
#68 | |
Canadian FR-S Member
Drives: FR-S '10 Series'
#69 |
i've been using techstream to collect logs after my turbo installation, and it's worked well. the response time is pretty decent without a bunch of PIDS selected, but still slower than an actual logger. very useable, though.
#70 | |
Pegasus White
Drives: 86
.Hopefully an ecu upgrade will fix it.
Driving: Pegasus White Manual GTS 86.
| Toyota Techstream | xjohnx | Engine, Exhaust, Transmission | 206 | 08-20-2023 04:01 PM |
| TechStream TIS - No work | FRSFirestorm | Engine, Exhaust, Transmission | 19 | 07-10-2014 03:14 AM |
| Techstream/ECU customizations | phanguy | Northern California | 60 | 10-05-2013 11:12 PM |
| Techstream ECU Options | mrjester | Electronics | Audio | NAV | Infotainment | 10 | 03-18-2013 10:24 AM |
| 86 TRD Customize Concept | JDMrolla | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-11-2013 12:31 PM |
