Old 07-04-2020, 08:36 PM   #57
dagle
Drives: assphalt FRS, couple s2000's
also for posterity, spring removal doesn't only change the heaviness. my understanding is that the linearity of force needed for pedal travel also changes (video link below). I haven't reproduced the test myself or have any inclination to, but it does seem that based on the position of the pedal, the spring's force transitions from push to pull.
dagle is offline   Reply With Quote
The Following User Says Thank You to dagle For This Useful Post:
humfrz (07-04-2020)
Old 07-05-2020, 06:13 AM   #58
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
I changed out the clutch spring for an MTEC clutch spring and then adjusted the clutch pedal so it grabs closer to the firewall. much improved take offs and gear changes. throw in the MTEC shifter springs the whiteline positive shift kit and perrin rear bushing and revel in how great swapping cogs can be.
I have a Stage 2+ tune on mine and found that improved throttle response a touch, not that I felt there was anything wrong with it.
I had noble intentions of keep my car stock but improving stuff like the gear shift and clutch pedal meant that one thing lead to another and now I have a list of nearly 40 mods I've done to the car, some very minor all the way up to headers, a tune and lots of suspension mods. that is the beauty of these cars - so much available to mod your car to your taste.
don't be afraid to modify and improve your car - just keep all the stock bits so you can change it back if you need to.
sneaky_pete is offline   Reply With Quote
Old 07-05-2020, 02:55 PM   #59
Ultramaroon
not playing cards
Ultramaroon's Avatar
The assist spring is part of an overcenter mechanism. The most common example that I can think of is that on a light switch. It's actually useful for stabilizing the linkage so it doesn't rattle while at rest. I regret losing the parts for mine after removing it, but not enough to scrounge for replacements.
humfrz (07-05-2020)
Old 07-05-2020, 06:56 PM   #60
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
Originally Posted by Summerwolf View Post
Clutch delay system?
As far as throttle body this is the best DBW system I've ever driven. I think it might be an issue of you getting used to a car.
this. My last car had DBW and it was good, and after I tuned it, it was very good. This is better. The only electronic throttle I've used that was as good was on my last bike, a KTM street bike.
the low throttle angle tip in response is laser sharp. very nice
JohnH is offline   Reply With Quote
Old 07-05-2020, 07:00 PM   #61
JohnH
Professional wrench
hey, any how to, or video on this to do it PROPERLY?? I know there are two adjustments. One is the rod that actually goes thru the firewall above the gas pedal and there is the other adjustment at the clutch pedal switch.
I don't want to take away all the free play in the rod, as then the clutch won't fully engage. and too much free play won't allow it to fully disengage. Its kind of hard to know what the free play is because of the spring.
I'd like to tune this nicely. Its not bad but its a little off. I'm a good manual trans driver, and I know its not my bad technique
thanks!
Old 07-06-2020, 03:57 AM   #62
sneaky_pete
clutch spring replacement
clutch pedal adjustment
shifter spring replacement
shifter bushing
The Following 2 Users Say Thank You to sneaky_pete For This Useful Post:
JohnH (08-18-2021), Tanstin (07-07-2020)
Improve throttle response ChrisD BRZ First-Gen (2012+) — General Topics 80 10-05-2020 07:50 PM
OFT v4.03 throttle response Tristor Software Tuning 29 09-22-2019 04:51 PM
OFT throttle response MyGT86Yas Software Tuning 6 02-26-2018 05:44 AM
Does the throttle response improve? pr086 Scion FR-S / Toyota 86 GT86 General Forum 36 12-01-2012 01:06 PM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
