Old 02-26-2018, 02:48 PM   #57
Originally Posted by JERM^ View Post
Yea will do and next diagnostic will likely be as per @e30kawi.
That would be the next step yes. If that doesn't do it then check the starter. Have it tested before you buy a new one though.
Old 02-26-2018, 03:24 PM   #58
humfrz
Be prepared for more chasing. Never hit the same spot twice. When you find it, you'll know it.
That's what mrs humfrz used to say ........
humfrz
Tcoat (02-26-2018), Ultramaroon (02-26-2018)
Old 02-26-2018, 03:39 PM   #59
humfrz
When did you make it that far?
Oh wait you didn't specify which "50s"
Ahhhh......YES! When a horse power was a horsepower (at the hoofs).
Of course, a good snort of ground opium poppies would enhance their performance .......
humfrz
Old 02-26-2018, 04:32 PM   #60
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Use dielectric grease to protect them
The Following User Says Thank You to guybo For This Useful Post:
Tcoat (02-26-2018)
Old 02-26-2018, 04:35 PM   #61
This is the better choice for durability.
Old 02-27-2018, 10:32 PM   #62
JERM^
JERM^'s Avatar
Drives: WRB BRZ Aozora 15'
So... That didn't last long.
All was fine, but today off work, first press, click, car stayed in ACC+. Push again, start right up...
Think it's that coil?
JERM^ is offline   Reply With Quote
Old 02-27-2018, 10:43 PM   #63
Have you had the battery draw tested? Have you checked the connection to the starter?
Old 02-27-2018, 11:01 PM   #64
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's not the battery.
Old 02-28-2018, 12:42 AM   #65
humfrz
Yes, definitely have the battery "load tested". Any auto shop can do that. Doesn't cost much.
humfrz
Old 02-28-2018, 12:43 AM   #66
humfrz
OK, smarty pants, if it's not the battery ..... what is it ??......
humfrz
Old 02-28-2018, 01:37 AM   #67
Ultramaroon
not playing cards
Oh, please. You need way better bait than that. As well as it cranks when it's working, there's no way it's the battery. Might be a dead spot on the commutator but, unless it's acting up and OP knows how to troubleshoot, it's a crap shoot.
The list of shit that could be the problem is a lot longer than what is not. It's not the battery.
humfrz (02-28-2018)
Old 02-28-2018, 02:12 AM   #68
humfrz
Well, if I were the OP, I'd still have the battery load tested. If it passes, then move on down the line. If it doesn't, buy a new battery.
humfrz
Old 02-28-2018, 02:20 AM   #69
Ultramaroon
not playing cards
humfrz
It's an intermittent connection. You and OP can waste time and energy, as well as risk dropping and ruining a perfectly good battery. I'll carry a multimeter along in the car while waiting for it to act up again.
Old 02-28-2018, 03:19 AM   #70
humfrz
OK .......OP, get yourself a multi-meter and a cell phone with Ultramaroon's cell phone number programmed into it and just cruise down through Toronto.
Now, when your car fails to start, ring up ol Ultramaroon and he'll talk you through a trouble shooting procedure.
Just tell those dudes on the street to back off ....... and put your wheels back on your car! .........
humfrz
ECUTek Cable, Engine Mounts, Raceseng Crank Pulley, Intake Tube, Light Battery Kit jonesy Engine, Exhaust, Bolt-Ons 1 08-25-2017 11:46 AM
Crank No start (Not battery issue) NEED HELP cnxmist Issues | Warranty | Recalls / TSB 19 07-28-2017 06:44 AM
Engine Won't Crank - Battery or Worse - Sanity Check StrangeLove4791 Issues | Warranty | Recalls / TSB 16 02-23-2017 12:18 AM
KW V3: 16 clicks for compression? h3opama Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-02-2015 09:01 PM
FS Phantom Supercharger PC680 starter battery, new display-2050 alex345 Engine, Exhaust, Bolt-Ons 20 04-12-2015 02:00 PM
