Old 12-02-2021, 05:18 PM   #57
Hurricane Nate
Drives: 2020 BRZ (Black)
Originally Posted by misterfly View Post
Im seraching the best one in 75-85 for the diff , for the trans i will take motul but motul dont do 75w-85 , what guy use in 2017 + ?
I plan on putting Motul 300 in both Trans and Diff soon for my 2020 BRZ
Also, the Motul website has links to where you can buy stuff for less than $20 bucks per 1L bottle.
https://www.motul.com/us/en/products/gear-300-75w90
Just click on the Buy online link and it'll pop a few sites. Currently Bimmers.com has it for $13.95 a bottle.
Hurricane Nate is offline   Reply With Quote
The Following User Says Thank You to Hurricane Nate For This Useful Post:
GPhilly (01-28-2022)
Old 10-27-2022, 09:56 AM   #58
covance
Drives: 2015 BRZ series.blue
In October 2022 Motul seems sold out everywhere. I spoke to 86speed customer service and they said it is backordered until 2023.
I have a 2015 BRZ 6MT - can I just buy 4 bottles of this and change both the transmission and rear differential fluids with it?
https://parts.stohlmansubaru.com/p/S...A427V1700.html
Genuine Subaru Certified High Performance Gear Oil SAE 75W 90, 1 Quart Bottle. Quantity Required: 2.3.
Part Number: SOA427V1700
This is my first time changing these fluids, after owning the car since end of 2014 and 40k street miles. I don't do track days, just spirited street driving.
Also, anyone happen to have the correct Subaru part numbers for all necessary washers/gaskets? I have had trouble finding those.
Thanks in advance!
covance is offline   Reply With Quote
Old 10-27-2022, 11:01 AM   #59
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Thanks in advance!
There's a thread somewhere with info but I saved it for my self.
Subaru
1215710010 Diff Drain Gasket
11126JB000 Diff Fill Gasket
17008AA050 Transmission Gaskets
803916010 Oil Drain Gasket
Toyota
TOY1215710010 Diff Drain Gasket
SU00300122 Diff Fill Gasket
SU00303626 Transmission Gaskets
SU00302159 Oil Drain Gasket
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Bonburner (06-21-2023), covance (10-27-2022)
Old 10-27-2022, 12:52 PM   #60
covance
Subaru
Toyota
Thank you! Any opinion on the link to the oil?
Old 10-28-2022, 12:52 PM   #61
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you can't find Motul, why not just run Redline? I have beating on my car for years with it. You can find 75w90 gear and Mt-90 at most box stores. I actually like the MT-90 more then the Motul, I think it shifts nicer and it's easy to get.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
RToyo86 (10-28-2022), Ultramaroon (10-28-2022), villainous_frx (10-29-2022), x808drifter (10-29-2022)
Old 10-28-2022, 01:47 PM   #62
Ultramaroon
not playing cards
Ultramaroon's Avatar
+1 for Redline
Old 10-28-2022, 02:04 PM   #63
LancePower
Drives: 2020 BRZ tS
I've also have both Motul and Redline in this platform and prefer the Redline.
LancePower is offline   Reply With Quote
Old 10-30-2022, 02:24 PM   #64
e_lunatic
Drives: 2015 Scion FR-S
I use Lucas Oil for trans and diff. We used it in the drift cars for a long time and its been perfect in my personal car as well. +1 for being able to find it at your local parts store as well.
that being said it's very clear you can't go wrong with Motul and Redline
e_lunatic is offline   Reply With Quote
Old 11-01-2022, 09:35 PM   #65
warhawk03
Drives: 2018 BRZ
With Red Line's products, am I understanding this correctly?
For the transmission, MT-90 is 75w90 GL-4, which meets the specifications set by the OEM.
For the differential, both 75w90 and 75w90NS are GL-5, which meets the specifications set by the OEM. However, the 75w90NS doesn't have the friction modifiers, which is ideal for the hypoid gear (non clutch-type) differential that's in the car.
So, MT-90 for the transmission and 75w90NS GL-5 gear oil for the differential?
If I've got this wrong, let me know so I don't confuse any other newbies.
warhawk03 is offline   Reply With Quote
Old 11-01-2022, 11:25 PM   #66
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Either would be fine. I've been using the regular 75-90. This is really only important if you have a clutch LSD.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
warhawk03 (11-02-2022)
Old 05-13-2023, 02:15 AM   #67
Drummerkurt71!
Drives: 2015 TRD 1.0 Scion FR-S
Which oil to use?
I have a 2015 FR-S
1.0 I think it's called. It's 1109 of 1500 made. TRD package on it.
At 100 k miles I figured it's time to change the transmission fluid and rear diff fluid. Besides it's getting harder to shift.
I put 75w-140 oil in it (because I had some). now i's harder to shift than before. I want to drain and fill it again with proper oil, but I want quality oil.
Something that will help it shift smoother than it used to.
What kind of oil do you recommend for it? For the transmission and diff?
I found Redline MT-90 on Amazon. But I also hear you guys talk about Amsoil, and / or Motul 300.
And for the DiffGL-5) 75w90 NON-LIMITED SLIP? (what brand)
A little confused. I drive the car pretty hard, like stole it! Hard corners and high freeway speeds.
I also have problem wi tire squirm; anybody heard of that?
This is my first post
Anything helps, Thank you very much!
Drummerkurt71! is offline   Reply With Quote
Old 05-13-2023, 03:35 AM   #68
r4mr4m3024
Drives: gt86
I can't find the original gaskets. I found these replacement gaskets for the transmission and differential. Is this correct?
A ABSOPRO 12 pieces car oil drain screws seal 12157-10010 for Toyota Corolla https://amzn.eu/d/duyZD2A
r4mr4m3024 is offline   Reply With Quote
Old 06-23-2023, 12:34 AM   #69
Griever423
Drives: 2020 BRZ PP
I just had my trans and diff fluid flushed and replaced with Redline. Man what a difference the MT-90 made in smoothness. Highly recommended.
Griever423 is offline   Reply With Quote
differential, fluids, maintenance, oil, transmission fluid
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG jfg5067 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 01-18-2016 10:24 AM
Trans and Diff fluid change feedback Freedom AFRICA 0 08-07-2015 12:52 PM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 09:02 AM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 10:04 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 04:11 PM
