Old 11-18-2019, 10:30 AM   #57
pcs
bump - anyone else using these? How have they held up?
how long do the rod ends / sphericals last, or how often do they need to be replaced?
pcs is offline   Reply With Quote
Old 11-18-2019, 01:04 PM   #58
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Have had these on my car for about 3 weeks now, along with rest of the kit from SPL. Thanks to these I was able to eliminate my cross caster in the front and run more positive caster allowing me to reduce static camber and still get fantastic driving feel. With all solid suspension everything just feels more direct and immediate, no waiting on weight transfer. I’m loving my car right now.
Tristor is offline   Reply With Quote
Old 11-24-2019, 09:09 AM   #59
Yoniyama
Drives: BRZ 2018
Lower (unsprung) weight, greater strength, what's not to like (except for the price tag)?
I hate it when lower weight is quoted, without disclosing how much weight was lost. Surely the vendor must have done the comparison, but just won't say it. Perhaps the weight loss was too little to quote?
Higher strength? Sure, by how much. Again, the vendor must know this, but just won't say it. Is it because the increase in strength is too little to mention?
Yoniyama is offline   Reply With Quote
Old 11-29-2019, 10:10 PM   #60
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by whataboutbob View Post
My front LCAs showed up. These things are beautiful.
@whataboutbob, how are these holding up for you?
Old 11-30-2019, 09:05 PM   #61
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
so yeah what is the weight difference?
SuperTom is offline   Reply With Quote
Old 11-30-2019, 09:38 PM   #62
new2subaru
Weight Weenie
Drives: 15 FR-S
There are a few pieces that were weighed here. No FLCA
http://www.ft86club.com/forums/showp...&postcount=297
I did weigh my SPL RLCA and it was less than OE but not by a lot. I have the number at work.
Old 12-01-2019, 07:54 PM   #63
whataboutbob
AutoX-10/10ths every run
They are working fine. 10/10, would buy again.
Build thread:Here
Old 12-01-2019, 08:43 PM   #64
new2subaru
Weight Weenie
Drives: 15 FR-S
Awesome, thanks for the reply
Old 12-02-2019, 05:07 PM   #65
Sleepless
Drives: 2016 FR-S
Same here
Sleepless is offline   Reply With Quote
Old 12-02-2019, 09:20 PM   #66
pcs
Originally Posted by Sleepless View Post
Same here
what would you guys say is the most notable difference in driving feel when the car is pushed with the FLCA?
Old 12-03-2019, 01:28 PM   #67
Sleepless
Drives: 2016 FR-S
Mine replaced worn out stock LCA so the difference was night and day
Old 12-04-2019, 10:01 PM   #68
whataboutbob
You're not going to get bushing deflection which will improve the turn in feel in my experience. Also they provide camber, caster, and bump steer adjustments which can let you optimize your setup for even more grip.
Build thread:Here
Old 01-02-2020, 08:53 AM   #69
TGIRWD
Drives: 10 Series FRS M/T
For those still interested in weight - the SPL arms and hardware weigh in at 2540 grams per arm. My OEM arms, with whiteline subframe bushing, ball joint, and anti dive, caster bushing weighed 2727 grams. So with both of them, that's a savings of ~375 grams - about .8 lbs. Nothing major - but not necessarily the main reason for installing these.
TGIRWD is offline   Reply With Quote
Old 01-02-2020, 10:58 AM   #70
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Originally Posted by TGIRWD View Post
For those still interested in weight - the SPL arms and hardware weigh in at 2727 grams per arm. My OEM arms, with whiteline subframe bushing, ball joint, and anti dive, caster bushing weighed 2540 grams. So with both of them, that's a savings of ~375 grams - about .8 lbs. Nothing major - but not necessarily the main reason for installing these.
Am I reading something wrong, or does this mean a weight gain?
OEM - 2540 grams each - 5080 grams total
SPL - 2727 grams each - 5454 grams total - 374 g more than stock?
JohnJuan is offline   Reply With Quote
New Turbo Kit Sneak Peek(Ptuning) kanundrum Forced Induction 1046 10-26-2017 07:02 AM
Part 1 of our FR-S / BRZ Turbo Kit Sneak Peek Rev Works Forced Induction 64 03-12-2014 01:21 PM
A Sneaky Sneak Peak? White64Goat Other Vehicles & General Automotive Discussions 2 02-20-2013 04:03 PM
Sneak peek at new 57Xtreme? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-07-2013 02:24 PM
Sneak preview at the Motiv Concepts Exhaust MotivConcepts Engine, Exhaust, Transmission 36 11-21-2012 08:17 PM
