Old 03-13-2013, 12:20 AM   #57
Noob4Life
86 Noob
Drives: Firestorm FR-S
This car may be lacking a bit in the power dept but im gonna out in the reason I chose this car instead of something with more power. Potential. This car has the potential to be an all out monster. It comes from the factory lightweight and a handling monster. With a little money and can cut the weight even further and slap a turbo or SC on it. Once my FR-S goes FI (which I know im eventually going to do) it will be a beast. Ill put up with people calling it slow for now (even though its not as slow as I thought it was going to be, which says alot considering im coming from a 22psi turbod jetta) because I know that a year or so from now when ive got a stage 2 fi kit under the hood. None of those people are going to touch me on the track and a decent amount will get left behind on the drag as well. My ideas may sound a bit childish but im okay with that lol I see my 86s potential even tho alot of people only see stock tq numbers.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Noob4Life is offline   Reply With Quote
Old 03-13-2013, 12:54 AM   #58
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
doesn't anyone here know that Wikipedia is not a reliable source? althought information may be correct, it's not much better than sourcing a forum post.
I haven't done my moments calculations and all that in a couple years, but if someone drew up all the shapes and distances and did the COG calculations, the COG will change. (I didn't really read the posts above cause I'm too lazy)
Atticus808 is offline   Reply With Quote
Old 03-13-2013, 01:08 AM   #59
circuithero
Drives: 2006 Infiniti M45S
Lol @ state certification and "engineer". Right... and cute (and very wrong) use of Newton's second law. My friend you are about as much of an engineer as I am Tony Stark.
Your first posts reminded me exactly of why everyone should take everything on the internet with a grain of salt, including mine. Thanks for helping with the noise to signal ratio... For the rest of you people, don't be thrown off by arbitrary formulas thrown out by some keyboard warrior who did a quick search on google to back up his argument. As for you "wu_", go take your argument to the suspension model section, they will rip you a new one quickly.
Sure you can assume relative arbitrary points, fact is, you are lowering the entire mass (minus the unspung, which is a small portion) relative to the contact patch has immense benefits. You really think, that in this obvious case that the COG would not be different? You know damn well (well, YOU don't...) for all intents and purposes, the center of gravity would be effectively acting on the center of mass in this case. Period. Btw, COM is arbitrary and a made up point to simplify modelling and not anything physical. Why don't we just take a point of the moment of the car around earth relative to Pluto huh? Will that make sense? You think race cars are low for fun?
Not only are you reducing the moment LATERALLY but you are decreasing the available volume for air underneath the car, which aids in high speed stability by reducing the pressure delta at higher speeds (generating less lift). Why are you decreasing the moment laterally? Because the COM/height of the vehicle is analogous to the effective lever arm, which you are reducing by decreasing the height, thereby decreasing the effective force to roll the body. You think trucks roll because they are unlucky and hit pixie dust too much? Higher COM, higher moment laterally (about the x-axis as a reference point, as any REAL engineer would take it) and you have more roll. Less moment laterally = less body roll = more use of the contact patch, especially on a mcpherson strut which sees positive camber gain with body roll. Thats just the tip of the iceberg too, as there are so many variables and components that your already WRONG and SILLY arguments is moot. Stop with the BS, you are wrong on so many levels and its not even funny. Geek talk my @$$, you don't even understand principle fundamentals.
circuithero is offline   Reply With Quote
The Following User Says Thank You to circuithero For This Useful Post:
strat61caster (03-13-2013)
Old 03-13-2013, 01:14 AM   #60
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
oldpueblo is offline   Reply With Quote
The Following 2 Users Say Thank You to oldpueblo For This Useful Post:
Quentin (03-14-2013), russv (03-13-2013)
Old 03-13-2013, 02:18 AM   #61
Brzetto
Drives: 4 wheels
Originally Posted by oldpueblo View Post
He's doing the Capital One commercials now.
[ame="http://www.youtube.com/watch?v=G7-V9DVAPnQ"]Capital One Vikings Commercial - 2009 (1).wmv - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=IRuuF-5ZST8"]neeeerds - YouTube[/ame]
Brzetto is offline   Reply With Quote
Old 03-13-2013, 02:30 AM   #62
shishand
Drives: Whiteout
this guy will never post again lol
shishand is offline   Reply With Quote
Old 03-13-2013, 02:33 AM   #63
husker741
20 year old who understands why this car is so great, checking in!...
You're all talking about the pu$$y magnet in the glove box, correct?
husker741 is offline   Reply With Quote
Old 03-13-2013, 06:06 AM   #64
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by wu_dot_com View Post
Not disputing that fact. But here is the question, how can you accurately setup your sum of moments (torque) equal zero for all 3 planes to solve for R when your unt vector in X and Z direction is zero?
You, are doing it wrong. You don't need to apply forces, or "unit vector" gravity in any directions, or sum moments at all to find the center of mass. Which, again, *is* the center of gravity in a constant gravitational field (which is the only way any of these cars will be driven).
Wikipedia references that are misunderstood and wrongly applied are no substitute for knowing what the hell you are talking about. Clearly you do not.
Also, it's "rigid body", not "ridgit" or "ridget".
Now repeat after me: A car's center of gravity *is* the same as it's center of mass, and it *does* change (move) if the car is lowered.
Old 03-13-2013, 06:27 AM   #65
fatoni
Originally Posted by SubaruBRZLimited View Post
The BRZ/86/FRS is not slow, the other cars just have a lot more power to compensate for their relatively humongous weight.
just like those other cars are relatively humongous, the frs is relatively slow. you cant have it both ways.
Old 03-13-2013, 06:29 AM   #66
Brzetto
Drives: 4 wheels
Opinions vary.
Old 03-13-2013, 06:35 AM   #67
F1_Fanatic
F1_Fanatic's Avatar
Drives: 2008 Honda Civic LX
I'm glad someone asked this because I have been wondering the same thing for quite some time now.
I've been driving a 140hp Civic (2008 LX) for 5 years now and to me it's not that bad in terms of power. Sure, you have to be realistic, but if I mash the pedal, the car revs up and moves. Like I said, gotta be realistic, so of course there's no sort of feeling of getting pulled into your seat or anything, but still, the car goes..
Now take the 86. Roughly the same weight as my car right now, but with an additional 60hp. That is quite a significant increase in power is it not? So when I read things like "Man, this car doesn't move" or "Damn it's slow" , I get really confused because I know if my Civic had 200hp it would certainly not feel slow!
F1_Fanatic is offline   Reply With Quote
Old 03-13-2013, 06:41 AM   #68
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
He's not an engineer, but he did stay at a Holiday Inn Express last night...
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 03-13-2013, 06:51 AM   #69
fatoni
Opinions vary.
thats true but to knock other cars for being heavy (which may or may not effect the performance of the car) but not knocking the frs for being slow (which does effect the performance of the car) simply isnt fair.
Old 03-13-2013, 06:56 AM   #70
Brzetto
Drives: 4 wheels
Cars that have 200hp or more are not slow by any means BUT you have these spoiled brats who think every car should come with 350hp so they are going to call a car with 200hp slow. The same mentality is present in the car magazines, these so called journalists drive $200.000 cars on a weekly basis in addition to inexpensive cars. Those hacks say the same bullshit, basically calling the inexpensive cars cheap pieces of junk. Not to mention a large group of them are car company stooges and or political stooges as well. For example that idiot Angus Mackenzie from motor trend blathering on about Carroll Shelby's nickname for the Mustang and calling the BRZ's handling crisp, bacon is crisp a car's handling isn't. The BRZ's handling is tight and direct like a sports car, period. *rolls eyes*
I knocked them because the people who bitch about 200hp are spoiled brats who need to go buy a different car if they want to achieve 4 seconds to 60 mph. The same idiots say "for an extra $5000 I could get a mustang gt", the funny thing is they don't get that certain cars are secret giant killers. They see a cheap car, I see a car that has the potential to kick a much more expensive car's ass. For example I saw a video out of japan about 5 years ago that showed one or two R34 Skylines vs an AE86 on a road course, the Skyline stayed away for a few laps but once the AE86 got past him the Skyline never recovered the lead.
Fuel gauge not reading properly FR-S Hot Lava Issues | Warranty | Recalls / TSB 27 10-29-2014 10:33 AM
i'm getting confused reading the tire booklet chenshuo BRZ First-Gen (2012+) — General Topics 23 02-09-2013 07:34 PM
Temperature not reading below 0 BrewCity-FR-S Scion FR-S / Toyota 86 GT86 General Forum 6 01-22-2013 10:05 AM
Reading Vin # Knightmare BRZ First-Gen (2012+) — General Topics 2 11-16-2012 01:26 PM
... reading the reviews? Buggy51 Off-Topic Lounge [WARNING: NO POLITICS] 6 04-26-2012 09:08 AM
