Old 08-01-2013, 05:59 PM   #589
Luis_GT
Originally Posted by supra2nv View Post
Shit...
Lol
When is my mono due to arrive??? Lol
Edit: I ordered custom titanium rods and billet pistons working with Crawford. I am trying to benchmark nsx-r ish type mods...FYI
The Following 2 Users Say Thank You to Luis_GT For This Useful Post:
chanomatik (08-01-2013), supra2nv (08-01-2013)
Old 08-02-2013, 01:28 AM   #590
Anaxilus
Drives: They have four wheels
Rods, pistons, cams made by who?
Nothing to do w/ the cylinder heads/valves? What's Crawford's take on the airflow?
Anaxilus is offline   Reply With Quote
Old 08-02-2013, 02:50 AM   #591
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
You will know soon enough. ..
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
supra2nv (08-02-2013)
Old 08-02-2013, 03:00 AM   #592
supra2nv
supra2nv's Avatar
Drives: 10 Series TRD
i cannot wait to have more than 8k rpm on this bad boy...im asking for 9k lol
"Electrons act like photons. They are both screwy, but in exactly the same way." Richard Feynman
Wave Particle Duality
supra2nv is offline   Reply With Quote
The Following User Says Thank You to supra2nv For This Useful Post:
ill86 (08-02-2013)
Old 08-02-2013, 03:05 AM   #593
torqdork
torqdork's Avatar
Drives: RV-7
With your mods, 8K should be cake. I think you might just exceed NSX specific power output per liter, too. As sweet as these things sound at 7.5K, 8K+ will be addictive.
torqdork is offline   Reply With Quote
The Following 2 Users Say Thank You to torqdork For This Useful Post:
ill86 (08-02-2013), supra2nv (08-02-2013)
Old 08-02-2013, 03:16 AM   #594
37
degrees
37's Avatar
Drives: 6MT BRZ
What are the lift and duration specs on the cams? How much heavier are you going on the valve springs? Ti retainers?
What has Crawford said about his expectations with these parts?
Since you're throwing your warranty out the window anyway, any reason why you aren't going FI instead? I can't imagine those rods, pistons, cams, springs, retainers, and whatever tuning time Crawford chews up will be cheap.
Torque in the FA20 falls sharply after ~6700 RPM so it'll be interesting to see if you gain RPMs for the sake of not bouncing off the rev limiter or if you actually carry power out further to make use of the noise.
37 is offline   Reply With Quote
The Following 2 Users Say Thank You to 37 For This Useful Post:
Old 08-02-2013, 04:51 PM   #595
supra2nv
supra2nv's Avatar
I like naturally aspirated, revvy, light, quick, it's my thing, i love bikes, i'm not allowed to buy one, cars are my loophole
my car has already had its ECU tuned (needed to quench my palette for a bit), so I eliminated the torque dip, i have some more hp and torque, and the power band looks more consistent now less choppy than stock, at least with my Layman approach to looking at my dyno graph lol. my brain tells me its fantastic already by simply getting in the darn car and driving it lol, and the engine internal mod can only add, is my guess...but time will tell are there comps? my gut tells me this car will be so fun to drive, it is already
PS: I inquired about titanium valves this morning...
ill86 (08-02-2013)
Old 08-02-2013, 05:39 PM   #596
37
degrees
37's Avatar
Drives: 6MT BRZ
...and the engine internal mod can only add, is my guess...but time will tell are there comps? my gut tells me this car will be so fun to drive, it is already
Internals should only be necessary in places where high RPMs truly stress components. It's unknown what the stock components can handle but it's safe to assume the valvetrain is the limiting point. Cams, valve springs, and lightweight retainers might be all that are needed. Rods and pistons could be overkill unless you're going significantly lighter (which I assume is your reasoning).
My only concern is that while it's certainly possible to build a 9000 RPM powerplant, there might not be any benefit in power. It might just make more noise. On a road course it could save from having to shift as often if you're able to carry speed for another 1000 RPM before the next corner. But, I don't see this turning into a track car with how much you've invested into it.
Ti valves sound like a bad idea unless they're VERY well made and of the right alloy. My question was about Ti retainers, and good ones at that. These typically need to be light weight to prevent valve float at higher RPMs.
It might be a while but I'd love to see the before and after dynos on your project to compare the lightweight parts. I'm very curious to see what happens to the torque curve after 7000.
Good luck!
Old 08-02-2013, 06:55 PM   #597
ill86
ill86's Avatar
Drives: iG FR-S
Sometimes cars get built behind closed doors.
This is one of those times. He's just being nice enough to drop breadcrumbs to tease anyone reading.. Lol
I'm consulting and encouraging his build because it is a very special case. :-)
I'm sure he will continue to share findings and Crawford will post when ready if it all necessary.
Stay tuned.. ;-)
Old 08-03-2013, 02:56 AM   #598
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
@supra2nv and @zephyr69 are your TRD strut braces fitted with the brackets in front of it (ie: strut brace bolted to the back) like mine, or with the brackets at the back (ie: strut brace bolted to the front).
I've got a mate and his is fitted with the brackets on the other side from mine. Mine seems to me under tension the way it is. Not sure which fitment is correct.
Here's a photo of the brackets on mine showing the strut brace behind the brackets. What's yours like?
nzer is offline   Reply With Quote
Old 08-03-2013, 04:30 AM   #599
zephyr69
Drives: TRD FT-86
Hi, nzer. Mine is fitted as shown in the picture below taken from speedhunters TRD 86 democar. So this is the correct way of it being installed. The strut bar should be in front of the brackets and not the other way around.
zephyr69 is offline   Reply With Quote
The Following User Says Thank You to zephyr69 For This Useful Post:
nzer (08-03-2013)
Old 08-03-2013, 08:50 AM   #600
nzer
nzer's Avatar
Yours looks the same as mine with the black brackets in front of the strut brace. You sure yours is behind the brackets?
Old 08-03-2013, 08:58 AM   #601
zephyr69
Drives: TRD FT-86
Ah ok I know exactly what you mean now..lol. sorry for the confusion, mine installed just like yours. I've checked my car and pictures of TRD demo car and both have black brackets in front of the strut brace. So your strut brace is installed correctly. I am sure of this. Not 100% sure if it makes a difference, but its probably best that your mate goes and gets his fixed.
nzer (08-03-2013)
Old 08-03-2013, 09:08 AM   #602
nzer
nzer's Avatar
Thanks @zephyr69. Does yours look like it is under a bit of tension? Mine has a slight bow in it as it looks like it is pre-stressed how it is installed.
@supra2nv is yours straight or does it have a slight tension bow in it?
The Following User Says Thank You to nzer For This Useful Post:
supra2nv (08-03-2013)
BRZ in Born To Race Fast Track Trailer switchlanez BRZ First-Gen (2012+) — General Topics 34 06-28-2013 08:21 PM
10 Series are Release Series kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 4 04-30-2013 09:23 AM
Sold my 1st born to join the BRZ crew.... cfl4rat BRZ First-Gen (2012+) — General Topics 31 04-22-2013 12:41 PM
What was the coolest car built the year you were born? ichitaka05 Other Vehicles & General Automotive Discussions 80 09-04-2011 01:43 PM
The wait till my daughter is born WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 73 06-21-2011 09:26 AM
