Old 06-10-2014, 12:02 PM   #6147
shif7i7down
Erected Member
Drives: frs
Originally Posted by robwbright View Post
147 pounds and location is 570+/- feet above sea level... I do have a 10" powered sub in the trunk which weighs about 22 pounds.
You should be killing me on 0~60 and et. I say invest in a better non torque pro device. Smartphones can do allot of things, just not very efficiently.
Side note:
My experience with the phantom electric supercharger is lacking. I haven't the opportunity to change broken belts or play around with hose clearance (rubbing) issues, or boost spikes. It's just been sitting in my engine bay giving me boost on demand without any of the fun issues that other kits are having.
Infact sometimes i forget that it's even there until it kicks in when I'm making a pass
shif7i7down is offline   Reply With Quote
Old 06-10-2014, 05:39 PM   #6148
raven1231
Definitely have a problem with my setup...voltage reads 25x, drops when accelerating, makes noise but doesn't really go anywhere at all. The pull factor of the esc is gone . I'll try and get more logs tomorrow
Old 06-10-2014, 05:54 PM   #6149
fenton
Check the three wires between the controller and compressor.... One of those might be loose or popped off.
fenton is offline   Reply With Quote
Old 06-10-2014, 06:06 PM   #6150
raven1231
Already checked all the wiring thanks though
Old 06-10-2014, 06:40 PM   #6151
shif7i7down
Erected Member
Drives: frs
I had a problem like that once and found that the hose clamps weren't tighten tight enough. Had to use a socket to tighten it and it started working again. I guess you could call it boost leak
Old 06-10-2014, 06:41 PM   #6152
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
man, you are having the worst luck. I hope you are able to figure it out.
Old 06-10-2014, 07:45 PM   #6153
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by shif7i7down View Post
Nope no header, pretty much totally stock besides the k&n drop in filter and esc. need to order my ofh and exhaust, but I'm gonna go with 4.88 final drive and stickier tires first. Wanna see if i can hit low ,low, low 13s with it looking sleeper. stock twin turbo supra contender
Good to hear. I have the same K&N with a catback (useless for performance) so hopefully I see similar numbers when I get an ESC.
l0aded is offline   Reply With Quote
Old 06-10-2014, 07:58 PM   #6154
raven1231
I checked it aswell. It looked snug but ill try tightening it anyway can't hurt
Old 06-10-2014, 08:01 PM   #6155
raven1231
Thanks bro same here.
Old 06-10-2014, 08:16 PM   #6156
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Does the voltage drop to 18.x right away?
Installed Mods:
Old 06-10-2014, 08:16 PM   #6157
fenton
Can you test the voltage of the dump packs they should be 12.7 to 13v.
It sounds like you shorted out the charge board fuse maybe.
Do you remember touching the 24v positive to the ground or something like that?
Old 06-10-2014, 08:20 PM   #6158
raven1231
Where is the chargeboard fuse ?
Old 06-10-2014, 09:22 PM   #6159
fenton
I believe it is in the controller box so it isn't accessible. @Robftss can confirm.
It just sounds like your pack isn't charging which may mean something shorted.
Old 06-11-2014, 06:28 AM   #6160
raven1231
No sir it drops down to lower 20's.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
