#6385 |
Drives: 2013 Asphalt 6spd
eh he flipped some tables. didn't take anything, didn't hurt anyone. being that they were in his house it's more like telling them to gtfo after they had been putting out they cools on his floor.
and if anyone got the reference, he may have actually had a rug from persia
#6386 |
Anyone else enjoying Shiv's 1.5dump tune as much as I am
#6387 |
Erected Member
Drives: frs
Where did you get the 1.5 dump tune? Didn't know it was out yet.
#6388 | |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
What do you think is happening to the car that causes it to shudder and stall under these conditions? Thx
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#6389 |
#6390 | |
......see below example of what happens with a 3500 Rpm launch ![]() ![]() [ame="https://www.youtube.com/watch?v=zWbuV0uewLM"]FRS BRZ OpenFlash header(OFH) - Nameless trackpipe - Phantom SC - YouTube[/ame] I think he was having a different issue where his compressor was turning on by itself without WOT. If the compressor turns on when the throttle is closed it will force air into the engine when it doesnt want any and cause it to stall. This condition will typically only happen if the brake isn't set fast enough to slow the compressor after a WOT run and clutch in. If the compressor is spinning when the car is idle it will most likely stall. |
#6391 | |
Drives: Fiat Abarth
I've done alot of WOT pulls in 2nd gear at 2K RPM, feels awesome. Motor never feels stressed. Now if I'm at 2K in 5th/6th thats a different story, I'd downshift to get RPMs up-to 3/3.5K before going WOT.
Phantom Supercharged BRZ | 205WHP / 185WTQ Nameless FP/OP Combo |
#6392 | |
#6393 | |
#6394 |
sounds like we need a relay hooked up to some rpm signal, so it will open/close the throttle switch circuit only after a certain rpm. Like SPM only rpm based not a secondary button.
on second thought, that seems like over complicating the issue by fixing the symptom insted of the problem. I wonder if the controller could be programmed to engage the esc more gradually, allowing the ecu to compensate insted of running lean. I don't think modifying the tune would help, because the boost is so sudden it has no way to anticipate. Last edited by Target70; 06-25-2014 at 07:44 PM. |
#6395 |
Drives: 2013 Toyota 86
Rob put me on the waiting list and I'm pretty excited , can't wait to try this out!
How long do you think the wait might be and is the kit set up for the 1.5 dump pack? |
#6396 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Just tell rob you want the 1.5 pack.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#6397 | |
Yes the controller can be programmed by Rob to come on slower but that wrecks all the fun of the ESCs instant boost. |
#6398 | |
Go-Kart Enthusiast
No need for a blow off valve has always raised a brow for me. Another question, if the braking for the turbine does not work correctly, like it did in this example, do you think it could create too much boost with nowhere to go? I love this concept and I am really toying with its purchase. Excuse my ignorance I am trying to understand. thx
FRS
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
