Old 02-22-2016, 01:33 AM   #603
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by Sojhinn View Post
If you were flooring it... It doesn't look like it was registering full throttle. There's a way to remap throttle position but I would first suggest loading any map and seeing what happens.
On one of you videos I saw that the batteries were going up to 29.2 volts. How long does it stay there?
Very rarely does it jump to 29+. This only happens when I go from full throttle to nothing and it will briefly jump above 28.5 before leveling back.
A question about motors, if it was damaged, could this be a symptom or would it just stop working completely? From my limited understanding, if it is partially working then it is most likely the power source (and one of those .5 packs could be the issue).
In the morning I will try remapping to one of the newer Procede maps I've been wanting to try and clean the intake filter on the off chance it is super clogged and causing the ESC to be unable to suck as hard.
l0aded is offline   Reply With Quote
Old 02-22-2016, 01:35 AM   #604
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Most likely the motor isn't bad. If it was bad I doubt it would sound the way it did. The voltage item sticks out to me because a battery pack that's bad would result in a charge above 29.
Installed Mods:
Old 02-22-2016, 01:45 AM   #605
l0aded
Addicted
l0aded's Avatar
That's a good point. I don't think I've seen charges above 29 until recently.
Old 02-22-2016, 01:46 AM   #606
Sojhinn
Sojhinn's Avatar
I'd say take apart the battery pack and test each battery. If you need a .5 pack I have two batteries.
Installed Mods:
Old 02-22-2016, 01:54 AM   #607
l0aded
Addicted
l0aded's Avatar
Can you give more detail on testing the packs? Do I just use a separate the batters, use a volt meter, attach it to both terminals and it should give a certain range?
Also thanks for your help at this late hour
Old 02-22-2016, 01:54 AM   #608
Sojhinn
Sojhinn's Avatar
Yup should be around 12.X
Installed Mods:
Old 02-22-2016, 02:34 AM   #609
PantsDants
Drives: Scion FR-S A/T, Whiteout
On the subject of batteries, I've got the old Powersonic setup and I've noticed that my voltage has been sitting around 29 pretty consistently, so I'm thinking about switching to the Rev 2 batteries.
Do I need new cables or anything else to convert from the old batteries to the new ones?
PantsDants is offline   Reply With Quote
Old 02-22-2016, 12:09 PM   #610
l0aded
Addicted
l0aded's Avatar
From Rob's e-mail, he suspects:
"with those voltmeter values.....looks like there is no dump pack/bad dump connection/bad battery connected. or one of the three motor wires is poorly connected."
I reconnected the 3 color wires incase but they were fairly snug. Next steps will be to test voltages.
Out of curiosity, have you felt your boost "weakening" at all from when you first got it? It can easily be placebo or even slightly different gas mixtures but I feel like my boost has been diminishing over the course of the last 6 months.
Old 02-22-2016, 12:49 PM   #611
Sojhinn
Sojhinn's Avatar
Pants which kit do you have again?
Installed Mods:
Old 02-22-2016, 12:50 PM   #612
DAEMANO
Time Traveller
Oh definitely triple check the 3 connectors going to the compressor. I have them connected, very gently crimped (i mean GENTLY), then taped individually to seal, then zip tied so there is nothing pulling on them.
Interesting... what batteries are you on? Some logging will easily confirm/deny su dyno de culo. Post em when you get a chance, that'll be valuable info.
Old 02-22-2016, 02:40 PM   #613
PantsDants
I've got the lightened compressor wheel and updated controller without the drag reduction hose thing, so I think that's V2?
Old 02-22-2016, 02:47 PM   #614
PantsDants
I've noticed that I seem to be capped around 4 psi these days; could just be that I'm not really engaging boost down low. It doesn't seem noticeably slower or anything; I probably wouldn't have noticed if not for my logs. I've confirmed that my procede is reading the throttle correctly, so without taking everything apart to test, I'm guessing one of the dump batteries may be on the way out. The higher-than-normal reading on the voltmeter seems to corroborate with that.
Old 02-22-2016, 03:08 PM   #615
DAEMANO
Time Traveller
Keep in mind that most people only get above 4 psi at very low RPMs. Anything above 4psi at greater than 3.5K RPM is a bonus.
Old 02-22-2016, 03:27 PM   #616
stevo585
Drives: White 2014 BRZ
Fwiw Temperature and altitude will also effect boost pressure. PV=RT.
On ecutek I saw the MAP read .33 bar (4.8 psi) between 3-4k rpm. I wasn't driving the tuner was but he didnt hit WOT that low. At 7.5k it read .1 bar (1.5 psi). V1 kit with Big Crank batteries.
That was 45-50 F and sea level in FL.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
