Old 07-24-2016, 05:36 AM   #603
Tor
Tor's Avatar
Drives: Toyota GT86
I read that on the other Subarus they can start/stop logging by pressing the rear defroster.
Are there any tricks to start/stop logging in our cars?
Tor is offline   Reply With Quote
Old 07-24-2016, 06:52 AM   #604
steve99
it can be done the defog ram address for A01G is known think it was in logcfg.txt on first post need to uncomment trigger lines, but it can be intermitent i gave up on it
Old 07-24-2016, 07:04 AM   #605
Tor
Tor's Avatar
Drives: Toyota GT86
So most effective/reliable way is just to pull the car over and switching it off/on when wanting to start a new log? (That's how I did it so far).
Old 07-24-2016, 06:26 PM   #606
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Get something like this.
http://www.ebay.com.au/itm/like/1821...pid=107&chn=ps
Old 07-24-2016, 07:11 PM   #607
Tor
Tor's Avatar
Drives: Toyota GT86
Originally Posted by Wayno View Post
I was under the impression it was no-no to turn OBD2 adapters on/off with ignition on? Couldn't I just unplug it as well (until I get a cable, obviously a switch is easier)?
Old 07-24-2016, 09:23 PM   #608
Wayno
Wayno's Avatar
Connecting all the data pins != switching the power line.
Old 07-24-2016, 10:24 PM   #609
lizbrayan
Drives: '15 Scion Frs Steel
I got a friend that has a '13 manual frs and he has a cai. He wants me to flash a rom so that the cai would work with the maf sensor, how would i accomplish this?
Sent from my SGH-T999N using Tapatalk
lizbrayan is offline   Reply With Quote
Old 07-24-2016, 11:04 PM   #610
Wayno
Wayno's Avatar
You can't just flash a rom, you have to do some actual tuning if you want to make an intake work. This isn't a tuning thread.
Old 07-25-2016, 12:35 AM   #611
steve99
as per what wayno said
you can start here
aftermarket intakes will upset the maf scaling.
alternative is your mate sells his intake ,puts stock one back on with drop in filter, that about as good as most aftermarket intakes with 10 times less hassle
See here for further info and MAF Scaling
http://www.ft86club.com/forums/showthread.php?t=64790
Old 07-25-2016, 12:47 PM   #612
lizbrayan
Checked the base timing b in the stage 1 oft 93 tune and it just looks odd could one of you just check it out for me ? Its for my buddys car so I dont want to screw anything up on him.
Old 07-25-2016, 05:35 PM   #613
Tor
Tor's Avatar
Drives: Toyota GT86
What am I doing wrong? This is now 2. time that the Tactrix doesn't save my log, despite flashing blue.
1) I plugged it in. Drove, stopped and turned off the engine 2 times, to make 3 logs.
2) Took out card, plugged the card into my computer's card reader (Mac). Copied two logs over. 3) Put the card back in the Tactrix. All good....
3) Put card back in Tactrix - repeated 1)
4) Got home, connected Tactrix via USB (without taking the card out, so I can't be that I didn't put the card in properly). Only the 3 previous logs on the card.
Do I have to delete the logs to get Tactrix to log again?
Old 07-25-2016, 05:43 PM   #614
steve99
TACTRIX creats a bit of debug info in a file called “logcfg.out" might give you a clue
also remove any trigger lines in code in logcfg.txt thats the sort of weird stuff that happens with triggers
Old 07-25-2016, 05:46 PM   #615
steve99
card must be formatted fat32
dont have laptop connected to tactrix while logging it does not work
Old 07-25-2016, 06:03 PM   #616
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks Steve nothing connected, format is FAT32. Clue is probably in the triggers (thanks!):
Code:
;-------------triggers---------------
conditionrpn = RPM,0,>
action = start
conditionrpn = RPM,0,==
action = stop
I think I did like this:
1) Switch off ignition.
2) Wait for Tactrix stop flashing (to be sure not to corrupt the log data, don't know if it's necessary? Normally you shouldn't unplug a disc being written to).
3) Start the car directly again.
I guess starting the engine directly again, maybe it's doesn't have time to boot up, and just never register "conditionrpn = RPM,0,>". When it finally boots, the rpm are already at idle speed.
So I should just delete those lines quoted above? If there are no triggers in the logcfg.txt, what decides when it starts to log, "power on"?
Another question, should I remove the SD card when doing ECU flashing? I do that now just to be safe side, but is it necessary?
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
