#6819 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Check out xim4.com. I've used their older products. Fantastic product and company.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#6820 | |
Other than that, something that is zero lag, no exhaust gases, no pulley+belt and no electricity, where are you going to get the energy source from? And how are you going to convert it into air pressure? then combustion? Do tell, at least in concept as I hope it would be more feasibly interesting than your previous suggestions.
#6821 |
Drives: GTX 86 2014
how i wish rob will go international or sell this amazing upgrade overseas, im so obsessed with this upgrade because of your feedbacks. how i envy you guys
#6822 |
Drives: Scion FR-S A/T, Whiteout
Can it be new batch time now?
#6823 | |
Drives: 2013 Asphalt 6spd
Still a scuba tank with a high pressure air pump would be a similar concept to the ESC. Might take a special exhaust housing and wheel, but no extra heat under hood, no oil or turbo exhaust manifold needed. The pump shuts itself off at desired pressure. A simple pressure regulator between the the tank and the turbo "exhaust" wheel would maintain a constant pressure thus a constant boost no matter how much air the engine needed, so constant boost through the the whole rpm range. With an electric air valve, you could hook it up with a full throttle switch. Based on the speed of the valve you might not need a wastegate. BOV would still probably be necessary. All this is theoretical though as I don't know how big, heavy, power hungry a high pressure air pump would be, or how much flow would be necessary from the tank and the pressure regulator. Probably not feasible or someone would have already done it, but an interesting concept imo after looking it up, a hp pump is too large. If this system did work, It would have to work like nos, and change out bottles as they emptied. Plus even at 3000 psi, I don't know if there is enough volume to spin up a turbo, or what kind of lag you would get.
#6824 |
Drives: FR-S,GTI
I thank everyone for their help and suggestions. I checked them all out and came up with nothing.
Finally broke down and PM'd Rob. His usual outstanding customer service strikes again. I got an almost immediate response with some things to check out. One of the things he wanted me to check was to turn off the volt meter switch and turn on the ignition then turn on the volt meter switch and listen for the controller to beep. There was no beep only the fan turning on. But something I did notice was a noise coming from the MAF area. Can someone check and see if this is normal? Don't start the car just turn the ignition switch all the way on and listen for noise around the MAF (intake manifold). So I'm going PM Rob again and see what to do next. Oh, one thing I forgot to mention is what I was doing when the ESC failed. I was doing burn outs because I'm getting new tires on Monday and figured "what the hell might as well take these down to the belts". My plan was to do a flat foot shift from 1st to 2nd and 3rd and see if I could spin the tires continuously all the way thru 3rd gear. But that's when the car went into wimp mode. And it's been in wimp mode ever since. |
#6825 |
Drives: FR-S,GTI
I'm back to NA. I had to jury rig the intake back on because I'm not going to replace the stupid sound tube. Looks like I might be NA for a while so I need to make an alcohol run. No way I'm going back to NA on gas. I went through 30 gallons of E85 last week I was having so much fun with the new tune. I got 2 more gas cans so now I can transport 40 gallons at a time.
#6826 | |
Pull out the maf. One member had filter particles on the maf and it caused issues.
#6827 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
I know this question has been answered before even when I posted it. I have the opportunity to buy it used from someone and I would like to hear your answers just one last time. How close to stock does this car drive when the boost is not engaged? This is very important to me as I am driving at partial throttle more often than I ever drive WOT engaging the boost. I don't want to lose the underpowered but snappy throttle response from 2.5 to 3.5k that I describe as the "playful area" Fenton has said you lose about 10hp up top around 6k which does not matter to me. However their was a dyno posted a few pages back by Jac showing a comparison dyno of stock vs this system with the DR system. This dyno clearly showed that stock had more tq and HP in that playful area with the DR exceeding stock around 4k and up. Maybe he had an older system/ controller ? Thx in advance
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#6828 | |
Full throttle Electric Supercharger Build Thread
Without activating the unit (but still on so that drag reduction is functioning) there is no difference on the car. It feels and drives the same. Activate the the throttle switch and you have a very fun car now. Trust me it's worth it, and I know nlowell has taken care of the system. It's a good buy.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel Last edited by Sojhinn; 07-27-2014 at 01:48 PM. |
#6829 | |
Here is my DR graph. |
#6830 | |
Drives: 2013 Subaru BRZ Premium
#6831 | |
Go-Kart Enthusiast
FRS
#6832 |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
