#57 |
Not a troll
I have. Turns out that -4 front and -2.5 rear is waaaaaaaaaaaaay too much for my use case. Prematurely (maybe?) killed my RE71R this past summer with that camber with two autox events. In any case, those tires served me well, and were on their third or fourth summer for me
#58 | |
I get about 130 runs (10-20 events depending on codriver) with that alignment (toe is F:0 R:1/16") but I keep the street miles down <2k miles. |
#59 |
Not a troll
#60 |
Ah yeah that'll do it at that alignment. But in any case even a modest -2.5 is a big improvement in handling over the stock -0.6
#61 |
Drives: 2014 GT86
Stock -0.6? IIRC stock front camber was 0, so even worse grip & grip-bias wise for track use then that.
#62 | |
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#63 | |
Not a troll
I suck at autox anyhow, so until I'm better I'll have a more street oriented alignment. |
#64 |
Drives: 2013 ARGENTO A/T
As one of the vendors suggested, there is a Cascade of effects that will have you replacing every suspension component possible to "fix" a system that was nearly flawless from factory, even with factory variances in alignment. So far after lowering I've installed:
Rear LCAs Camber bolts (front) Steering rack bushings Sway bar end links New oem shocks Tie rod end links LCA ball joints(roll center correction) Each installation gains a little of the OEM feel back but it will never be the same. This is the last car that I will ever lower. And yes, changing camber values has been part of this hair pulling journey. |
#65 |
What you call flawless I call an understeering pig. To each their own.
#66 |
Yeap, if they think that they are good in standard form, they have not driven a well sorted RWD car.
#67 | |
Drives: Crapcan
#68 |
Drives: 2016 Scion FRS
I almost agreed with strat, but then I remembered how I bought the car, drove it home, ordered parts, and had struts/springs/camber bolts/sway bars/rear lca's/wheels/tires/exhaust on the car within a week of owning it.
#69 | |
The best thing about SSC is giving the car -3° up front. |
#70 |
Drives: Crapcan
| 2013s less responsive than 2017s? | 370zBRZ | BRZ First-Gen (2012+) — General Topics | 25 | 07-28-2018 05:24 PM |
| Car feels a little less peppy | Riftur | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 04-15-2018 06:02 AM |
| Which entry level turbo kit is the most responsive? | Keenercarguy | Forced Induction | 54 | 04-18-2017 03:40 AM |
| Am I the only one that feels bothered by this (R.S 1.0) | 1GiantTurtle | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 12-11-2014 08:18 PM |
| 18's or 19's ... What looks and feels best on FR-S. | Jon1084 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 65 | 07-19-2013 06:42 PM |
