Old 04-02-2014, 03:54 AM   #631
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
@gmsii
(What) aftermarket header is being used in these tests? Asking as haven't heard of one confirmed that fits with this kit.
Also are the toothed pulleys now shipping with kits?
Lastly as others pointed out, with this larger blower what other mods are required?.. Fuel pump, clutch, injectors etc?....
Any chance you guys will create a thermostatic controlled engine oil cooler?
Impressive gains for sure!
Old 04-02-2014, 08:06 AM   #632
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Originally Posted by KraftWerks View Post
We've got a few updates for everyone!
Note:
-All testing was done using California 91 Octane
Pretty cool numbers here. Does the C30 "high boost" tune require fuel mods?
Ralph Spoilsport is offline   Reply With Quote
Old 04-02-2014, 11:38 AM   #633
Originally Posted by gmsii View Post
and your purpose for pointing this out is??
it will be the new tune that gets certified
for those that dont know, the longest process with CARB approval is not the lab testing...its the paperwork submittal and approval process. the paperwork has now all been approved and will be going to the lab for final testing and approval.
It's a genuine question. We have several customers on the fence, but are not willing to commit to purchasing the KW kit without a CARB EO#.
Your kit is a difficult sell for California customers when there are 3 other supercharger kits that are CARB legal, so we're looking forward to getting that CARB approval on your kit.
Old 04-02-2014, 11:44 AM   #634
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
To answer some of your questions:
-The aftermarket header used was ours, the borla works as well.
-With the pulley upgrade we used stock fueling.
-When the C38 was tested we installed Grams 550cc injectors as well as a Grams 265 fuel pump.
-We will look at a thermostatic cooler
-Toothed pulleys will be going out to existing customers
KraftWerks is offline   Reply With Quote
Old 04-02-2014, 11:50 AM   #635
djdnz
1337
Drives: 2013 BRZ WRB S/C
If you are truly concerned as a vendor who has questions for real potential customers then you would be contacting KW via email or phone, like a proper business would - rather than posting through a forum and waiting for a response that could take weeks.
It's pretty obvious you are JRSC fan, and almost every post in this thread shows it. There is no problem with that, but after a while it becomes tiring when you are constantly badgering the competition.
djdnz is offline   Reply With Quote
Old 04-02-2014, 12:19 PM   #636
sw20kosh
Drives: 2013 Black FR-S
this
Old 04-02-2014, 12:29 PM   #637
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Glad to see I'm not the only one that's been thinking that.
Freeman is offline   Reply With Quote
Old 04-02-2014, 01:02 PM   #638
Model Citizen
Lacking brains
Drives: frz
X3
Model Citizen is offline   Reply With Quote
Old 04-02-2014, 02:23 PM   #639
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
x4
glamcem is offline   Reply With Quote
Old 04-02-2014, 03:08 PM   #640
Ralph Spoilsport
That C38 is making my credit card twitch. 15% more torque from 3K up.
What do you suppose happens on 100% stock exhaust with C38? Back pressure, sure, but turbos make a ton of back pressure too. Not too worried about bleeding edge peak HP #'s. Would rather keep stock exhaust (it's paid for, quiet, OEM reliable, heat shielded).
Old 04-02-2014, 03:21 PM   #641
Calum
That Guy
Drives: 2013 asphalt FRS MT
Given that the aftermarket header made pretty well zero difference on the C30, I'm guess, and hoping the header will make little to no difference. Don't worry, my credit card is twitching pretty hard now to. I've just got to remind myself to wait for other to test the waters.
Old 04-02-2014, 03:55 PM   #642
glamcem
glamcem's Avatar
Revised Kraftwerks Tune "r2" vs high boost - (stock header and exhaust on both pulls, smaller blower pulley used for higher boost. C30-94 used on both)
when you say higher boost, how much of boost are you referring to?
AFAIK, kit makes 9 psi boost at redline.
Thanks in advance
Old 04-02-2014, 06:15 PM   #643
KraftWerks
KraftWerks's Avatar
Thanks in advance
No problem!
-High boost with the C30 was 13psi
-High boost with the C38 was over 14psi (we haven't finished that tune)
Old 04-02-2014, 07:03 PM   #644
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Are the C38 and C30 "low boost" runs the same psi?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
[TX] DFW General Discussion feedbag Southwest 1488 06-18-2022 07:25 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
ROTREX SC Brainstorming MANDALAY Forced Induction 61 12-11-2012 05:57 PM
Rotrex kit - why no build? MindtheGap Engine, Exhaust, Transmission 5 10-26-2012 07:01 PM
