#6147 | |
Erected Member
Drives: frs
Side note: My experience with the phantom electric supercharger is lacking. I haven't the opportunity to change broken belts or play around with hose clearance (rubbing) issues, or boost spikes. It's just been sitting in my engine bay giving me boost on demand without any of the fun issues that other kits are having. ![]() Infact sometimes i forget that it's even there until it kicks in when I'm making a pass
#6148 |
Definitely have a problem with my setup...voltage reads 25x, drops when accelerating, makes noise but doesn't really go anywhere at all. The pull factor of the esc is gone . I'll try and get more logs tomorrow
#6149 | |
Check the three wires between the controller and compressor.... One of those might be loose or popped off. |
#6150 |
Already checked all the wiring thanks though
#6151 |
Erected Member
Drives: frs
I had a problem like that once and found that the hose clamps weren't tighten tight enough. Had to use a socket to tighten it and it started working again. I guess you could call it boost leak
#6152 |
Drives: 2013 Asphalt 6spd
man, you are having the worst luck. I hope you are able to figure it out.
#6153 | |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#6154 |
I checked it aswell. It looked snug but ill try tightening it anyway can't hurt
#6155 |
Thanks bro same here.
#6156 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Does the voltage drop to 18.x right away?
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#6157 |
#6158 |
Where is the chargeboard fuse ?
#6159 |
I believe it is in the controller box so it isn't accessible. @Robftss can confirm.
It just sounds like your pack isn't charging which may mean something shorted. |
#6160 |
No sir it drops down to lower 20's.
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
