Old 07-22-2016, 04:33 AM   #589
steve99
Originally Posted by lizbrayan View Post
So I made a zip folder that has my stock rom from the ecu and the oft stage 2 uel 93 tune that "has" my calid. @steve99 and if some of you other guys can also help me out thatd be great thanks!
yep your stock rom is ZA1JD00D it was saved in ecuflash .srf format so hex locations different, you can open the rom and save it as .bin if you load a ECUFLASH DOOD def into the correct directory in ecuflash then the hex locations they are 8000,10000,11EB9E hex in standard bin format
checked the stage2 rom in your zip its real D00D as well so you will be able to use standard ecuflash D00D definition to flash
be sure to allow ecuflash to correct checksum before flashing
Old 07-22-2016, 04:37 AM   #590
steve99
Originally Posted by Tor View Post
Yes, I meant brake pressure via own sensor. Hence, I would think it's probably easier to add a potentiometer to the pedal. Probably not as accurate as monitoring pressure, but probably enough to pick up brake technique mistakes or spot bad habits.
Seems like it would be possible, another project for the winter.
P.s.
I read the link you gave about KCA and now I think I understand what you meant with "be careful with adding timing". Because the ECU can't pull as much timing with Waynes map as the stock one can (lower values in KC Advance Max A), in case one would add much too much?
Again, thank you were much for your help.
main reason is some people just blindly copy base B say out of a standard OFT tune into wayno's without realising that he has changes the KCA table from what oft guys use
Tor (07-22-2016)
Old 07-22-2016, 08:56 AM   #591
lizbrayan
Drives: '15 Scion Frs Steel
So im good to go? i have the za1jd00d def in the brz 2014 folder because theres no 2015 folder and the 32bitbase def in the base folder. What do i have to check in the za1jd00d def to make sure its okay?
Sent from my SGH-T999N using Tapatalk
lizbrayan is offline   Reply With Quote
Old 07-22-2016, 09:14 AM   #592
Tor
Tor's Avatar
Drives: Toyota GT86
I see. No, I would have select all fields in Base Timing B and added 2 degs with "Increment Value (Coarse)" arrow-up button.
I got helped to another solution. However, my questions are wandering off the Tactrix topic. So to avoid clutter I'll find appropriate threads when I have further questions.
Again many thanks for your help, and to everyone else who helped me out in this thread!
Tor is offline   Reply With Quote
Old 07-22-2016, 01:34 PM   #593
Kodename47
Kodename47's Avatar
Drives: UK GT86
Don't just go adding 2 degrees across the whole map....
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-22-2016, 03:37 PM   #594
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks, yes I have the utmost respect for messing with thing. I wouldn't have done that without a lot of questions first with exactly how to go about it. I just meant I certainly wouldn't blindly copy/paste anything from another map. I'm surprised that there are people treating it all with such carelessness. They must have deep pockets.
I noticed yesterday that my brakes are so bad I am not driving the car before I get my brake job done (got my new XP10 pads in the mail today). So first priority is now brakes.
I also want to drive on track next Wednesday, so I'm considering just to leave it all as it is on Waynes 108.2 tune and log it there to see how it behaves. For me it's more important that it has a conservative track tune, than to squeeze out every hp for street usage. During the pulls I logged it had no knock at all.
I also did a log pulling the car fairly hard up a hill on a backroad in mid rpm range (I think I was feeling out the torque dip) - there after just normal cruising. To be honest, I didn't look at that log very thoroughly until today
http://datazap.me/u/tor/ww1082-drivi...26-27&mark=332
During the "hill climb" there were a 4 flkc events (0.65 range) and 2 fbkc (1 at -2,1 at 3200 rpm and 0.93 load, going off the throttle). I suppose that is "normal"? And even with these events more timing wouldn't hurt, possibly pulled back in those areas if it's consistently reproducible?
Now I am getting off-Tactrix topic again. I guess I should use the sticky datalog thread instead?
Old 07-22-2016, 04:57 PM   #595
lizbrayan
Alright so i flashed the oft stage 2 uel to my car. Feels great. Just got a question is it possible to program a launch control on an a/t with ecuflash, if so how do i do it?
Old 07-22-2016, 05:03 PM   #596
phrosty
In theory it may be possible, but your torque converter stall limit gets in the way of any meaningful launch control.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 07-22-2016, 05:34 PM   #597
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Tor if you're using Wayno's base and advance tables, if you want to advance timing I would suggest no more than 1 degree at a time and even then it's only really beneficial to do it for WOT loads. You might find some response improvements by adding timing in medium transient loads (~0.8+) if you're not showing any signs of timing retard but there's no point in increasing timing on cruise over stock IMO. How you add this is up to you, in the base table or the advance, just remember to check the totals of the 2 combined to try and keep a smooth-ish table.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
Tor (07-22-2016)
Old 07-22-2016, 06:12 PM   #598
Tor
Tor's Avatar
Drives: Toyota GT86
Thanks for the description. It helped to increase my understanding. For now I wont need to change anything. It was stupid to mention the +2 deg on the whole table, without the full picture. What I meant to say was "I won't copy tables from one map to another without someone telling me why to do it".
Old 07-22-2016, 06:42 PM   #599
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You place your left foot on the brake pedal and your right foot on the accelerator. When you hit the desired RPM, lift your left foot. Last I remember, all the launch control did was hold a chosen rpm before dropping the clutch.
The Following User Says Thank You to EAGLE5 For This Useful Post:
lizbrayan (07-22-2016)
Old 07-22-2016, 06:43 PM   #600
lizbrayan
Lol you made me laugh bud, it was worth a shot
The Following User Says Thank You to lizbrayan For This Useful Post:
EAGLE5 (07-22-2016)
Old 07-22-2016, 06:46 PM   #601
EAGLE5
Dismember
EAGLE5's Avatar
Are you sure you're from Jersey? Your skin is awfully thick and you're awfully smart. You must not be a governor.
lizbrayan (07-25-2016)
Old 07-22-2016, 11:47 PM   #602
steve99
No not easily
you need mechanical changes to the torque converter in the auto. and number two the launch control rpm limiter is a software patch to the actual ecu coding like flat foot shifting. Changing ecu program code is a whole new level of dificulty and skill as oposed to changing table vaules like about 100 times
lizbrayan (07-23-2016)
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
