Old 01-22-2020, 07:15 AM   #57
steverife
Drives: 2016 Scion FRS
I probably spent about 5k autocross travel miles in an STX FRS with the STi mounts in the 2013-2015 era and never noticed them. So that seems like a reasonable option.
steverife is offline   Reply With Quote
Old 01-23-2020, 11:18 AM   #58
bslate3
Drives: 2015 CWP BRZ
I was thinking about replacing my axles instead of rebuilding them.
Is everyone using OEM? They are super expensive. I see there are aftermarket replacements for way cheaper. Just wondering if they will hold up though.
bslate3 is offline   Reply With Quote
Old 01-23-2020, 11:25 AM   #59
M0nk3y
Personally, just buy some used ones off eBay and be ready to change when one goes.
I have 2 - OEM Axles from an 86 that obviously was wrecked or something with 5,000 miles on the axles. Paid $199 for 2.
I just have the tools ready to change onsite.
Kyle H. - #89 STX
Old 01-23-2020, 11:27 AM   #60
MX-5RACER
MX-5RACER's Avatar
Drives: 2018 FA24 SWAP BRZ "ANNIE"
I had a rattle in my car that was a combination of the header (HKS Equal length) hitting the undertray and the over-pipe hitting the subframe. I was able to loosen the bolts on the over-pipe and push it up a little and tighten the bolts and I am now rattle free! I also "clearanced" the undertray with a smack with the round end of a hammer on the spot that was just touching the header.
DJ
2008 MX-5 PRHT "Violet"
2018 FA24 Swap BRZ "Annie"
MX-5RACER is offline   Reply With Quote
Old 01-25-2020, 10:27 PM   #61
KevBRZ
Drives: 15BRZ
2020 STX setup
2015 BRZ Limited Car STX/daily driver,
Suspension:
Racecomp engineering SS1 coilovers with 340 spring rates front and rear
Camber: Not sure what i am gonna do this year prob -3.X front and 2.2 rear
Perrin 22m front bar on soft
RacerX end-links in front
Velox/verus rear arms with poly bushings
Engine:
Stock intake with K&N filter
Perrin inlet tube
Perrin 2.5 inch non resonated exhaust ( Prob gonna go back to stock after header install- i like quiet lol) or maybe get CSG exhaust
Ace 350 header ( not installed yet)
Ecutek tuner ( not installed yet)
Wheels, Tires, Other:
Enkei 17x9 +35 rpf1s gunmetal with 245/40/17 Rivals
(Ferodos pads not installed yet)
Hoping to do alot more than just 2-3 events like last year
and get to learn the car this year.
KevBRZ is offline   Reply With Quote
Old 01-25-2020, 10:57 PM   #62
KevBRZ
Drives: 15BRZ
re: mounts
Originally Posted by steverife View Post
Nobody running upgraded motor mounts?
I was thinking about getting them to install with the Ace Header but was on the fence about it.
Old 01-26-2020, 06:18 PM   #63
MaverickMonk
Drives: 13 BRZ Limited
Suspension:
How are those endlinks holding up? Been considering whether or not to do adjustable endlinks but have concerns about non-poly bushings in a salty area on a car that sees daily duty
MaverickMonk is offline   Reply With Quote
Old 01-27-2020, 11:25 AM   #64
KevBRZ
Drives: 15BRZ
re: links
Funny you ask that...... I daily drive mine ( wasn't exactly the original plan lol) , but on bad days i can ride with my wife in our CRV ( we work together) so my car doesn't see alot of bad weather but def some, one bushing froze up (the lower passenger side) but did not appear to be because of salt etc (they were fairly clean) it just seemed to freeze up, Racer x is in the process of sending me a new bushing for free and they were great to work with btw. If i knew i was gonna be driving in tons of salt and snow in say Buffalo, Canada etc. i don't think i would recommend these links..... I think it even says on their site for race use only not street....I am gonna spray mine down with something but not sure what I am gonna use yet, or even just try to cover them. I think the key is just try to keep them clean just like the coilovers hosing them down here and there etc.
Old 01-27-2020, 12:53 PM   #65
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I had no issues with Whiteline end links set about as short as they'd go. Ideally you'd cut some off each end of the center section.
The end links on my Karcepts bars have also been quiet so far too, and I DD my car (but not in salt)
Old 01-27-2020, 02:08 PM   #66
MaverickMonk
Thanks for the info, and sorry about the trouble. I’m not going too low with my coils, so unless I experience a lot of tension or binding I’m just going to stick with the stock endlinks. Shame there’s no adjustable endlinks with poly bushings, that’d be ideal for a car that sees primarily daily use and some autoX on the side.
Old 01-28-2020, 03:17 PM   #67
PointDSM
PointDSM's Avatar
Drives: 2013 Subaru BRZ
Has anyone noticed any drastic difference between presumably used (or remanufactured) OEM rear axles and those found on RockAuto (SurTrack/Trakmotive) - https://www.rockauto.com/en/moreinfo...O0G6cYNWkIwVUp
Looking for a back-up set to carry around just in-case.
Thanks!
PointDSM is offline   Reply With Quote
Old 02-14-2020, 10:24 AM   #68
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Are the JDM underbody panels legal for STX? I think they are now OEM equipment on the 2017+ 86/BRZ's...can someone confirm?
https://www.ft86speedfactory.com/jdm...l#.Xka9SGhKiUk
skylinekin is offline   Reply With Quote
Old 02-14-2020, 11:23 AM   #69
ka-t_240
Thanks!
I have extras, OE pull outs. They were about $50 each when bought with other parts from salvage years.
ka-t_240 is offline   Reply With Quote
Old 02-14-2020, 11:26 AM   #70
ka-t_240
They are also OE on brz TS/series blue/etc, I was thinking they came on 15+ or there was some chang in the panels on a 15ish+
SSC setup thread conehead Tracking / Autocross / HPDE / Drifting 26 06-06-2023 02:21 PM
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 12:44 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 11:27 AM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 11:30 AM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 10:05 PM
