Old 12-24-2019, 05:38 PM   #57
Cole
Not a troll
Cole's Avatar
You have clearly not experimented with camber yet.
I have. Turns out that -4 front and -2.5 rear is waaaaaaaaaaaaay too much for my use case. Prematurely (maybe?) killed my RE71R this past summer with that camber with two autox events. In any case, those tires served me well, and were on their third or fourth summer for me
Cole is offline   Reply With Quote
Old 12-24-2019, 11:11 PM   #58
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
How many street miles?
I get about 130 runs (10-20 events depending on codriver) with that alignment (toe is F:0 R:1/16") but I keep the street miles down <2k miles.
ineedyourdiddly
Old 12-24-2019, 11:53 PM   #59
Cole
Not a troll
Cole's Avatar
Almost all street, something like 20000km. I have 0 toe all around.
Old 12-25-2019, 12:23 AM   #60
strat61caster
Ah yeah that'll do it at that alignment. But in any case even a modest -2.5 is a big improvement in handling over the stock -0.6
ineedyourdiddly
Old 12-25-2019, 03:13 AM   #61
churchx
churchx's Avatar
Drives: 2014 GT86
Stock -0.6? IIRC stock front camber was 0, so even worse grip & grip-bias wise for track use then that.
Old 12-25-2019, 03:40 AM   #62
86MLR
86MLR's Avatar
Yeah, my stock front was 0, the rear was -0.75 on one side and -1.25 on the other, toe settings were all over the shop IIRC.
Old 12-25-2019, 11:37 AM   #63
Cole
Not a troll
Cole's Avatar
Yeah, I'm not too bummed out. Getting as many km out of the tires as I did, I'm happy. Going to get an alignment shortly after the new year with probably -2.5 front, -1.5 rear and some toe for a bit more highway speed stability.
I suck at autox anyhow, so until I'm better I'll have a more street oriented alignment.
Old 12-25-2019, 10:31 PM   #64
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
As one of the vendors suggested, there is a Cascade of effects that will have you replacing every suspension component possible to "fix" a system that was nearly flawless from factory, even with factory variances in alignment. So far after lowering I've installed:
Rear LCAs
Camber bolts (front)
Steering rack bushings
Sway bar end links
New oem shocks
Tie rod end links
LCA ball joints(roll center correction)
Each installation gains a little of the OEM feel back but it will never be the same. This is the last car that I will ever lower. And yes, changing camber values has been part of this hair pulling journey.
Spacemane969 is offline   Reply With Quote
Old 12-26-2019, 12:32 AM   #65
strat61caster
What you call flawless I call an understeering pig. To each their own.
ineedyourdiddly
Old 12-26-2019, 01:08 AM   #66
86MLR
86MLR's Avatar
Yeap, if they think that they are good in standard form, they have not driven a well sorted RWD car.
Old 12-26-2019, 02:43 AM   #67
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Rear LCAs
Sway bar end links
New oem shocks
Tie rod end links
What tire ?
Old 12-30-2019, 11:23 AM   #68
steverife
Drives: 2016 Scion FRS
I almost agreed with strat, but then I remembered how I bought the car, drove it home, ordered parts, and had struts/springs/camber bolts/sway bars/rear lca's/wheels/tires/exhaust on the car within a week of owning it.
steverife is offline   Reply With Quote
Old 12-30-2019, 04:15 PM   #69
strat61caster
Understeer, it's what makes a Subaru a Subaru.
The best thing about SSC is giving the car -3° up front.
ineedyourdiddly
Old 12-31-2019, 06:48 AM   #70
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I like how he gave us all that detail but won't tell us what tire he is on. Pretty critical part of the equation.
2013s less responsive than 2017s? 370zBRZ BRZ First-Gen (2012+) — General Topics 25 07-28-2018 05:24 PM
Car feels a little less peppy Riftur Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 04-15-2018 06:02 AM
Which entry level turbo kit is the most responsive? Keenercarguy Forced Induction 54 04-18-2017 03:40 AM
Am I the only one that feels bothered by this (R.S 1.0) 1GiantTurtle Scion FR-S / Toyota 86 GT86 General Forum 22 12-11-2014 08:18 PM
18's or 19's ... What looks and feels best on FR-S. Jon1084 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 65 07-19-2013 06:42 PM
