#57 |
That guy
Drives: Ultramarine mt FR-S
P&L hit 403 on e85 with only upgrading injectors. The auto's internals seem to be holding up to more than the manual.
| The Following User Says Thank You to Hawaiian For This Useful Post: | Kochinopride (08-27-2012) |
#58 | |
Drives: DGM BRZ limited
Upgraded clutch: cheap and only a fewish hours to replace Upgraded transmission internals: expensive and likely difficult to replace |
#59 |
Drives: Firestorm FR-S
Not too surprising. Reminds me of the upgrades required for MT gti guys vs those with the DSG...
#60 | |
That guy
#61 |
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
I (like most) will be running 93 Octane on fuel... Does this mean I absolutely have to have Methanol Injection for reliability/safety? e85 is awesome, but alas - none here
2005 Lotus Elise
2012 Mercedes Benz CLS AMG 6.3 2013 Scion FR-S 2011 Land Rover LR4 2013 Lamborghini Gallardo LP570-4 Superleggera |
#63 |
340whp is nice, but I wanted 400whp
... Guess I'll wait for the BRZ-500 project? lol
2005 Lotus Elise
| The Following User Says Thank You to Kochinopride For This Useful Post: | tripjammer (08-27-2012) |
#64 | |
Replace it once with one up to the task and you won't have to replace it again. That or just stay at a reasonable power level on the stock one. Anything over 200whp is going to be quite the excitement compared to stock. |
| The Following User Says Thank You to rusty959 For This Useful Post: | Sall (08-28-2012) |
#65 |
Drives: 2013 Asphalt FR-S
Well, your auto has several "clutches" inside. It does not have the same type as the manual however which uses a clutch and flywheel combo at the back of the engine. Yours just uses a flex plate (instead of flywheel) and a torque converter (instead of a clutch).
| The Following User Says Thank You to Opposed For This Useful Post: | Supermassive (08-30-2012) |
#66 | |
King of Kiwi Palace
Drives: Faster than you
I used to run methanol on my old car, it's pretty safe. Then you run with a hi/lo psi switch. 9-10 psi low and 20-25 psi with methanol. Good ole days
#67 |
If larger injectors means more power for the car, then I'm all in!! If they can confirm this - I'm going to chart the course of getting it installed next month!
2005 Lotus Elise
#68 | |
The BRZ-400 kit is still under testing John |
| The Following User Says Thank You to Visconti For This Useful Post: | Shiny (08-29-2012) |
#69 |
Toyota Soul
Drives: 96 taco
Well, id love to see a vid as well, but take yall time on getting this right. I will be waitng on more dyno results also!!
No replacement for Displacement??? Tell that to the people with a 2JZ.
| Visconti Tuning - Who wants to run on e85? or 100 Octane | Visconti | Engine, Exhaust, Transmission | 174 | 05-21-2013 04:00 PM |
| Visconti Tuning Stage 1 Tester #3 (I think) | ruskymx | Engine, Exhaust, Transmission | 46 | 09-15-2012 05:29 AM |
| Visconti Tuning Stage1 candidate | brichard0625 | Engine, Exhaust, Transmission | 134 | 09-03-2012 01:04 PM |
| Another Accelerated Performance Turbo BRZ - Visconti Tuned ! | Visconti | Forced Induction | 34 | 08-28-2012 01:47 AM |
| Visconti Tuning NA STG1 Group Buy | Visconti | Groupbuys | 683 | 08-24-2012 12:28 PM |
