#589 |
| The Following 2 Users Say Thank You to Luis_GT For This Useful Post: | chanomatik (08-01-2013), supra2nv (08-01-2013) |
#590 |
Drives: They have four wheels
Rods, pistons, cams made by who?
Nothing to do w/ the cylinder heads/valves? What's Crawford's take on the airflow? |
#591 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
| The Following User Says Thank You to ill86 For This Useful Post: | supra2nv (08-02-2013) |
#592 |
Drives: 10 Series TRD
i cannot wait to have more than 8k rpm on this bad boy...im asking for 9k lol
"Electrons act like photons. They are both screwy, but in exactly the same way." Richard Feynman
Wave Particle Duality |
| The Following User Says Thank You to supra2nv For This Useful Post: | ill86 (08-02-2013) |
#593 |
Drives: RV-7
#594 | |
degrees
Drives: 6MT BRZ
What has Crawford said about his expectations with these parts? Since you're throwing your warranty out the window anyway, any reason why you aren't going FI instead? I can't imagine those rods, pistons, cams, springs, retainers, and whatever tuning time Crawford chews up will be cheap. Torque in the FA20 falls sharply after ~6700 RPM so it'll be interesting to see if you gain RPMs for the sake of not bouncing off the rev limiter or if you actually carry power out further to make use of the noise. |
#595 | |
my car has already had its ECU tuned (needed to quench my palette for a bit), so I eliminated the torque dip, i have some more hp and torque, and the power band looks more consistent now less choppy than stock, at least with my Layman approach to looking at my dyno graph lol. my brain tells me its fantastic already by simply getting in the darn car and driving it lol, and the engine internal mod can only add, is my guess...but time will tell are there comps? my gut tells me this car will be so fun to drive, it is already![]() PS: I inquired about titanium valves this morning...
#596 | |
degrees
Drives: 6MT BRZ
My only concern is that while it's certainly possible to build a 9000 RPM powerplant, there might not be any benefit in power. It might just make more noise. On a road course it could save from having to shift as often if you're able to carry speed for another 1000 RPM before the next corner. But, I don't see this turning into a track car with how much you've invested into it. ![]() Ti valves sound like a bad idea unless they're VERY well made and of the right alloy. My question was about Ti retainers, and good ones at that. These typically need to be light weight to prevent valve float at higher RPMs. It might be a while but I'd love to see the before and after dynos on your project to compare the lightweight parts. I'm very curious to see what happens to the torque curve after 7000. Good luck! |
#597 |
Drives: iG FR-S
Sometimes cars get built behind closed doors.
This is one of those times. He's just being nice enough to drop breadcrumbs to tease anyone reading.. Lol I'm consulting and encouraging his build because it is a very special case. :-) I'm sure he will continue to share findings and Crawford will post when ready if it all necessary. Stay tuned.. ;-)
#598 |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
@supra2nv and @zephyr69 are your TRD strut braces fitted with the brackets in front of it (ie: strut brace bolted to the back) like mine, or with the brackets at the back (ie: strut brace bolted to the front).
I've got a mate and his is fitted with the brackets on the other side from mine. Mine seems to me under tension the way it is. Not sure which fitment is correct. Here's a photo of the brackets on mine showing the strut brace behind the brackets. What's yours like?
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#599 | |
Drives: TRD FT-86
| The Following User Says Thank You to zephyr69 For This Useful Post: | nzer (08-03-2013) |
#600 |
Yours looks the same as mine with the black brackets in front of the strut brace. You sure yours is behind the brackets?
#601 |
Drives: TRD FT-86
Ah ok I know exactly what you mean now..lol. sorry for the confusion, mine installed just like yours. I've checked my car and pictures of TRD demo car and both have black brackets in front of the strut brace. So your strut brace is installed correctly. I am sure of this. Not 100% sure if it makes a difference, but its probably best that your mate goes and gets his fixed.
#602 |
Thanks @zephyr69. Does yours look like it is under a bit of tension? Mine has a slight bow in it as it looks like it is pre-stressed how it is installed.
@supra2nv is yours straight or does it have a slight tension bow in it?
| The Following User Says Thank You to nzer For This Useful Post: | supra2nv (08-03-2013) |
| BRZ in Born To Race Fast Track Trailer | switchlanez | BRZ First-Gen (2012+) — General Topics | 34 | 06-28-2013 08:21 PM |
| 10 Series are Release Series | kALMIGHTY | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 04-30-2013 09:23 AM |
| Sold my 1st born to join the BRZ crew.... | cfl4rat | BRZ First-Gen (2012+) — General Topics | 31 | 04-22-2013 12:41 PM |
| What was the coolest car built the year you were born? | ichitaka05 | Other Vehicles & General Automotive Discussions | 80 | 09-04-2011 01:43 PM |
| The wait till my daughter is born | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 73 | 06-21-2011 09:26 AM |
