Old 06-12-2017, 08:57 PM   #659
wooly35
Drives: 2014 Scion FR-S LS3
Originally Posted by DustinS View Post
Forgot to post up a picture of the steering rack.
wow... I trimmed mine back the other day, but I still wish I had more room between them. That is exactly where my oil pan cracked.
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
Old 06-12-2017, 10:18 PM   #660
all4spl
This is terrible. These are suppose to fit and they were suppose to have "redone the design to fit better"
all4spl is offline   Reply With Quote
Old 06-13-2017, 06:12 AM   #661
kurty85
Drives: 2014 FRS LS Swap
I have the same issue. My oil pan is touching the steering rack. Trying to see how to lift the engine slightly. I am using cx racing mounts with the subframe weld pieces removed like vorshlag. I was able to move the engine back to the 3rd hole on the cxracing mounts, which is about 2-3 inches further rearward. But it involved cutting the valve cover and then using a 90 degree piece of aluminum to close the hole up(clearing the rocker) to clear the clutch master cylinder which was hitting the valve cover. Makes it so I almost don't have to have a gto shifter. I am using a t56 from an 02 Camaro. Hoping I don't have any weird vibrations when running soon.
kurty85 is offline   Reply With Quote
Old 06-13-2017, 06:22 AM   #662
kurty85
Here's the pics. Hard to see the pan pic but easy to see the placement.
Old 06-13-2017, 09:32 AM   #663
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Yeah I trimmed mine on both sides. It's still super close to the oil pan. The actual crossmember may be hitting the oil pan as well, because there is almost no room. I would say a few sheets of paper haha. They are going to need to supply and oil pan so they know it fits, this is almost unacceptable.
Got the A/C Compressor in! Just needed a slight tweak of the dipstick with a hammer.
DustinS is offline   Reply With Quote
Old 06-13-2017, 11:36 AM   #664
ILLSMOQ
Drives: 2017 WR BLUE BRZ
What about a sheet metal shim under the engine mounts to lift the motor a touch?
I'm sure the motor twists a bit too under a load.
b.jpg[/img]
ILLSMOQ is offline   Reply With Quote
Old 06-13-2017, 11:38 AM   #665
DustinS
DustinS's Avatar
Intake hits the hood already. The shim would have to be thin enough that I don't think it would be worth it.
Old 06-19-2017, 10:17 AM   #666
DustinS
DustinS's Avatar
Well. I may be looking at pulling the engine and transmission here soon.
The transmission is still leaking trans fluid and I still can't find where it is coming from.
The engine lifters are still really loud and I suspect something is wrong there. I don't have any experience with LS engines, but it is really loud. I will try to get a video of it.
Oil Pressure is also too low for my liking. I just assumed it was okay because engine was new, but that was not the right way to go about it. 20psi at warm idle, was 30psi cruising at 2k rpm I haven't ever really seen it past 40psi hot. I will pay more attention to it today. Thinking it is best to have either Texas Speed Check it over just in case, or a local shop I trust look it over.
Old 06-19-2017, 10:28 AM   #667
all4spl
Ya oil pressure doesn't look right. I had the same issue with my engine. 19-20 psi at idle and never got over 40psi regardless of the rpm. Turned out to be a spun cam bearing.
Old 06-19-2017, 10:43 AM   #668
DustinS
DustinS's Avatar
Contacted Texas Speed on how I should go about getting the engine checked. The engines include a 1 year unlimited mile warranty as long as the engine is tuned by them.
Old 06-19-2017, 11:00 AM   #669
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
I've been using the GTO front sump pan for two years now. I get all sorts of vibrations because as mentioned above there is only a few sheets of paper thickness between crossmember/steering and pan. I'm sure my pinion angles are terrible too.
I also had terrible oil pressure shortly followed by spun rod bearing.
Replaced all the bearings and a new crank and I've been getting 30+psi idle HOT.
wutsaiu is offline   Reply With Quote
Old 06-19-2017, 11:08 AM   #670
gtpvette
Drives: 2015 FRS - FFR GTM
Did they do a mail order tune with the motor????
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 06-19-2017, 11:10 AM   #671
DustinS
DustinS's Avatar
Engine comes with a premade Harness and Pre-Tuned ECU
Old 06-19-2017, 06:33 PM   #672
Zer0
Drives: 2015 frs
I was looking into the Canton oil pan part 15-276 I'm hopeful it will have a little more clearance. Do you guys know anyone running this pan?
Zer0 is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
