| View Poll Results: How important is a factory LSD to this car? | |||
| Meh... |
3 | 3.80% |
| Nice to have. |
17 | 21.52% |
| Offer as an option. |
19 | 24.05% |
| Make or break. It's gotta have one. |
40 | 50.63% |
| Voters: 79. You may not vote on this poll | |||
#57 |
Drives: '06 AM V8V Coupe
Yes I figured that much, but that kind of statement is a bit difficult to ignore...
When they drove the Exige around one of the tires was spinning through a corner, which is why Clarkson made the comment. Not saying I don't trust you though, so you say it doesn't make a difference? Any other opinions? |
#58 |
Drives: 2008 XRunner
#59 | |
Very interesting. I didn't believe it at first. But the thing about these is the fact that they are a Limited slip until you turn it on, then it's a spool/full locker. Which if you're at the track is very bad. Might be fun in the back of a 4Runner though lol. |
#60 |
professional smartass
Drives: 16 speed mountain bike...
I suppose if you want the "cheap bastards locked rear differential" you can always open up up the differential housing and weld the two drive axels together. Going around corners will be a real adventure then!
#61 | |
Hot Dog
Drives: quicker than arghx7
Basically, an LSD will mask a crappy car and/or a crappy driver, but a good driver with a good car minimizes the need for an LSD. Of course this is primarily with rear-drive cars. Front drive cars almost always need an ATB to put power down, though it's at the expense of delicate steering feel. In the end, I hope an LSD isn't critical for the FR-S to handle well.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#62 |
Drives: 04 PSM WRX Wagon
But an LSD wouldn't "hurt" a well-balanced car with a good driver, right? If not, then why not just include the LSD for the potential benefit (unless we're trying to minimize cost)?
#63 |
Hot Dog
Usually. A well specified LSD for the application will almost always lower lap times, however it may do at the expense of feedback and driver emotional purity. Too many manufacturers get hung up on comparative specifications and ignore the most important facet; driver satisfaction.
With any luck Toyota specifies a good LSD [if their latest press conference is an indication of production intent]. A quality clutch-pack would be best for rear-drive; ATB's in the rear axle tend to be less communicative and less pin-point precise in terms of car control in than a clutch-pack. The problem with my hope is worthy clutch-pack LSD's are expensive, and cheap ATB's like Torsen's are affordable with reasonable quantities of scale.
#64 |
#65 | |
Drives: N/A
True, but that's not something you want to do on a brand new differential is it? Or on a corner carving DD. |
#66 |
Drives: 2001 Celica GT-S
As much as I want it, get real, it's Scion. I want an LSD, but I want it to come standard. I wouldn't pay $3000 for it as a dealer option. But again, it's going to be a Scion. Their #1 is 16-21 hipster wannabes who probably don't know what an LSD is.
#67 | |
You don't want a Locked up Rear on anything that will see turns over 10 MPH. It works great when you are climbing over rocks at .5 MPH but when turning at speed you have to let the wheels spin at different speeds. |
#68 |
Drives: BMW 325i (E46)
I'm hoping we'll get a torque sensing rather than locking differential.
#69 |
Softparker
Drives: 2002 Mazda Miata
I think it would be nice to have an option for an open diff. just for folks that want to put in their own specific setup. However, I voted for "it's gotta have one" simply because I don't think Subaru can go from AWD on every model to an open diff. for this car and it would be too easy to use the lack of a standard LSD as an argument against what this car is supposed to be.
It might not be the best unit out there, but I don't think they're going to drop the ball on this. |
#70 |
So I was talking to a buddy of mine about this thread because I found it all very fascinating. He made an excellent point.
An LSD is there to help with Cornering. As you go through the corner your inside tire is going to lift and not get as much traction. It doesn't matter how sticky your tires are if you can't keep them on the ground. Now we all know that on an open diff the power is going to go to the wheel with least resistance. The LSD helps keep the power even so you are able to get through the corner faster with more control. Then when you exit you have the same power going to both wheels for great power exiting. Of course it's only going to make a small difference when you're racing balls out. A few tenth's of a second maybe. But still I thought it was interesting to note that this car is going to be all about the corners. So I think they will be including a LSD in the package standard. |
