Old 04-10-2014, 01:31 AM   #57
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Originally Posted by AznKirby View Post
Look at those specs. Nothing will be "cheap".
If you want to spend less money, used wheels would be your best bet.
Edit: I've seen your build. Why would you want to put cheap wheels on that nice car?
I was looking at the forgestar f14s or f14f I have a budget of Max 2k$ for wheels
Scalzo is offline   Reply With Quote
Old 04-10-2014, 05:37 AM   #58
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
Originally Posted by Scalzo View Post
So if I want to run 17s or 18s I should go 18x9.5 +0 or -10 & 18x10.5 -30 to fit? I don't want to be slammed but no wheel gap.. What are some cheap wheels that will fit. BBS style
you might need -25 in rear.
Maverick22 is offline   Reply With Quote
Old 04-10-2014, 05:39 AM   #59
Maverick22
Maverick22's Avatar
Originally Posted by CodyFRS View Post
Thinkin about going with a set of 18x11 +20 square. Would these fit the rocketbunny fenders? or would I have turning radius problems up front?
you are going to need a 15-20mm spacer up front and a a 15-20mm spacer rear. you can't run anything wider than a 9.5 in front, however you can run a 11 inchwide rear. you will need to be careful with your tire size.
Old 04-15-2014, 07:04 PM   #60
Maverick22
Maverick22's Avatar
I updated post 14 with more accurate info.
Old 04-16-2014, 05:05 PM   #61
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
18x11" in the rear and 18x9.5" fronts, you're correct, anything more and we start rubbing everywhere.
Yamajee is offline   Reply With Quote
Old 05-04-2014, 11:46 AM   #62
kal-el
Anybody can help me which setup best for RB v.2 planning on getyong weds maverick 605S couldnt figure out the inset [URL] http://maverick-weds.jp/605s.html#[URL]
Sent from my GT-I9500 using Tapatalk
kal-el is offline   Reply With Quote
Old 06-02-2014, 03:46 AM   #63
KIMOJIxSTYLE
KIMOJIxSTYLE's Avatar
Drives: ultramarine monogramfrs
im getting me some weds orden too man and I might just do 18x9.5 -20 up front n 18x10.5-40, any one think this might be too much offset?
KIMOJIxSTYLE is offline   Reply With Quote
Old 06-03-2014, 01:36 AM   #64
kal-el
Hi bro really? I was told that they dont have aggressive offset like that? Please let me know if they have... cuz i was told different
Old 06-03-2014, 02:54 AM   #65
KIMOJIxSTYLE
well if u go to evasive motorsport,, they do have some close to it,,, and if u go to weds.com open thier wheel selection size chart its all custom to ur liking,
Sent from my SGH-M919 using Tapatalk
Old 07-11-2014, 06:12 PM   #66
jumbaco
jumbaco's Avatar
Drives: FD
Originally Posted by Speed Element
15mm spacer up front. no issue with full lock
-Ryan
the 18x9.5 -15 is the effective offset after the spacer or is that before the spacer?
jumbaco is offline   Reply With Quote
Old 07-14-2014, 01:14 PM   #67
Speed Element
Speed Element's Avatar
Drives: FR-S, Evo X, IS-F, 335i, STi, LS460
Send a message via AIM to Speed Element
before to clear our bbk.
-Ryan
Speed Element is offline   Reply With Quote
Old 07-14-2014, 05:50 PM   #68
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Closest to that setup will be 18x9.5 -24 (4inch lip) | 18x10.5 -36 (5inch lip)
Kami Speed is offline   Reply With Quote
Old 07-14-2014, 08:09 PM   #69
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
I'm planning on running
Front: 18x9.5 +26 (25mm spacers)
Rear: 18x10.5 +1 (25mm spacers)
I'm afraid the rear will be sunken in - not that I'm looking for massive amounts of camber, either. I know xdjdubx was running two spacers in the rear for a total of 50 mm with his 10.5, but that seems a bit unsafe.
Thoughts?
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 07-23-2014, 08:34 AM   #70
kal-el
I dont get their website.. the below is asnapshot of the wheels setups they have.. which one will have that 4 and 5 inch lips? Name:  uploadfromtaptalk1406118827299.jpg
Size:  102.0 KB i used google translate and it says insets
Replica rocket bunny crildz Cosmetic Modification (Interior/Exterior/Lighting) 103 05-09-2014 04:35 PM
Rocket Bunny FRS in Dubai TAP Auto Parts FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 49 12-04-2012 01:39 PM
Red Rocket Bunny FR-S - Speedhunters RaceR FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 10-12-2012 12:48 AM
Rocket Bunny or Modelista? HELP!!! ShowstoppersUSA Cosmetic Modification (Interior/Exterior/Lighting) 21 08-16-2012 01:23 PM
GReddy/Rocket Bunny Wheels? Coultergeist Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-15-2012 02:39 AM
