Old 04-09-2013, 03:44 PM   #57
GT 86 Brah
u aware?
GT 86 Brah's Avatar
Drives: it like a turtle.
Originally Posted by boredom.is.me View Post
Heel and toe only comes into to play under relatively hard braking. If it was easy with normal (barely enough) braking, then it would be useless on a track or spirited run. I just throttle blip and down shift if hard braking isn't needed.
i know but i always make the tires squeal every time i try i have to push the brake pedal down pretty far to make my heel reach the gas.
GT 86 Brah is offline   Reply With Quote
Old 04-09-2013, 03:48 PM   #58
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
@frslee: I know the feels. It's difficult for me to go on Reddit at the firm without snickering like a little girl.
Originally Posted by frslee View Post
ah.. i want to laugh out loud, but everyone at work is kinda busy so it's very quiet...
Anthonytpt is offline   Reply With Quote
Old 04-09-2013, 03:54 PM   #59
Lauren
Lauren's Avatar
Drives: 1985 AE86, 2013 GT86
Use the handbrake. I always put the handbrake on if I'm stopped on any incline at traffic lights or in traffic.
I do wonder if it being called an 'emergency' brake in the US and people there learning in autos, don't consider the handbrake as something you use all the time in a manual car.
Doing hill starts was one of the first things I learned in my driving lessons.
1985 AE86 Sprinter Trueno
2013 GT86 White Leather, MT Injen intake, Milltek Exhaust
Lauren is offline   Reply With Quote
The Following User Says Thank You to Lauren For This Useful Post:
sierra (04-09-2013)
Old 04-09-2013, 03:54 PM   #60
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You are probably coming in too fast then. If you try downshifting to second at 45-50mph, you might have a bad time. I try to keep it under a certain rpm (gear dependent) going into the downshift. I don't know what that rpm is though. I just listen.
The Following User Says Thank You to boredom.is.me For This Useful Post:
GT 86 Brah (04-09-2013)
Old 04-09-2013, 04:19 PM   #61
GT 86 Brah
u aware?
GT 86 Brah's Avatar
i tried it on a back road and i just listen too lol. this car is just hard to heel and toe. needs a longer gas pedal imo.
Old 04-09-2013, 04:43 PM   #62
frslee
Just drive it
Drives: 13' FR-S
handbrake!
frslee is offline   Reply With Quote
Old 04-09-2013, 04:56 PM   #63
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Practice... practice... practice!
Imho, when I see a driver in front of me roll back and I can hear that it's stick shift (autos don't revvv like mad before moving forward usually unless he's trying to dump it), it's the most pathetic thing ever. It just shows you don't know how to drive it well.
It takes practice, practice, practice just like anything in the world.
And it's not just me - in Ontario, Canada - if you show up to your driver's test in a stick shift and roll back at ANY TIME, you have an insta-fail. No if's and's or but's. FAIL. I believe they are right. I almost got rolled into a couple of years back exiting a parking lot from a Jay's game - parking lot ramp out was packed with cars and knowing this, I left at least 8-10feet between me and the car in front and I see him roll back, back, back and here I am in a stick shifter myself (and a fully loaded car!) and just watch in horror as he finally rediscovers he has brakes and stops maybe a foot in front of me. I do the same thing except no roll in my case - though with 4 big guys in my little Yaris I thought my engine might barely make it happen but it worked out ok.
If you're on an incline and aren't quick enough to catch the clutch and gas after brake release, USE YOUR HAND BRAKE! It helps you save on clutch wear as you can gently release the brake while adding gas and you learn a little more each and every time you do this.
Plus you won't scare people behind you either.
Frost is offline   Reply With Quote
Old 04-09-2013, 08:52 PM   #64
jmaryt
Drives: 2012 honda civic ex
I practiced a lot on my driveway and anywhere with hills. I used hand brake for a week and I dont use it anymore. All about the right timing.
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
true! after a while you won't need it!
jmaryt is offline   Reply With Quote
Old 04-09-2013, 08:55 PM   #65
jmaryt
if someone is tail gating the hell out of me i would hold the brake pedal and get the clutch right at the biting point then let off the brake and then gas. it will go like an automatic with 0 roll back. 1 inch roll back is hardly even noticeable also. lol.
i still find heel and toe very difficult for this car. the pedals are just too far apart height wise.
true,however,ANY roll back may be enough to contact the guy behind ya ,because some f**kheads could possibly be 1 inch from your back bumper!..just sayin'
Old 04-09-2013, 09:06 PM   #66
GT 86 Brah
u aware?
GT 86 Brah's Avatar
idc.. thats their fault then. if a car rolls back and hits the person behind them because they are too close, its their fault for being too close. go look it up. i have a dash cam also.
Old 04-09-2013, 09:40 PM   #67
jmaryt
(idc) i don't park that close to people.just made a general statement is all,but YOU should care enough to pull forward if they do that to avoid any possibility of hitting them,but,of course it's 'suuuup" to you as the asians say!..also what does it matter WHO is at fault if your car gets damaged,unless of course,you (dc) about that! i don't have to look it up,you are right,i already know this,but your car STILL gets damaged,so (w.t.f!) eh! he! he!
You guys with Limiteds, hows your climate control working? houseofsuffering BRZ First-Gen (2012+) — General Topics 58 02-22-2013 08:37 AM
MT Firestorm at Puente Hills Toyota KlafKoon Southern California 0 07-02-2012 06:31 PM
Black BRZ available at Puente Hills but with a markup toeknee Southern California 10 05-27-2012 11:59 AM
