Old 08-07-2016, 09:15 AM   #631
Tor
Tor's Avatar
Drives: Toyota GT86
Originally Posted by STV3 View Post
Anyone have issues with passing an OBDII state inspection with the OFT? My mechanic tried numerous times with both the Stage 2 tune flashed and with the stock rom flashed and my car would not send the diagnostic info to the machine for me to pass inspection.
Did you check if P0420 (Cat efficiency) is disabled in the tune?
Tor is offline   Reply With Quote
Old 08-07-2016, 04:58 PM   #632
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
I passed TN OBDII inspection. you have to make sure all your diagnostic trouble codes are turned on except for po420 (cat efficiency) turn it off if you have a catless header. I'm using Shiv's new OFH tune and when looked at my trouble codes in romraider 3 others were turned off for some reason. when you do that you will have too drive it for about 50 to 60 miles then go though the state Inspection.
oldgunfan is offline   Reply With Quote
Old 08-08-2016, 10:17 AM   #633
tinma
Drives: '13 BRZ
Ive been attempting to do some datalogging but for some reason I am not able to start the recording. Is there a process I am supposed to do to enable the recording feature, or should I just be able to press the record button and everything starts recording?
Thanks
tinma is offline   Reply With Quote
Old 08-08-2016, 12:15 PM   #634
Nah
Drives: 2013 Scion Frs 6mt
Thanks
Should be able to just press the little red circle button
Nah is offline   Reply With Quote
Old 08-08-2016, 01:11 PM   #635
tinma
Drives: '13 BRZ
Ive tried that and nothing happens. No indication that anything is recording.
Old 08-08-2016, 01:36 PM   #636
Nah
Strange... So the little blue button below it doesn't flash? Sounds like some type of glitch? On the diagnostic page there are variables right? Like MAF a/f etc... Shiv should take care of you if you bought it new
Old 08-08-2016, 03:01 PM   #637
tinma
Drives: '13 BRZ
That is correct. Nothing happens. Maybe I have to recalibrate my tablet because its not registering me touching the record(all the other buttons work fine)? There are variables on the diagnostic page. I have everything running the way I like it other than having the record feature working. I set up the alarms posted on the original post of this thread and my tablet seems to alarm quite a bit so Im trying to figure out what the issue could be...datalogging would help quite a bit haha
Old 08-08-2016, 07:14 PM   #638
steve99
Drives: FT86
yep probably just need to re calibrate touch screen you can do that yourself in menus, use a pointer of some sort as fingers are too fat to calibrate screen properly
Old 08-09-2016, 08:54 AM   #639
GT86 Guy
Drives: 2016 Scion FRS Raven
How do I know I hav successfully flashed a stage 2 tune? Feels like the car is pulling a bit heavy after my stage 2
GT86 Guy is offline   Reply With Quote
Old 08-09-2016, 06:25 PM   #640
steve99
Drives: FT86
Car will often feel a bit strange straight after flash, throttle might be a bit laggy, should clear up after a couple of drive cycles..
unfortunaly you cannot read out the tune with oft. but you could log the tune
bedabi (08-16-2016)
Old 08-10-2016, 01:41 PM   #641
pancake
Drives: 2015 BRZ Limited MT
How risky is the stage 1 91 tune?
My car is only a year old, and i'd like to be able to get warranty work if needed.
Any reports of engine issues after running stage 1 OFT tune?
pancake is offline   Reply With Quote
Old 08-11-2016, 07:45 PM   #642
GT86 Guy
I'm thinking about retuning it. Just flashing the stock ECU then stage 1 then stage 2 if those steps are necessary. With the Tomei headers I'm using a lot more gas it seems like. Idk if that's because I love the sound and I'm just smashing the pedal.
Old 08-11-2016, 08:36 PM   #643
choiboie
Drives: 2013 Fr-S UltraMarine
I just noticed that too
Sent from my SM-G920V using Tapatalk
choiboie is offline   Reply With Quote
Old 08-14-2016, 08:24 PM   #644
fibble
Drives: 2015 86 GTS
Stg 1 is not particularly risky on a stock car - use the best quality fuel you can.
But........to be sure.........you need to log your tune. Read the links in steve99 signature.
Totally up to you, but you may want to flash stock tune before you go to dealer for unrelated warranty work.
fibble is offline   Reply With Quote
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
