Old 04-09-2017, 10:23 PM   #57
steve99
Originally Posted by Boofneenee View Post
i dont feel that the environmental conditions for the stock tune are fair. IAM 0.2? FLCK -3.0? pulling a lot of timing. Something must have happened,.. driving really hard?
I cant understand how this is a fair comparison..
No that was just normal driving on poor quality fuel, our fuel in Australia is almost as bad as that iam around 0.5 and heaps of knock, that was pretty well the reason I started messing with tunes to make my car work better on our poor quality fuels
Boofneenee (04-11-2017)
Old 04-09-2017, 10:38 PM   #58
Somerandom18
Drives: 2017 manual BRZ
What does iam stand for?
NE Ohio represent.
Somerandom18 is offline   Reply With Quote
Old 04-09-2017, 11:23 PM   #59
stevo585
Drives: White 2014 BRZ
IAM = ignition advance multiplier. That means full timing. Which is around 20 degrees iirc in the stock map.
If my local fuel was that bad Id blend with toluene or some other octane booster like klotz. My local 93 AKI is pretty good. I'm able to run ~24 degrees timing up top (with no FLKC) and hit MBT through the midrange. E85 can run that up top you can actually go past 30 which is usually too much.
With the turbo now the most I can run on 93 is about 14 degrees to be conservative...
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
The Following User Says Thank You to stevo585 For This Useful Post:
Somerandom18 (04-09-2017)
Old 04-09-2017, 11:27 PM   #60
Somerandom18
Awesome, thank you. Is it possible to view this in torque pro?
NE Ohio represent.
Old 04-10-2017, 01:24 PM   #61
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by DirtySouth86 View Post
Actually, federal law mandates that the catalytic converter(s) and engine control computers for vehicles 1995 and newer are warrantied by the vehicle manufacturer for 8 years or 80,000 miles (whichever occurs first) from the original in service date of the vehicle. On those 2 items, it does not matter what the original bumper to bumper or powertrain warranty periods are, because they are covered regardless.
Yes, but in this case the ECU is replaced as a matter of repair procedure, not because the ECU is defective.
So the discussion around powertrain and basic warranty is the key. The Clean Air Act has no coverage or relevance here.
-alex
Old 04-10-2017, 07:58 PM   #62
mav1178
mav1178's Avatar
nailed it.
FYI. The ECU IS covered under the warranty and my ECU was replaced 2x during the repairs. Here is a clip and paste from the manual for proof from the limited power train warranty:
Engine
Cylinder block and head and all
internal parts, timing gears and
gaskets, timing chain/belt and cover,
flywheel, valve covers, oil pan, oil
pump, engine mounts, turbocharger
housing and all internal parts, super
charger housing and all internal parts,
engine control computer, water pump,
fuel pump, seals and gaskets.
The cam sensor is also covered under warranty
I just read the entire Warranty booklet for 2014 for Subaru. It blanket covers all models of Subaru including BRZ.
Unless Subaru has a completely different warranty coverage, it does NOT cover electronics under powertrain.
The ECU is already covered by the mandated Federal warranty.
I'm just going off what you described... P0018 is a sensor issue and if, during the process of repair, you replace the ECU as part of the repair procedure, then the replacement part is replaced as covered by normal warranty and not powertrain. P0018 is NOT a "ECU defective" issue so that portion of the emissions warranty does not come into play.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Tcoat (04-17-2017)
Old 04-11-2017, 12:39 AM   #63
stevo585
NE Ohio represent.
Yes it is what I use to monitor things when not tuning on ecutek.
Old 04-17-2017, 07:23 AM   #64
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
I am a second owner of a 2013 FRS with 65k miles, bought it with 30k miles 3 years ago. I've only ever had two issues with this car, first i had to replace the clutch and flywheel around 35k miles (not covered under warranty because of excessive wear, turns out the previous owner did not know how to shift, I bought the car from an older woman). This was about 2.5k
The other issue was the wheel studs kept breaking every time I took the tires of, after the first time it happened i replaced only the broken studs. When it happened again I replaced all of the studs on all the wheels, problem solved (for now).
I should also mention that I don't baby my FRS, i drive the damn thing (sometimes my foot gets heavy) but I think the car is holding up pretty good considering that it was the first year of production.
Sent from my SAMSUNG-SM-G930A using Tapatalk
FRS13_ is offline   Reply With Quote
The Following 3 Users Say Thank You to FRS13_ For This Useful Post:
HKz (04-20-2017), nikitopo (04-20-2017), Tcoat (04-17-2017)
Old 04-24-2017, 07:46 AM   #65
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
-alex
http://www.ft86club.com/forums/showthread.php?t=45844
Here is a tsb for the cam sensor. Scroll down till you see a giant red box that says "this is covered under the limited power train warranty"
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 04-24-2017, 11:22 AM   #66
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
That is not for the P0018 issue though.
I got this issue last week @47K miles... I will be taking mine to the dealership to see if I can get it fixed under warranty... but we shall see.
Cartman is offline   Reply With Quote
Old 04-25-2017, 01:49 AM   #67
mav1178
mav1178's Avatar
So tell me... where on that TSB does it say "P0018"?
Also, is your VIN BEFORE the applicable VIN on that TSB? If so, perhaps it will apply. If not, you referencing the TSB shows that you do not have a clear understanding of how TSBs work.
Old 04-25-2017, 08:28 AM   #68
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
No no, I popped error code p0018 and brought it to the dealer. The 1st approach they took was to replace the cam sensors. If that's what they did then I would assume it was covered because this tsb states it is.
I didn't get charged for them doing it
FRS
Old 04-25-2017, 09:51 AM   #69
lizbrayan
Drives: '15 Scion Frs Steel
I make 2 years with my 2015 in july, i am currently at 28,000 miles. I have had 2 codes appear in the life of the car, all before mods such as headers and tune and the whole deal. The code was for the camshaft position sensor. Appeared once after i got gas and once sitting in traffic. Took it to toyota, they had the car for 2 days and blamed it on an open gas cap. As a mechanic for a living i know this wasnt the case but i rolled with it. They cleared it and it has never came back. (Knock on wood). Point is these cars have a weird temper they either like you or they dont. Toyota made a mistake working with subaru with this car and the early 2013/2014 cars clearly show it. Never buy a first gen car.
lizbrayan is offline   Reply With Quote
Old 04-25-2017, 12:25 PM   #70
mav1178
mav1178's Avatar
I stand by my previous statement, that you have a poor understanding of how TSBs work.
Exhaust disappointment please help!!! Fred Flintstone Engine, Exhaust, Transmission 10 04-04-2017 05:11 PM
Oft disappointment bRZillian7 Software Tuning 45 09-30-2015 05:19 PM
Valenti Tail lights disappointment/question kincito Cosmetic Modification (Interior/Exterior/Lighting) 27 07-02-2014 09:47 PM
Pre-Order Disappointment woes Draco233 BRZ First-Gen (2012+) — General Topics 16 03-03-2012 04:31 PM
BRZ pricing disappointment thread dsgerbc BRZ First-Gen (2012+) — General Topics 42 02-29-2012 02:37 PM
