08-07-2016, 09:15 AM | #631 |
Drives: Toyota GT86
Did you check if P0420 (Cat efficiency) is disabled in the tune?
08-07-2016, 04:58 PM | #632 |
Drives: 2014 BRZ sterling silver
I passed TN OBDII inspection. you have to make sure all your diagnostic trouble codes are turned on except for po420 (cat efficiency) turn it off if you have a catless header. I'm using Shiv's new OFH tune and when looked at my trouble codes in romraider 3 others were turned off for some reason. when you do that you will have too drive it for about 50 to 60 miles then go though the state Inspection.
08-08-2016, 10:17 AM | #633 |
Drives: '13 BRZ
Ive been attempting to do some datalogging but for some reason I am not able to start the recording. Is there a process I am supposed to do to enable the recording feature, or should I just be able to press the record button and everything starts recording?
Thanks |
08-08-2016, 12:15 PM | #634 |
Drives: 2013 Scion Frs 6mt
Should be able to just press the little red circle button
08-08-2016, 01:11 PM | #635 |
Drives: '13 BRZ
08-08-2016, 01:36 PM | #636 | |
Strange... So the little blue button below it doesn't flash? Sounds like some type of glitch? On the diagnostic page there are variables right? Like MAF a/f etc... Shiv should take care of you if you bought it new |
08-08-2016, 03:01 PM | #637 |
Drives: '13 BRZ
That is correct. Nothing happens. Maybe I have to recalibrate my tablet because its not registering me touching the record(all the other buttons work fine)? There are variables on the diagnostic page. I have everything running the way I like it other than having the record feature working. I set up the alarms posted on the original post of this thread and my tablet seems to alarm quite a bit so Im trying to figure out what the issue could be...datalogging would help quite a bit haha
08-08-2016, 07:14 PM | #638 | |
08-09-2016, 08:54 AM | #639 |
Drives: 2016 Scion FRS Raven
How do I know I hav successfully flashed a stage 2 tune? Feels like the car is pulling a bit heavy after my stage 2
08-09-2016, 06:25 PM | #640 | |
unfortunaly you cannot read out the tune with oft. but you could log the tune |
The Following User Says Thank You to steve99 For This Useful Post: | bedabi (08-16-2016) |
08-10-2016, 01:41 PM | #641 |
Drives: 2015 BRZ Limited MT
How risky is the stage 1 91 tune?
My car is only a year old, and i'd like to be able to get warranty work if needed. Any reports of engine issues after running stage 1 OFT tune? |
08-11-2016, 07:45 PM | #642 |
I'm thinking about retuning it. Just flashing the stock ECU then stage 1 then stage 2 if those steps are necessary. With the Tomei headers I'm using a lot more gas it seems like. Idk if that's because I love the sound and I'm just smashing the pedal.
08-11-2016, 08:36 PM | #643 | |
Drives: 2013 Fr-S UltraMarine
Sent from my SM-G920V using Tapatalk |
08-14-2016, 08:24 PM | #644 | |
Drives: 2015 86 GTS
But........to be sure.........you need to log your tune. Read the links in steve99 signature. Totally up to you, but you may want to flash stock tune before you go to dealer for unrelated warranty work. |
Similar Threads | ||||
WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
