| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#57 | |
Drives: 2020 BRZ (Black)
Also, the Motul website has links to where you can buy stuff for less than $20 bucks per 1L bottle. https://www.motul.com/us/en/products/gear-300-75w90 Just click on the Buy online link and it'll pop a few sites. Currently Bimmers.com has it for $13.95 a bottle. Last edited by Hurricane Nate; 12-02-2021 at 04:19 PM. Reason: Added car |
| The Following User Says Thank You to Hurricane Nate For This Useful Post: | GPhilly (01-28-2022) |
#58 |
Drives: 2015 BRZ series.blue
In October 2022 Motul seems sold out everywhere. I spoke to 86speed customer service and they said it is backordered until 2023.
I have a 2015 BRZ 6MT - can I just buy 4 bottles of this and change both the transmission and rear differential fluids with it? https://parts.stohlmansubaru.com/p/S...A427V1700.html Genuine Subaru Certified High Performance Gear Oil SAE 75W 90, 1 Quart Bottle. Quantity Required: 2.3. Part Number: SOA427V1700 This is my first time changing these fluids, after owning the car since end of 2014 and 40k street miles. I don't do track days, just spirited street driving. Also, anyone happen to have the correct Subaru part numbers for all necessary washers/gaskets? I have had trouble finding those. Thanks in advance! |
#59 | |
Drives: 17 Asphalt 86
Subaru 1215710010 Diff Drain Gasket 11126JB000 Diff Fill Gasket 17008AA050 Transmission Gaskets 803916010 Oil Drain Gasket Toyota TOY1215710010 Diff Drain Gasket SU00300122 Diff Fill Gasket SU00303626 Transmission Gaskets SU00302159 Oil Drain Gasket |
#60 | |
#61 |
Drives: Crapcan
If you can't find Motul, why not just run Redline? I have beating on my car for years with it. You can find 75w90 gear and Mt-90 at most box stores. I actually like the MT-90 more then the Motul, I think it shifts nicer and it's easy to get.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: | RToyo86 (10-28-2022), Ultramaroon (10-28-2022), villainous_frx (10-29-2022), x808drifter (10-29-2022) |
#62 |
+1 for Redline
#63 |
Drives: 2020 BRZ tS
I've also have both Motul and Redline in this platform and prefer the Redline.
#64 |
Drives: 2015 Scion FR-S
I use Lucas Oil for trans and diff. We used it in the drift cars for a long time and its been perfect in my personal car as well. +1 for being able to find it at your local parts store as well.
that being said it's very clear you can't go wrong with Motul and Redline |
#65 |
Drives: 2018 BRZ
With Red Line's products, am I understanding this correctly?
For the transmission, MT-90 is 75w90 GL-4, which meets the specifications set by the OEM. For the differential, both 75w90 and 75w90NS are GL-5, which meets the specifications set by the OEM. However, the 75w90NS doesn't have the friction modifiers, which is ideal for the hypoid gear (non clutch-type) differential that's in the car. So, MT-90 for the transmission and 75w90NS GL-5 gear oil for the differential? If I've got this wrong, let me know so I don't confuse any other newbies. |
#66 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | warhawk03 (11-02-2022) |
#67 |
Drives: 2015 TRD 1.0 Scion FR-S
Which oil to use?
I have a 2015 FR-S
1.0 I think it's called. It's 1109 of 1500 made. TRD package on it. At 100 k miles I figured it's time to change the transmission fluid and rear diff fluid. Besides it's getting harder to shift. I put 75w-140 oil in it (because I had some). now i's harder to shift than before. I want to drain and fill it again with proper oil, but I want quality oil. Something that will help it shift smoother than it used to. What kind of oil do you recommend for it? For the transmission and diff? I found Redline MT-90 on Amazon. But I also hear you guys talk about Amsoil, and / or Motul 300. And for the Diff GL-5) 75w90 NON-LIMITED SLIP? (what brand)A little confused. I drive the car pretty hard, like stole it! Hard corners and high freeway speeds. I also have problem wi tire squirm; anybody heard of that? This is my first post Anything helps, Thank you very much! |
#68 |
Drives: gt86
I can't find the original gaskets. I found these replacement gaskets for the transmission and differential. Is this correct?
A ABSOPRO 12 pieces car oil drain screws seal 12157-10010 for Toyota Corolla https://amzn.eu/d/duyZD2A |
#69 |
Drives: 2020 BRZ PP
I just had my trans and diff fluid flushed and replaced with Redline. Man what a difference the MT-90 made in smoothness. Highly recommended.
| Tags |
| differential, fluids, maintenance, oil, transmission fluid |
| Changed Diff/MT Trans Fluid to Motul 300 and super low MPG | jfg5067 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 01-18-2016 09:24 AM |
| Trans and Diff fluid change feedback | Freedom | AFRICA | 0 | 08-07-2015 11:52 AM |
| Manual Trans./Diff. Fluid Change.?. | westmansweed | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 07-15-2015 08:02 AM |
| Replacing Trans & Diff Fluid, Hot vs Cold | BRZNutt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 12-22-2013 09:04 PM |
| Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 03:11 PM |
