Old 07-05-2014, 01:39 PM   #6525
fenton
Originally Posted by Sojhinn View Post
@fenton now that you are back to the 250 what do you think?
I have to let this motor break in a bit more before I will know. This is a brand new motor....Rob said it can take 3 weeks or so before they reach max efficiency.
Initial impressions are the 250 is stronger down low and the boost comes on quicker. The 250 also doesn't surge like the 300 does so that helps for smoother power delivery. You can see from the logs that even though the 250 isn't broken in it is getting almost the same numbers even on the top end.
Also with the 250 my voltage never drops below 23 which is better for recharge.
If I had to guess the 300 is good for 10 HP from 5500 to 7500 but will lose 15tq from 2500 to 5500 and it engages slower do you don't get that kick.
I will post more impressions as time passes. I posted logs on shivs thread.
fenton is offline   Reply With Quote
Old 07-05-2014, 01:43 PM   #6526
fenton
Oh and shifting with the 250 at Wot is very sharp. Boost comes on right away in the next gear. Sometimes with the 300 I would feel a slight pause.
Old 07-05-2014, 04:51 PM   #6527
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I wonder how much a ceramic wheel would cost?
Old 07-05-2014, 10:36 PM   #6528
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Alright, first about Dynos - everyone is different, blah blah blah. A stock 2015 WRX does 220 on that dyno, a Stage 1 2006 did 180. Keep in mind these numbers (and most dyno numbers) are corrected for our crappy altitude. If I ran on a DynoDynamics unit in Vancouver it should be the same'ish. I don't get another 15% hp.
The stock car in the chart above is not mine, they just found one to compare with.
I also did 2 curiosity runs with the latest Shiv tune file, etc but with the Phantom turned OFF. The compressor is a obstruction obviously, and seems it costs about 10hp turned off. Also was curious how rich it would run with no boost.
Mods are Phantom 1.5 pack, Openflash Header, stock exhaust, openflash tablet (latest 1.5 91 flash) on 91 gas. I may try 94 next time but since it doesn't seem to be pulling timing, and I can't up the boost there's probably not much point.
And here's the Datalog file - adding boost was not clear, so it's not on the chart.
http://datazap.me/u/khyron/2014-07-05-dyno?log=0&data=1
Khyron686 is offline   Reply With Quote
Old 07-05-2014, 11:10 PM   #6529
Robftss
Drives: VW
^ Great!
+ 23% Peak HP
+ 50% best delta TQ.
Yes with SC 'off', -10 HP @ high rpm, ~ 0 loss at ~ 5000 rpm (not enough constriction to become a restriction until higher rpms (flow)). This is where DR will compensate.
HP gains look pretty consistent across the band.
A little leaner up top might add a couple hp's.
Very good for an OTS tune.
Thks, Rob
Robftss is offline   Reply With Quote
Old 07-06-2014, 01:43 AM   #6530
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Do you guys think it would hurt to take the cap off of the side of the intake box (the old resonator location where you drill the rivets out)? I realize that it would draw in some warmer air from the engine bay, but the air filter is still in line after that hole.
Assuming it would fit (haven't measured the area around the hole), you could also clamp something like this on there. That is, if you're worried about extra debris getting in:
http://www.summitracing.com/parts/knn-rc-2580
Purpose: Amplification of sweet, sweet compressor noises.
Thoughts?
alexand3r is offline   Reply With Quote
Old 07-06-2014, 01:55 AM   #6531
fenton
Thoughts?
I don't think you would get anymore compressor noise but I could be wrong. I would love more induction noise.
Old 07-06-2014, 07:03 AM   #6532
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Originally Posted by VR46 View Post
Question - with ESC + Borla UEL + OFT, I have gotten a CEL with code P0420 (Catalytic Converter Efficiency Below Threshold) on 3 occasions in the last 4 months. I had thought that the OFT tune was supposed to disable that. I used Torque to clear the code and it doesn't come back within a short amount of time. If I had to spitball a non-scientific guess as to when it happens I'd say within a short time of engaging the ESC at a questionable (low-ish) RPM.
Anyone experiencing anything similar? @shiv@vishnu - am I correct that this fault code should be disabled by the OFT tune?
Originally Posted by s2d4 View Post
No, he left it on for leak detection.
If you are sure that your header is not leaking, you can always just disable it.
Just to close the loop on this - I found this in another thread, posted by @shiv@vishnu on 6/24:
Originally Posted by shiv@vishnu View Post
The P0420 code is disabled in the ROM file I sent you. So if you are still getting it, it's likely you didn't load the file correctly
P0420 should have nothing to do with fuel formations or exhaust leaks.
The tune I've got right now was supplied to me in early Feb - do the current ESC tunes have P0420 disabled?
VR46 is offline   Reply With Quote
Old 07-06-2014, 10:00 AM   #6533
WNDSRFR
Drives: FR-S,GTI
Here's my latest rear garnish.
I tried to apply Shiv's Vishnu Tuning sticker, but it sticks to the backing paper much better than it sticks to the car. I like to give credit where credit is due. The badge on the front is Toyota. I really have it backwards. Toyota should be on the back and Subaru should be on the front.
Old 07-06-2014, 12:41 PM   #6534
s2d4
s2d4's Avatar
Cheers for the correction.
I remembered people were having leaks and shiv specifically said he was re-enabling the code. Perhaps this is no longer the case or it wasn't quite the same CEL, all good.
Old 07-06-2014, 01:30 PM   #6535
raven1231
Day has been made! Just found an E85 station that is 8 minutes from me Can't wait for the E85 ESC Tune!!!!
Old 07-06-2014, 02:29 PM   #6536
fenton
You guys are so lucky. I would drive 30 minutes out of my way if there was a chance I could get the corn juice.
Old 07-06-2014, 02:31 PM   #6537
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Ok so I won't say I have e85 around the corner. 😁
Installed Mods:
Old 07-06-2014, 02:33 PM   #6538
Sojhinn
Sojhinn's Avatar
@Robftss and @fenton feel free to use my install video anyway you guys see fit. If you want it on your website or on the first post go for it.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
