Old 12-16-2012, 04:45 PM   #645
fiveoneone
Drives: 86 White GTS
This guy is running +30 for your reference
http://www.ft86club.com/forums/showthread.php?t=11258
fiveoneone is offline   Reply With Quote
Old 12-17-2012, 03:35 AM   #646
g0lden
Drives: 2013 Scion FR-S Argento
looks decent :-)
g0lden is offline   Reply With Quote
Old 12-17-2012, 09:00 PM   #647
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Will this fit in my car
lower on BC coil overs
18x10 +18
235/40/18
Old 12-17-2012, 09:59 PM   #648
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
18x10 +18
235/40/18
widebody?!
18x10+18 going to stick way out...
http://www.1010tires.com/WheelOffsetCalculator.asp
ill86 is offline   Reply With Quote
Old 12-18-2012, 05:05 AM   #649
ft_sjo
Drives: GT86
Question Anyone running a 245/40/17 all round?
Curious as to fit, standard or lowered ride height, and with what ET and tyre choice?
Old 12-18-2012, 07:34 AM   #650
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Yes.
Weds TC105N 17x9" +35. Hankook R-S3s. Stock ride height so far (coilovers coming). No issues whatsoever.
GTB/ZR-1 is offline   Reply With Quote
Old 12-18-2012, 11:11 AM   #651
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
This is the size I want. No rubbing at all?
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 12-18-2012, 11:27 AM   #652
GTB/ZR-1
GTB/ZR-1's Avatar
None
Old 12-18-2012, 12:58 PM   #653
wparsons
wparsons's Avatar
If you check the fitment guide that is stickied there's a few people running that setup without issues on both stock height suspension and also stock struts with lowering springs.
flickr
Old 12-18-2012, 01:02 PM   #654
MKIV
MKIV's Avatar
Drives: 4 tires mounted to 4 wheels
No issues here either. 17x8 +45
I've only been wrong once, and that's when I thought I was wrong.
MKIV is offline   Reply With Quote
Old 12-18-2012, 01:15 PM   #655
ft_sjo
Drives: GT86
Are you really running a 245 on a 8" wheel?
Old 12-18-2012, 01:24 PM   #656
MKIV
MKIV's Avatar
Yep.
Old 12-18-2012, 01:37 PM   #657
Foobar
SLO NO MO
Foobar's Avatar
245 is good from 7.5 - 9 inches.
Old 12-18-2012, 01:42 PM   #658
ft_sjo
Drives: GT86
Not really, the tyre will behave differently at each of those different widths. Just because it will physically fit doesn't mean it's the right thing to do.
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
