Old 08-27-2012, 12:34 PM   #57
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by Kochinopride View Post
YESSS!!! That's what I'm talking about! Let's get this going on my FR-S Automatic!!! Just need to make sure the clutch is upgraded (can we even upgrade it?)
P&L hit 403 on e85 with only upgrading injectors. The auto's internals seem to be holding up to more than the manual.
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
Kochinopride (08-27-2012)
Old 08-27-2012, 12:37 PM   #58
rusty959
Drives: DGM BRZ limited
Neither of them have broken so both are holding up just as well as the other. No one should consider a clutch needing upgraded part of a transmission's internals.
Upgraded clutch: cheap and only a fewish hours to replace
Upgraded transmission internals: expensive and likely difficult to replace
rusty959 is offline   Reply With Quote
Old 08-27-2012, 12:37 PM   #59
Mild2Wild
Drives: Firestorm FR-S
Not too surprising. Reminds me of the upgrades required for MT gti guys vs those with the DSG...
Mild2Wild is offline   Reply With Quote
Old 08-27-2012, 12:40 PM   #60
Hawaiian
That guy
Hawaiian's Avatar
True, but this will be the second clutch for Don's car. It's one of the main thing keeping me from slapping a turbo on my car tomorrow (that and the fact that it's been stuck at the dealer for the last week).
Old 08-27-2012, 12:45 PM   #61
Kochinopride
Kochinopride's Avatar
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
I (like most) will be running 93 Octane on fuel... Does this mean I absolutely have to have Methanol Injection for reliability/safety? e85 is awesome, but alas - none here
2005 Lotus Elise
2012 Mercedes Benz CLS AMG 6.3
2013 Scion FR-S
2011 Land Rover LR4
2013 Lamborghini Gallardo LP570-4 Superleggera
Kochinopride is offline   Reply With Quote
Old 08-27-2012, 12:53 PM   #62
Visconti
Drives: 05 STi
I'll post up a graph later but I think we made 330-340whp on pumpgas.
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
Shiny (08-29-2012)
Old 08-27-2012, 12:56 PM   #63
Kochinopride
340whp is nice, but I wanted 400whp ... Guess I'll wait for the BRZ-500 project? lol
2005 Lotus Elise
2013 Scion FR-S
2011 Land Rover LR4
The Following User Says Thank You to Kochinopride For This Useful Post:
tripjammer (08-27-2012)
Old 08-27-2012, 01:02 PM   #64
rusty959
Its only the second clutch needing replaced because he was using the stock pressure plate. Seems like Exedy wanted some testing done and that testing was successful, atleast in that they found the limit.
Replace it once with one up to the task and you won't have to replace it again. That or just stay at a reasonable power level on the stock one. Anything over 200whp is going to be quite the excitement compared to stock.
The Following User Says Thank You to rusty959 For This Useful Post:
Sall (08-28-2012)
Old 08-27-2012, 01:12 PM   #65
Opposed
Drives: 2013 Asphalt FR-S
Well, your auto has several "clutches" inside. It does not have the same type as the manual however which uses a clutch and flywheel combo at the back of the engine. Yours just uses a flex plate (instead of flywheel) and a torque converter (instead of a clutch).
Opposed is offline   Reply With Quote
The Following User Says Thank You to Opposed For This Useful Post:
Supermassive (08-30-2012)
Old 08-27-2012, 01:12 PM   #66
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
I'm sure larger injectors can pull 400 on pump.
I used to run methanol on my old car, it's pretty safe. Then you run with a hi/lo psi switch. 9-10 psi low and 20-25 psi with methanol.
Good ole days
Ironsquid is offline   Reply With Quote
Old 08-27-2012, 01:17 PM   #67
Kochinopride
If larger injectors means more power for the car, then I'm all in!! If they can confirm this - I'm going to chart the course of getting it installed next month!
2005 Lotus Elise
2013 Scion FR-S
2011 Land Rover LR4
Old 08-27-2012, 02:43 PM   #68
Visconti
Drives: 05 STi
I would suggest the SIR500s or DW700s on the BRZ-300 kit. It can be done with out on low boost..
The BRZ-400 kit is still under testing
John
Shiny (08-29-2012)
Old 08-27-2012, 03:00 PM   #69
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Well, id love to see a vid as well, but take yall time on getting this right. I will be waitng on more dyno results also!!
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 08-27-2012, 04:02 PM   #70
Visconti
Drives: 05 STi
I have a dyno video but Mr Don doesn't know how to operate a iPhone so the sound kinda sucks
John
Shiny (08-29-2012)
Visconti Tuning - Who wants to run on e85? or 100 Octane Visconti Engine, Exhaust, Transmission 174 05-21-2013 03:00 PM
Visconti Tuning Stage 1 Tester #3 (I think) ruskymx Engine, Exhaust, Transmission 46 09-15-2012 04:29 AM
Visconti Tuning Stage1 candidate brichard0625 Engine, Exhaust, Transmission 134 09-03-2012 12:04 PM
Another Accelerated Performance Turbo BRZ - Visconti Tuned ! Visconti Forced Induction 34 08-28-2012 12:47 AM
Visconti Tuning NA STG1 Group Buy Visconti Groupbuys 683 08-24-2012 11:28 AM
