Old 08-31-2018, 03:04 PM   #57
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by chaoskaze View Post
This, I can probably buy some BCs at $400-500 dollar range on alibaba if i order more then 10 sets at once.
via Imgflip Meme Generator
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
Tokay444 (08-31-2018), Tristor (08-31-2018)
Old 08-31-2018, 04:07 PM   #58
KnightRyderx2
Drives: 2014 FR-S
Well your going to need all 10 sets to piece together a decent set that will actually work.
KnightRyderx2 is offline   Reply With Quote
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
wparsons (09-01-2018)
Old 08-31-2018, 04:14 PM   #59
churchx
churchx's Avatar
Drives: 2014 GT86
And to select better ones from those ten sets one will need shock dyno them.
.. wait. Isn't it supposed to be dirt cheap?!
Old 08-31-2018, 07:05 PM   #60
evomike
Drives: frs
Originally Posted by Tokay444 View Post
He fucked up buying such an inferior product. The fact that people can point at anything else blows my mind.
So you’re still saying him not aligning it and having t set up isn’t the problem, keep ignoring the fact that if OP bought $5k coilovers his car would still drive like a bag of ****s. You can say the product is inferior all you want but that IS NOT the root of the problem here the root of the problem is OP not aligning his car and having the pre load set.
evomike is offline   Reply With Quote
The Following User Says Thank You to evomike For This Useful Post:
x808drifter (08-31-2018)
Old 08-31-2018, 07:16 PM   #61
86MLR
86MLR's Avatar
I have MCA Reds on my car but would not recommend them on this forum except for in the Australia sub-forum.
Why? Because in the States there a gazillion options running from $200 junk items to 10k+ racing dampers with local support. Yeah, that last part. Local support. Last time I spoke to Josh they still hadn't organised a distributor/service center for MCAs in the States and as I've said before you won't appreciate local service until you need it. I mean seriously, why would anyone in the States want to send their dampers back to Aus to get serviced?
/rant.
I generally throw my old coils away and buy a new set if required, I understand there is a requirement for rebuilding in some circles though.
It's just something I wouldn't worry about personally, I actually cannot recall anyone who has had their coil rebuilt.
Old 08-31-2018, 07:22 PM   #62
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Not setting pre preload only matters if there's enough droop in the suspension to unseat the spring. Even then it won't affect anything until you go to full droop. It certainly will not affect the bounciness of the ride during normal driving. Not aligning it will shred the tires and the car won't drive straight/handle well, but again it would have very little to do with the ride comfort. The car drives like shit because BCs are known to ride like shit. They're known for too high (for street driving) spring rates and crappy damper cartridges. That's a perfect recipe for a crappy ride.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Tokay444 (09-04-2018)
Old 08-31-2018, 07:42 PM   #63
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
AGAIN.....
GO BACK AND READ WHAT THE OP DID. FFS
It wasn't typical messed up preload on all four corners.
He had completely fucked up the preload in a single coilover.
He essentially has ZERO compression in the right rear, which would 100% make it bounce and ride like shit.
My dipshit friend did the same on his miata. It too rode exactly like the OP said his car did.
#ENDTHREAD
EDIT:
Here, I'll make it easy.....
Originally Posted by Lakitu View Post
I think I've found the issue... there's a 1" gap between each spring coil on the driver rear coilover, but every other coilover has about 2" between each spring coil.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
evomike (08-31-2018), MCTeeJ (09-03-2018), Yoshoobaroo (08-31-2018)
Old 08-31-2018, 10:16 PM   #64
evomike
Drives: frs
Nah dog it rides like shit because he fucked up preload and didn’t align the car, but I get it reading is hard.
Old 08-31-2018, 10:29 PM   #65
Yoshoobaroo
TRACKBREAD
Suggestions on suspension upgrade over BC
Originally Posted by x808drifter View Post
AGAIN.....
EDIT:
Oh shoot! I totally read that as 'my coilovers have a different gap between the coils than other brands.'
My bad. I thought well sure, but the number of coils in the spring being different shouldn't make it ride like shit.
Dude, reading is hard apparently.
*bonk* 🤣
Old 09-01-2018, 12:42 PM   #66
wparsons
wparsons's Avatar
I call BS on that. Should he have had it aligned after a few days, absolutely, but that's not going to fix the ride quality.
Proof? I put my KW V3's in with them set to the height I wanted based on the recommended highest height in the manual (highest recommended setting is 20mm lower than stock, I wanted 25mm lower rear and 28mm lower front), I also put in different camber bolts than before (SPC lower, stock lower bolts in the upper holes). I drove it for a couple weeks to let the springs settle (my commute is ~7kms, all city, wasn't worried about tire wear or anything).
After settling I set the ride height (with my weight in the car), two corners were out more than 1/4". Corrected that, went for an alignment. RF was at -3.8*, LF was at -2.7*, toe was all over the place both front and rear.
I knew the alignment was off, but the car was absolutely NOT bouncy or jarring, and wasn't pulling all over the place over bumps. Would I track it or drive it hard like it was, no, but it tracked straight on the street and at 60% of the limit you'd never know it was that poorly aligned.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
strat61caster (09-01-2018)
Old 09-01-2018, 01:48 PM   #67
evomike
Drives: frs
There is no way your car tracked straight with those specs
Old 09-01-2018, 04:50 PM   #68
strat61caster
strat61caster's Avatar
I've had terrible alignments that were downright dangerous when driven hard feel fine on the freeway and around town.
#diylife
Doing a full coilover install on this car doesn't really affect the alignment on this car, it'll still be within spec in my experience. Adding camber bolts, control arms, camber plates etc will affect it, but for the bcs that would just throw off front camber. If it's a degree off, sure, you'll have to go down the street with the wheel at 5 degrees (I had a camber plate slip on the freeway two years ago after hitting a bump) but it had literally zero impact on "ride quality"
ineedyourdiddly
Old 09-01-2018, 07:23 PM   #69
wparsons
wparsons's Avatar
Sorry, but you're wrong. Toe was all over the place too, along with the steer ahead.
flickr
Old 09-01-2018, 07:37 PM   #70
86MLR
86MLR's Avatar
It would be nice if the OP had the BC's setup and aligned, then post his view on them.
Exhaust Upgrade Suggestions hosfordbrandon Engine, Exhaust, Transmission 6 03-27-2016 01:47 AM
Looking to upgrade rear sway bar, any suggestions? Str8Ghostin Tracking / Autocross / HPDE / Drifting 8 02-22-2015 11:40 AM
Suggestions for more horsepower! Turbocharger upgrade + more! forzajuve Forced Induction 14 04-10-2013 09:51 PM
Michelin/Enkei upgrade + more. Community suggestions welcome! forzajuve Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 03-29-2013 08:14 PM
